Hence, never ever ever run the cells down that far.
That’s the same reason why I don’t trust multicell (series) arrangements. Even with nominally balanced cells, the slightest imbalance will run down one cell more than the other(s). Only way to keep that from happening is to make sure you don’t get close to burning them down too far.
No the Convoy C8 never have soldered in driver in any version. It always has retaining ring. Only the threaded pill S series had solreded in drivers with 6 or 8x7135s and maybe the early pilled M series. For example the S3 doesn’t have threaded pill so it is a retaining ring type fitting even with 8x7135.
Huh. Your sure right. I had to look just now. I’ve changed drivers in both before, but didn’t realize they were the same size. I thought the S2 was 15mm and the C8 was 17 and that was why the S2 needed to be soldered.
From stock, the 6 or 8*7135 versions are soldered, but 8*7135 can be used with regular retaining ring! It is a more “fragile situation” as the ring can “jump” if the flashlight falls, but it can be done
Can tell about the C8 as I don’t have one. :arrow_right:
Yes, although you don’t have to get the clear version if you want those upgrades. The main upgrades are the XP-L HI emitter, Smooth Reflector, Biscotti Firmware, and AR Glass. There is a Black model with the XP-L HI and smooth reflector; you can add that to your cart and add a note requesting Biscotti and AR glass, then wait for Simon to adjust the price before submitting your payment. For the Gray model, you have to include the XP-L HI and smooth reflector in your note.
So the Clear model is the easiest to order, but you can get the other colors if you prefer.
My very first Convoy flashlight was an early Convoy C8 with an OP reflector. Love it. They’ve been around for a long time, most people just go for smooth reflectors. The OP reflector has a beautiful beam pattern. It’s a pretty light OP but it makes the transition from the hotspot out very smooth and eliminates any rings that might have been there. This ultra smooth beam transition does cost you a bit of throw though. I actually just got an OP C8 reflector from Simon but it’s for the older 7mm opening so it’s not a direct swap in a current model C8 unless you have the smaller centering rings. Old opening is 7mm. New opening is 9mm. The other upgrade that happened at the release of the clear C8 was a new DTP copper MCPCB.
I ordered another c8 with everything on it and asked Simon for other button and black body color. As before, he said no problem and gave me a discount Probably the best seller i have seen
I have “tested” the beam of my Klarus xt12gt, c8 and Fenix rc20. Fenix has the worst beamshot. Klarus is the best, but is getting hot on max output. C8 is not far away from Klarus beam distance.
hm the klarus says a bit over 600m throw, can the c8 with xpl hi really come close to that? its more around 300-350m throw at most no? either way the convoy wins any day if u look at the price and what u get, clear winner to me.
They need to be on a website, first. Then you take that pictures url and copy paste it into the pop up box when you click the orangish sunset looking button above the post window.
