I hate trying to open glued lights… but I always try it for some reason…
You often have to use heat, I just use an old grill lighter and heat up the head as much as I can. Try to guess where the threads are and heat that exact spot… Then I try to open it while its hot…
Lately I have been using the bottom side of an old, thick mouse pad. The rubber is very sticky, and prevents me from getting burned…
Sometimes I STILL cant get it open, by then I’m so frustrated I just crank on it with wrenches, which ruins the finish…
Gains would be a bonus and not my main goal. I’d like to convert whatever lights I can over to neutral white. I clamped the LD10 in a bench vice between rubber material. It was cut from a home depot thin floor mat. I wrapped the same material around the head and used an adjustable wrench that has teeth. Came off pretty easy. My LD01 was quite easy also. So far I have yet to get the PD35 and four sevens Quark Pro apart. Those things are stuck on pretty good. Even tried heat as other members have suggested but no go.
i’ve already ruined my my four sevens light. it was my first attempt at opening a light and i tried bicycle tubing but the teeth from my wrench broke through it. ah well. no turning back now. i cant stand the tint on this light.
It’s been years since I’ve opened a Fenix light but I remember that I’ve put the head in 3 or 4 ziplock bags, each time removing as much air as possible, then boil it for a good 10 minutes. When you take it out, act as fast as possible, put it in a vise (with a lot of rubber protection) and use a strap wrench.
Almost all Fenix glued. Simple heating using heat gun will remove it easily. I opened 8 Fenix E05 with success.
Heat the head of the flashlight and measure the temp whenever possible. In my case I kept the temp below 120C because E05 uses TIR PMMA lens. LD10 seems to use reflector, I don’t know.
Then after you’re sure the entire head is evenly heated to ~100 - 120C use circlip plier or tweezer (there are two fastening holes) to turn the driver anti-clockwise. Don’t use brute force, the driver board is soft. If you can’t get it in the first try, try to heat it longer (not hotter). The thread locker need sometimes to soften, and when the whole head cools it will hardens back.
At it’s current level swapping to 219C or XPL won’t gain you measurable (by eyes) output, but you should get better runtime. XPG R5 has smaller die, swapping to XPL/XPL2 HD will give you almost almost twice bigger hotspot. Newer LEDs have lower voltage, this should give you slightly better regulated runtime. And the lumen/watt efficiency will be improved because lower output voltage is easier for the boost driver used in this light.
Along the same topic. I managed to get my PD35 open and it has a copper 15dia sinkpad. I was thinking of getting an LED with noctigon before but maybe i should attempt a reflow? Or is the noctigon mcpcb superior?
Noctigon is indeed superior. So far it’s the best DTP board. The only thing from Noctigon which I don’t like is the red color.
If you’re just swapping the LED while keeping the rest as is, there’s no point switching to Noctigon. Most Fenix DTP boards are already good enough, even for mild hot rodding. Reflowing is easy and can be done easily with many household stuffs.
Thanks for the feedback. I don’t mind the red as the insulator will block it. I’ve never reflowed so maybe a good time to try. Unless I go with XP-L. I was just on fenix’s website and latest emitter is XP-L. I know very little about them. It is just farther throwing but same hot spot as XM-L2 ?
I’ve taken apart couple fenix lights and a~7 year old 4Sevens. I use a small butane torch lighter and heat up the bezel evenly all around, and then an ice cube around the perimeter to anneal the thread lock adhesive. I then use strap wrenches combined with a small bench vise, and crank the snot out of it to get it to unscrew.
This 4Sevens had a green tinted XPG2 that I replaced with a neutral XP-G3. The mod went very well actually, despite its age I still use this light all the time. Love the sub-lumen firefly mode, despite being brighter with the new XPG3 its still very useful for preserving night adapted vision.
Thanks for tip. I used heat and vice but no ice. Didnt have strap wrenches. I damaged the ano but once i did that i didnt care anymore. Finally got it off.
Thanks for that. Interesting Fenix use a 10mm board for the LD10 I figure it’d be larger and have the smaller boards reserved for their AAA line like the E05 or LD01.
Yeah kinda odd but i guess that screw is in the way. Not sure what its there for. It is also on the quark so something to do with the tightening of the bezel to get to turbo im guessing? Would love to use bigger mcpcb. Do AA llights get hot enough to matter??
So i finally swapped the emitter over to XP-L2 V5 last night. first attempt did not go well as the light would only stay in one mode, the highest mode. i was probably due to the wires touching the sinkpad? didnt help that the wires were really short and i couldn’t get the driver out to resolder longer ones. so i resoldered again making sure it would only touch the pads and it worked but for some reason in the high setting it dims randomly. still bright but i could tell it would dim and brighten up randomly. lower modes worked fine. what could cause this?
Yes they were soldered correctly. It kept acting up. I tried resoldering but the dome fell off so its destroyed now. Dissappointed with myself. Pretty sure i damaged it when reflowing.
