Anodization is what dramatically increases the heat emissivity of aluminium (because it increases the surface area). Bare aluminium is really bad on the other hand. The color is not important.
There is no secret coating. Only increasing the surface area even more by using large heat fins with the correct spacing will have an additional large benefit. Check out aftermarket PC-component heatsinks to see how cheap, effective heatsinks are made.
This is sarcasm, right?
It can translate poorly over the internet. Plus there are many non English speakers here. I always make sure people know I’m exaggerating because people WILL take you serious.
Well, i like to use Turbo mode for 10+ minutes with randomly switching to low/off for like 10s to reset. After that, it is getting very hot, i would grab another flashlight to play like this again. If a flashlight can only do 1-2 minutes turbo, i don’t think it is good to use it this way.
sure am glad your staying away from here…
its been nice and quiet , thanks….
” If people were more like Dogs the world would be a better place. There would be much less conflict and violence,instead there would be true harmony and grace.
Wolfdog-5.23.2017 “”
that is probably about the dumbest damn thing ive ever heard anyone say.
you ever seen dogs get in a real fight ?
dogs are harmony and grace ? lol !
man, what a fruitcake……
Well, to me, people are mean occasionally. Most of the time people are nice.
Dogs and people are the same. Just don’t take their kindness to be granted.
Let’s focus on MF03 else M4X M4D will get really mad. :smiling_imp: just kidding.
1. Does any one have any suggestion for fan-cooled system ? It might be the best solution for faster heat dissipation from the LED to the heatsink/ fins. How is the mechanical construction / contact to the flashlight through the fins, yet water resistant ?
2. For the numbers of LED, any chances or possibility of having 10 pcs XHP-35 HD for the circular/ surrounding with thick & shallow OP reflectors, while using 1 pc XHP-35 Hi for the center throw with deep SMO reflector ? Can we assume 11*2500 lm = 27,500lm, 11*15w = 165w power consumption?
3. If the overall head diameter is 130mm, then can it be: a) center reflector diameter of 74mm (SMO), b) surrounding 10 LED with reflectors diameter of 25mm each ?
4. Can a diameter of 74mm SMO deep reflector project a 1600 meters distance ?
Sorry for the lack of knowledge.
I need to learn lots of things from the seniors.
Fan cooled requires a complete design starting from scratch. It won’t be this light.
2. Xhp35 are small and weak for the power they consume. You get much more bang for your buck with xhp70.2. Since the reflectors are shallow, the xhp35 has no advantage at all. It would also not be efficient to run xhp35 at 2,500 lumen. That is their max and they produce a lot of wasted heat. It would be 11 x 35w = 385w.
If you use the xhp70.2 at 385 watts, you would get 44,000 lumen!
Not really. Even the 30Q can only do 15A continuous and 20A in pulses according to HKJ. They tend to get pretty hot. Plus you get a lot of voltage sag. More batteries means less voltage sag and more lumens.
I think the Imalent DX80 has about the right battery to output levels. 8 x xhp70.2, 32,000 lumen and 8 x 18650. That’s 4,000 lumen at 5A from each emitter. It works pretty well.
Once you start going over that, like 11 of the xhp70.2 at 5A each, you need 12 cells. If you have 11 at 8A each, then 16 cells. This would be a practical use light I’m talking about. Not a 5 second wonder.
Imagine the GT with its 5.5” diameter head and a copper insert to load up 11 or 12 xhp70.2 using small reflectors. Then a special driver that can handle the power. It would probably be 2 drivers combined or stacked. That would be an awesome light. Now that the GT is shipping, I wonder who will be the first to mod it?
I think DBCUSTOM was talking about running 4 x xhp70.2 with each one in a C8 reflector. That would be cool.
