What did you mod today?
Matchbox Instruments HF-R Ti.
I’ve been working on this the last few days and it has finally ended up an XHP50 light with GITD rotary switch markers and a momentary side switch.
There is a thread with a fairly thorough teardown for anyone interested in how these are built.
10250/ 10440 configs
2 x 10250 XHP50 1260lm max with momentary side switch
Built my first driver from parts. Tiny85 and D4 v2 Ramping_IOS was ordered programmed from MtnE. Did the assembly with an iron and a quick re-melt on the stove. 30mm driver, 20AWG and bronze spring
It Works!! :smiley:
@vwpieces
Thanks, and cool!
Excellent work on the HF! Mine was one of the first ones and oddly, it doesn’t look like that! :stuck_out_tongue:
VW, very clean work on that driver, fun isn’t it? :smiley:
Yeah its fun when its done and works. If it didn’t work I would be SOL with no clue why.
30mm is going into SD26, if all goes well it will also charge.
Have a 17 & 20mm to build next. 17mm is for the C8F.
Any clue if anything needs to be changed in the D4 UI code for 2S like the L6?
Very cool; to both vwpieces and CRX
Thanks
I am wanting to see some Hot Air action Don.
2 emitter transplants today:
Nitecore HC30 with cool white emitter got a spare XM-L2 3B tint I had from from my S2+ triple
Nitecore TIP 2017 also cool white got the 2nd 219C high CRI 5000k from the late D4
Notes:
  • Broke the lens on the TIP, and have no idea how to replace it… I hope my local glass shop will have the tools do cut a circle this tiny. Scratched the reflector a little too, but it doesn’t appear to be affecting the beam
  • I never quite got the snapping effect people show and tell about reflowing emitters, I had to manually center the emitters and by consequence the MCPCBs spent more time on the pan than I’d like, the TIP MCPCB even started to peel of the positive pad and started smelling a little funny. Is this because there is less solder than needed? I never added any extra solder, I just used what was left over on the MCPCB and back of the emitter
  • So far these are 3 (2 from this post and the Tool AAA previously) cool white flashlights that I made into my preferred 5000k tint, 2 of them are now also high CRI. The 3 of them have neutral/warm white versions that where either unavailable, not included in a flash sale, or unknown to me at the time of purchase, so now I have flashlights that I like a lot more than I did before and washed away any semblance of regret I had from buying the cool white versions. I don’t think I would have ever tried such feats if not for everything I see and read shared here, so thanks BLF for that
Me too! I have other stuff “in the way”. I need to complete the big bookcase project first. Getting close to being done; stained the last pieces this morning.
Some pics of the earlier mentioned Osram Oslon square 4000K 96 CRI led replacements:
Smaller than XP but not really difficult to fit because the thermal pad has almost the same width.
Beautiful colors with 96 CRI
One in the Utorch UT01:
On the left: UT01 Osram, On the right: Nitecore TIP CRI
Left: UT01 XP-L CW, right: UT01 Osram
From the pictures the tint looks really good…
What’s the output on them? Around 300 lumens? Might still give some nice output in a triple or quad like that.
330 lumens at 1,57A
Today I completed my hardest build yet, an E2L with an LD-B4 and three sw57 219Bs.
Why the hardest? Well it’s harder to build with the LD-B4 compared to other drivers and also many things didn’t fit together and needed sanding.
The first snag I met was ILC-1 not fitting in the tailcap because it touched the retaining ring outer lip, quickly solved with some sanding.
Then the led pcb didn’t fit the head of the light so I had to sand that too paying attention not to get too close and causing shorts.
On the positive side, the fit after I was done was perfectly snug.
Then I needed to cut to size and solder the many wires, I guess it wasn’t all that difficult but certainly time consuming.
And when I was done and tried to do a runtime test in a jar of water, I found out the light wasn’t waterproof :person_facepalming: , I think it was because the glass is a little bit too small and didn’t make good contact with the front o-ring; after rebuilding the head paying attention to keep the glass centered it had no problem emptying a Sanyo GA while underwater. And here’s the runtime on 7.5A as proof :smiley: .
I’m going to see if I can find a glass that fits better but overall I’m pretty happy with the build, I like led4power’s stuff a lot and the E2L host too. The light looks good and the beam with the Carclo 10508 is beautifully floody too.
I had similar results even when using slightly lower current (7.5A), with stock thermal regulation it stepped down in about 10-15 seconds and I was unable to set the custom treshold high enough to make the regulation useful so I just disabled it too, but at least I haven’t had any driver shutdown because the fet is on the mcpcb.
Funny how the X6 can just chug 6A without problem for so long but this can’t go 15 seconds without throttling, didn’t expect to find this much of a difference but I guess there really is a big delta in thermal mass and heatsink surface between the two.
That’s strange, mine E2L with 219c on 7A and ld-b4 driver holds easily over a minute until thermal step-down.
If you use old solder of different kind it gets not a good compound, adding flux is a must to get better chance for a good reflow
BUT it is way better to clean off old solder completely and add new solder, it makes no difference if paste or wire used, additional flux can help
I prefer the S2 triple over the S2+ and the S2+ over the E2L. Simply because of the thermal mass. S2 Triple uses a good hunk of Copper.
Hard part for me to understand on my single Luxeon V S2+ is that the outside of the light does not feel hot enough to justify the thermal shutdown on highest possible settings. I have the Fet on driver and the thermal spacer installed and I am starting to wonder if its the driver getting too much heat from the emitter. I should try to remove the thermal driver spacer.
^ I hope you do not confuse mass with thermal mass. Per volume, copper and brass can store more heat, but per weight aluminium is better. So the mass of a flashlight can give a good feeling, but lightweight aluminium can store a surprising amount of heat too (I do not have the numbers at hand, I believe it was: copper has 2.5 times the weight of aluminium, but just 1.4 times the heat capacity).
