Using a 7135 regulation chip driver is still pretty easy, stack the extra chips on the inside and the retaining ring will fit like always.
If having ANY chips on the spring side is a problem, remove them and put them on the inside, there’s almost always room for them in the driver bay. I’ve gone 4 high plenty of times.
As an aside, the price you pay for the ArmyTek is potted drivers and glued bezels, similarly the Klarus is difficult to mod as well. Pay more, play less.
For me, the boost driver and constant current drivers are unnecessarily hard on the cell, requiring ever more current from the dying cell. Hard discharges will shorten the cells life as well as leave you suddenly without light in a worst case scenario, while the regulated boards that use 7135 chips will eventually dim and let you know you need to take precaution, as with the direct drive FET drivers. Tit for tat, I guess.
Hence, never ever ever run the cells down that far.
That’s the same reason why I don’t trust multicell (series) arrangements. Even with nominally balanced cells, the slightest imbalance will run down one cell more than the other(s). Only way to keep that from happening is to make sure you don’t get close to burning them down too far.
No the Convoy C8 never have soldered in driver in any version. It always has retaining ring. Only the threaded pill S series had solreded in drivers with 6 or 8x7135s and maybe the early pilled M series. For example the S3 doesn’t have threaded pill so it is a retaining ring type fitting even with 8x7135.
Huh. Your sure right. I had to look just now. I’ve changed drivers in both before, but didn’t realize they were the same size. I thought the S2 was 15mm and the C8 was 17 and that was why the S2 needed to be soldered.
From stock, the 6 or 8*7135 versions are soldered, but 8*7135 can be used with regular retaining ring! It is a more “fragile situation” as the ring can “jump” if the flashlight falls, but it can be done
Can tell about the C8 as I don’t have one. :arrow_right:
Yes, although you don’t have to get the clear version if you want those upgrades. The main upgrades are the XP-L HI emitter, Smooth Reflector, Biscotti Firmware, and AR Glass. There is a Black model with the XP-L HI and smooth reflector; you can add that to your cart and add a note requesting Biscotti and AR glass, then wait for Simon to adjust the price before submitting your payment. For the Gray model, you have to include the XP-L HI and smooth reflector in your note.
So the Clear model is the easiest to order, but you can get the other colors if you prefer.
My very first Convoy flashlight was an early Convoy C8 with an OP reflector. Love it. They’ve been around for a long time, most people just go for smooth reflectors. The OP reflector has a beautiful beam pattern. It’s a pretty light OP but it makes the transition from the hotspot out very smooth and eliminates any rings that might have been there. This ultra smooth beam transition does cost you a bit of throw though. I actually just got an OP C8 reflector from Simon but it’s for the older 7mm opening so it’s not a direct swap in a current model C8 unless you have the smaller centering rings. Old opening is 7mm. New opening is 9mm. The other upgrade that happened at the release of the clear C8 was a new DTP copper MCPCB.
