Flanders
(Flanders)
November 14, 2010, 10:37am
1
Hi, I have a spare sst90, and I am planning on sticking it onto a 14 or 16mm star to put in a small 18650 light
So far I am looking at getting a UltraFire A10B from DX, switching the led over and making it direct drive :)
I realise it will get hot fast, but it is just something to have a play around with in short bursts.
Just wondering if anyone can recomend any other cheap small liights I could use?
or if anyone knows where I can get a 14 or 16mm star board?
Thanks
Don
(Don)
November 14, 2010, 10:43am
2
I'd guess something with a bigger head will do better - it is fairly large as emitters go. Maybe a better bet would be an empty P60 pill and then use any P60 light?
And welcome to BLF! Good to have you here.
xP.1337
(xP.1337)
November 15, 2010, 5:43am
3
flanders, welcome, i have had no luck in the same quest
your best bet is doing a C or D maglite conversion, if you have one sitting around.
either way its expensive.
Don
(Don)
November 15, 2010, 8:18am
4
For the easy, but probably not cheap way, see here .
agenthex
(agenthex)
November 15, 2010, 10:25am
5
Flanders:
Thanks
Proper mounting on a star for something that hot is non-trivial.
The biggest problem with a sst-90 is not even a host, but getting a driver that works. You can try to direct drive with an IMR, but who knows what kind of draw you end up with.