That said, regardless of which metal is used, an S2+ triple with a spacer to compensate the short optic just has a lot more metal under the leds, and thus takes more time to heat up than a single led S2+ without extra spacer.
For those who having problem with setting custom OTP threshold, I just updated LD-x4 datasheet, you can download it from my page: LD-x4 datasheet
Since someone already asked me about OTP setting on LD-x4 driver over mail, I will just copy my answer here, which explains difference between LD-3 and LD-x4 OTP setting:
"But I will describe it here for now:
If you want to change OTP threshold, you should turn on the
flashlight on highest mode, wait until is around temperature that you
want to be new threshold,
and then enter into config. settings - next select EXT. OTP menu and
choose "CUSTOM" sub-menu. After that driver will set mode to max. and
flashlight would get hotter. When temperature is what you want to be
new threshold - fully turn the flashlight off. On the next turn on new
temp. threshold value will be stored.
The difference between LD-3 OTP setting and LD-x4 setting is that you
must "pre-heat" flashlight outside config. setting on LD-x4 drivers
and then set final value of OTP in config. setting; on LD-3 drivers it
was possible to set OTP directly in config. setting. Reason for that
is that LD-x4 has 30sec "no-press" turn-off timer while in config.
settings as safety feature,if you don't press switch for 30sec, driver
would shut down without storing anything, so if you don't "preheat"
flashlight in normal mode, there is a good chance , your flashlight
would not get hot enough during those 30sec.
If you have problem with setting desired OTP level, please try to
follow upper procedure:
"Pre-heat" light in normal mode -> enter into config. settings -> go
to EXT. OTP menu ->CUSTOM sub.menu ->driver would go to max. mode ->
wait until temp. is hot enough (should be in <30sec!)-> turn the
flashlight off ->turn the flashlight ON ->DONE "
Today I built up a Jaxman E2L host, using a BLF-A6 (FET+7135) driver and 4000K Luxeon V leds on the new led4power 4040 triple board. In fact, I did this build to check some real world performance of this new board type.
Special about the new boards that he sells now is that they are not DTP, so none of the solder pads are electrically connected to the core, but the dielectric layer is so thin (it is just an anodisation layer on the aluminium core) that the board should perform just as well as a DTP board.
I won a number of these boards in a small quiz that l4p held to promote them, and I happened to be online () just as he posted it so I was the first with a correct answer. And I even received some bonus boards, thanks!
The 4040 triple board is exactly 20mm diameter, as it should be, but the E2L host annoyingssely just allows 19.5mm, so it needed some slight shaving and that can only by just be done while still clearing the circuitry on top. But I do not know how I would have done that without my disc sander. The shaved board:
Reflowing the leds was no problem, and since I'm not using the FET-option on the ledboard, the ledminus wire was soldered on the FET-drain pad.
The leds fit tight but nicely under the Carclo optic.
Both springs were bypassed with 20AWG wire, the rather long tail spring replaced with a shorter one to make a 18350 cell fit less tight in shorty form. I replaced the switch because I melted the stock one during the spring soldering. The BLF-A6 driver received the 'voltage spike-fix' (not really needed for this driver, an OCD-thingy), a 680 Ohm bleeder resistor and 20AWG ledwires. A lighted tail is planned at a later moment.
The only real problem was soldering the ledwires on the ledboard. It was immediately clear that this dielectric layer is something special because even though the pads and wires were pre-tinned, even my super-hot 80W solder iron (admittedly with old rotten tip) struggled to get the solder hot enough to join, the heat was just sucked away to the core: I had multiple cold solder joints (the wires just sprung loose when the light was on max for a few seconds) before I finally got good connections. I ordered a new tip for the solder iron to get better work done next time.
So the low thermal resistance dielectric layer which is the key quality of these boards, has a nasty side-effect: not just under the led but also under the solder pads the heat is sucked away to the core with record speed.
So I got the light done and did some measurements. I also measured my modded Emisar D4 with Luxeon V leds again for comparison, even though it is a bit different light, and it has 4 Luxeon V leds compared to 3 for the E2L. Ignoring other differences, having 3 leds the E2L could theoretically put out 75% of the D4. But probably a bit less because the E2L uses a clicky switch and a bit lower quality FET, both adding some extra resistance. I measured output on a fully charged 30Q battery, at 3 seconds (first stable reading of my luxmeter after an output change), 12 seconds (first stepdown of the D4) and 30 seconds for the E2L.
D4:
3 seconds: 5200 lumen
12 seconds: 4850 lumen
E2L:
3 seconds: 3650 lumen
12 seconds: 3450 lumen
30 seconds: 3170 lumen
The D4 even performs better than when I measured it first a few weeks ago. It looses 7% output in 12 seconds. The E2L looses just 5.5% in 12 seconds, already a good sign for the ledboard. 3170 lumen at 30 seconds is also very good for this very small triple. Only the output (at 12 seconds) is not 75% of the D4 but 71%, a small difference that can easily be attributed to FET and switch, I do not blame the ledboard. The longest runtime that I checked on turbo was 40 seconds, which is the fixed stepdown time for the BLF-A6 driver. No angry blue light and no damage could be observed.
I give this board a very good rating for performance, when doing this mod I did not not see any worse performance compared to a DTP board (better??). The only challenge is getting the ledwires soldered, a problem inherent to the good thermal properties of these boards.
Thanks for your test and thoughts on these mcpcbs Jos .
Also , you should get some Sony VTC5A batteries if you haven’t any , they give a bit more power for these quads and triples :wink:
