[New Release] Mankerlight E05 II AL/Cu 1300 Lumen Highest Output Pocket EDC Flashlight in 14500/AA Class
20700 + USB Type-C + 6V emitter, now that is some innovation :slight_smile:
But that UI will be a no-no for me, bummer :frowning:
Not being 21700 capable, the UI, the price, and only 2000lms?
Pass!
Nice light but I donā€™t buy without a discount code.
Manker E02 Titanium Version. Edit 20171212
Special Offer Mankerlight 3 Year Anniversary(link is external) Edition (Manker T01s) is releasing
Features
Emitter: CREE XPL HI LED (CW and NW for your choices)
Maximum 420 lumens output, power by 1x AA battery
Maximum 800 lumens output, power by 1x 14500 battery
Driver: Most efficiency constant current circuit, maximum runtime up to 300 hours
Material: Aircraft-grad 7075 aluminum body
Surface treatment: Premium Type III hard-anodized anti-abrasive finish
Clip: Titanium coated stainless steel clip
Lens: Toughened ultra-clear glass lens with anti-reflective coating
Reversible & removeable Stainless Steel Bezel
Forward Clicky Tail Switch
Dimensions: 105mm (length) x 35mm (Head diameter)
Weight: 45gram (without battery)
Accessories: o-ring *1, lanyard *1, pocket clip *1
Brightness levels & Runtime:
Powered by 1x 2500mAh AA NiMH battery
Working voltage: 0.8v-1.6v
Moonlight 0.5lm 300hrs,
Low 5lm 13hrs,
Middle 58lm 5.5hrs,
High 220lm 1.5hrs,
Turbo 420lm 1.3hrs.
Powered by 1x 3.7V 750mAh 14500 battery
Working voltage: 2.7v - 4.2v
Moonlight 7lm 90hrs,
Low 45lm 12hrs,
Middle 100lm 3.5hrs,
High 270lm 1hrs,
Turbo 800lm, 0.5hrs.
Operation:
Forward clicky tail switch,
On / Off: Click for on and off, 5 output mode in total.
Change modes: click within 0.64 second to change modes,
the light will memory your last mode if the time get over 0.64 second between two clicks.
More details please visit: http://www.mankerlight.com/mankerlight-3-year-anniversary-edition-manker...
Aliexpress: https://www.aliexpress.com/store/product/Manker-T01s-800-Lumen-CREE-XP-L-LED-Flashlight-AA-14500-Torch-With-reversible-Bezel-Mankerlight/1406554_32844293593.html
What a stunner. 8) And congratulations on the anniversary, I love my MK34 very much!:slight_smile:
Thanks Mate :)
Thatā€™s some bezel! I think I might be able to hoe my garden with it. :slight_smile:
On a more serious note, I just got MK41 as a gift for someone - very nice light!
T01s looks great
glad to hear you like our product.
Manker Torch Club; wasnā€™t this Mankerā€™s first light? And if Iā€™m not mistaken, this light was also made from 7075-T6. Could you please tell me why Manker chose this alloy instead of the more conventional 6000 series aluminium?
we choose special alloy for our special models.
Will you offer a smaller and floodier version of this light? Iā€™d buy 3 if it was made, best AA flashlight ever!. Would also love something like the Trunite Archer 1A V3 but with your awesome driver
Manker U22 compact thrower is releasing!
For me thatā€™s definitely the flashlight announcement of the first quarter. And I expect it to be a strong candidate for the flashlight of the year title.
:slight_smile:
Hi Manker, whereā€™s the U21? Couldnā€™t find it anymore
Is it true that the U22 (65.000cd) throws less than U21 (124.000cd)? They both use the same XHP35 HI, correct?
- Clemence
U22 has smaller head (51 vs. 59 mm).
Still, the difference in throw is higher than the size would suggest. Even more so when you consider that U22 has higher output (1500 vs. 1200 lumens).
I prefer the U21 minus the disco mode. Thanks for the info Agro.
- Clemence
U22 was designed as a reliable utility for your daily use.
1. Smaller and lighter than U21, handy and compact, easy to carry .
2. Completely new driver design gives a full play to 21700 battery which will be the mainstream of Lithium batteries.
3. Optimized clicky side switch gives better feeling, smooth and soft.
4. 1500 lumens maximum output and 509 meters maximum beam distance with such a small body
Yup, looks like it. Anyway, does the U21 has been discontinued?
- Clemence
