Emisar D1 / D1S review
D1S thrower has one major flaw: no tail switch
its the thrower that we miss : 50mm head range, p30 looking but has a better reflector, great UI….yet, the lack of a tail switch nukes everything
I asked Hank to redesign it, hoping he will….it will be a hell of a torch with a tail switch!
P.S
It gives 200k candelas and 2.2 lumens with Sst40 folks.
Different people, different needs, I consider the lack of tail switch an important feature.
Same here.
Youre both BLFers, you dont count :slight_smile:
The police forse, hunters , secutiry guards and army personel dont think so.
That light has a potential to become the next C8 generation, unfortunately the lack of a tail switch nukes that.
Hank is a reasonalbe man, D1S with both side and rear switch: definately the next C8
That’s your opinion.
For me, a “nuke” is if a flashlight has a side switch and a tail switch. You have to handle the light before you can switch the modes - that’s annoying as…
As a lockout - OK, but not as a on/off switch
  • for me :wink:
I think, the big Emisar Thrower would benefit a lot from a 26650 Battery tube.
It just looks too thin on the battery-end.
“The next C8”?
I don’t think so.
The C8 is a very cheap (y15:money_mouth_face: yet very good flashlight.
Unless the Emisars drop to under 20$, they are not a replacement.
Missing Tailswitch - how many buyers of flashlights are security-guards and policemen? Maybe 2-5%?
For the throwers, maybe 95%: including hunters and army personel ofc
You cant mount that torch too, thats another minus too
Plus, its quite hard to find that side switch in the dark, plus you can always misclick the side button
A 26650 based flashligt is quite a different story- As other said Ut20 is quite good and in that condition Emisar 50mm thrower covers it, yet Ut20 is 30$ and easy moddable too
By default C8 isnt anyting specialy, XPg2 modded is quite a different story, but then again its not 15$ :slight_smile:
15-20$ price range for a D1S in a host form is quite reasobnable and affortable
While we speak about throwers… :slight_smile:
Side switch only was the reason I got a D1S, I don’t want to use a flashlight with my fist up in the air or by my chest, I want to be able to change modes one handed with the light comfortably down by my side.
I also find with throwers that the further away the beam is from your eye, the less apparent backscatter.
I was looking for a 50 mm head range, 18650 light, wit only side switch. I found it. If it would have a tail switch, I would not buy it.
Don't worry about the police , they got their own crappy lights that make them feel special
Mitko - not sure why the tail switch is so important. The physical placement or the fact it's a power cutoff switch and not electronic?
Is reverse or forward clicky more popular?
For police and security guards, the classic full size Maglites such as this one have been side switch lights for years, and very popular with police and security guards.
Looking at the latest SureFire "R1 Lawman", it seems to have a combo of side switch and tail switch, though I'm not clear on how the UI works.
Of course I don't think the Emisar's are an attempt to be a "tactical" light, and I like it that way. I would agree a tailswitch would go more in the direction of tactical, but for tactical use, I'd consider:
  • better and true HA III coating
  • possible SS bezel and tail
  • tail switch with full support for tactical use - press&hold is max, etc.
For me, keeping the length short and the tail useful for clean tailstanding is important.
Q: Is the 220 kcd on a SST-40 de-domed? Still don't know how to reliably de-dome a SST-40 with chemicals we can actually get.
For these models, I'd rather see a magnet added to the tails, specially for the D1 and D4.
Funny, I’ve been considering adding a tail switch to mine…
Ofc you will, i am pretty sure about that :wink:
Tom, that light has a huge potential with both switches, unfortunately Hank said: Nope!
its like Simon you know, i was begging him for 4 years about those remote switches, 3 weeks ago in a chat he mentioned that he should releace them earlier :slight_smile:
Same with Emisar thrower, such a little step is needed to be the next C8…better and fully as it should be…P30 failed cause of the heavy gluing and lame reflector, S3 Pro cause of the boost driver( andf its hella lame too) and XHP35
Pretty reliable actualy, i have modded arround a dozen C8s and maybe 20 L2s this way, only 1 falut so far whitch is quite normal(a black pethrol looklike dot , some emitters do suffer from that after dding).
SSt40 L2 is the real thing m8, at 8 amps( paired with a black Li26650) it gives those lovely and steady 365-370k candelas and 2.2-3k lumens
Unbeatable
I use it as an offhand observation torch when hunting, running already for 2-3 months like every weekend
And several X6s too, even my own: do you know that at 7.5 amps and the new reflector it gives 115k cds?
According to the specifications, a D1s should be similar in throw to my Convoy L2. Has anybody compared the two? I might have to get one the next time mtn has them in stock if it’s fairly close.
I can see a custom builder using square threads at the tail, where the cell get’s changed out all the time, but I would think a wider more robust square thread would be used. These thin little square threads are a pita and I really don’t see how they’re better than the standard thread, even worse really as far as I’m concerned.
So these very thin little square threads will probably relegate this nice D1S to being a toy, used for lightning and candlelight but not serious usage outdoors as I find it too much hassle to cut square threads. (or the very thin ones to match this, anyway)
Anyone come up with a diffuser for the D1? With it’s flat tailcap, a diffuser would come in handy as a mini lantern and also give the light a more broad swath of light for up close work.
For $40 it is hard to complain about any aspects of the D1 or D1S, they are both excellent lights.
The weird square threads do prohibit practical modding of the tail though, and there isn’t much else to be done.
Of course, perfect being the enemy of good and all that, I think the D1 would be better suited for a proper mechanical tailswitch, probably reverse clicky given the current, instead of the D1S due to head size.
The D1 reflector itself is awesome and makes a nice custom…
Wow ThetaSigma, that looks really sharp! Ti? I like it! :smiley:
Thanks, but it is Mn-Bronze which is my preferred metal. Another week and anywhere that has skin contact will be a lovely chocolate brown color.
Titanium would have been more than double the material cost and this already wasn’t cheap
Agree 100%
No, a C8 can handle much more abuse
The D1S bezel is very thin.
Drop it on a hard surface and the lens will surely crack, the bezel will definitely dent.
