Thank you Toykeeper! I just used the .c file for the tail-light firmware to practice making a hex file and it worked when flashed to the nanjg driver. Wonderful! I like the bi-level blinky. It should make a good tail light. Thanks again…. fun while learning!
It was very hard to break my UT02 too. It was soaked in thread lock. it needed heat, and some heavy equipment to break it. I wrapped the head with very big cable and the tube with leather. The tube bent a little oval so then the Liitokala black 26650 wont fit. So I needed tu put in the wise again to press it back to circle.
This was ordered about half year ago but it is the black led centering ring version. The tube now circle and the 26650s fit again. The pipe wrench wasn’t enough length with my force so that is why I used the big pressing tool tightened to the tube. The only damage I have after it is that little scratch on the tube block knurling edge:
OK just checked, mine is white centering ring. And NO GLUE on the tube. Phew. Will try the resistor mod on it tomorrow.
Read a lot about these and saw a couple vids, but I was suprised how short the light was when I opened the box. I like it a lot and think it has potential beyond the resistor mod.
Yes the MCPCB is DTP. It wasn’t the first time I removed the bezel and in the led solder I found some air bobbles so it was not perfect.
My stock numbers:
2,2A at battery
897 lumens
74800 cd
After R100 resistor mod I got these numbers:
3,65A at battery
1250 lumens
103000 cd
You can see my google tables with beamshots and compare a lot of other lights.
:heart_eyes: that test board, with the little styrofoam ball to diffuse the led :party:
(it is how I made my first, and last, working radio back in the seventies, with a simple ferrite rod AM receiver and two-step amplifier . After condensing the circuit on a proper circuit board I never got it to work again).
Great that you got the flashing stuff to work. When I retire in 17 years from now and have all the time in the world just before I die, I will pick up these skills as well.
Worked on the UT02 6500K today.
20AWG wires and bypassed springs. R100 resistor mod and polished the SW cover after it got scratched taking it apart. SW also wasn’t very smooth but it is now.
Impressive light for $30. I liked seeing the Genuine TP5000 chip on the charge board. Nicely made over all too. Killer pencil beam and I am pretty happy with what they call 6500K, no blue IMO. I got 3.78A at the tail on DMM.
Zero back feed to the charge port so I am going to integrate a magnetic port adapter like my M3 Clone.
The EC21 that I got open yesterday, tonight has received a Nichia 219C R9050 sm4070e led. The output did not even really suffer from it, measured at 30 seconds, the output went from 445 lumen to 375 lumen. So just a 15% loss for a dramatic tint and colour rendering improvement. (But the EC21 was never about output anyway, but about usefulness and runtime).
This is my first mod with this exclusive led (just a handful 219C’s in this specific tint area were obtained and sold by clemence) and it is different than I expected. I expected a quite rosy tint on top of the slight yellow-ness that 4000K leds have, instead it is less yellow than my 4000K R9080 E2L mod, and not rosy at all, it looks very neutral white to me.
(it may be this particular led, the sm4070e tint covers a fairly large area , although it is all under the BBL, but this led may just be close to it)
All in all, a super nice neutral tint
( ^ this pic suggests a load of red but the camera did not pick up the real tint very well. Btw, even the camera sees absolutely no PWM)
