I would think the C8F triple reflector would be pretty close to the Q8. My guess would be a little bigger hotspot, so not as good throw, but still good and much brighter spill than a TIR. Here is a video of the C8F xpl to see the beam. Video by DB Custom.
For the record, in my testing I always got the same or slightly better throw from TIR optics vs reflectors of the same size.
Assuming the TIR was properly match to the LED is use that is.
How was the spill brightness? I was really hoping to find a TIR setup that could come close to a reflector as far as beam proportions, hot spot size to spill brightness.
EDIT, I changed post 487 to better reflect what I was trying to say.
TIR’s give you a larger hotspot then a reflector but that doesn’t mean less throw, they are simply better at collimating the beam.
I have dozens of TIR’s laying around here and I have tried all sorts of combos. The spill is usually better then you would expect unless the optic you got is specifically designed to not have any spill.
Unlike reflectors TIR’s are designed for a bunch of use cases and a whole lot more then size factors into what they give you.
In my case I did a lot of testing for my EDC tube light.
As a rule, the TIR gave more spill close to the hotspot, then there was a small area near the edge of the reflector beam where the reflector spill was slightly brighter. After the reflector spill cutoff though, the TIR spill kept going, just getting dimmer.
I prefer TIR optics in most cases, the beam is more pleasing.
Also someone mentioned frosted TIR, this second image is sorta what you will get if you diffuse it:
Almost no hotspot and very nice spill, great for close range use.
How about a really tiny lamp, using one AA cell or a 14500.
Similar to a UTorch 01, but with a better interface, and maybe a little more power…?
I’d like a small, elegant, titanium light. BLF style.
Seeing how Astrolux sells their TI3A for $16 I can’t help but think that a much better BLF light has to be doable for $25 (preorder price). And I want one.
So:
- 10440 powered
- e-switch, BLF UI
- FET driver (FET+1 would be better, but if it complicates the build it’s not worth it)
- CRI90 219c
- clip
- locator light
I think that LED locator would be cheaper than tritium. And if connected to the driver it could act as an indicator as well. Or with RGB led the colour could be configurable to best suit the garment.
I’d like it the most with the switch in the tail, but I’m not sure if doing the FW3A thing is feasible in a titanium light (I guess with Al internal tubing - yes). It would make the light thicker though.
Thoughts?
I’d like another light of this style.
18650 with 16 Yuji VTC-5730 LEDs. No overcurrent to maintain CRI 9790, ~400 OTF lumens.
A double-tube 10440 light doesn’t make much sense because it would lose the advantage of being thin. It’s also difficult to fit a complicated driver into something that size. But perhaps a 16340 light could work? It seems like it’d be a lot easier, at least.
I still want a BLF version of the Olight S-Mini.
I also still want a small BLF 14500 light. Could be like a smaller FW3A, could be like the brass AA clicky.
16340 or 14500 would work great in a woman’s purse, but not so well in a jacket’s inner pocket….too thick.
But I wonder what is the factor limiting minimum tube thickness? Size of PCB contacts? Strength necessary when joining them into one?
I have been looking for a good quality mid-size thrower for a while now and I just thought of bringing it up here. What I have in mind is a 3 or 4 cell Q8 style battery tube with a 2.8 to 3” head. Throw in good heat management, an efficient driver and Narsil or other great UI and BLF would have a nice light that would fill a hole in my line-up.
How would that differ from the Q8?
Single reflector with a 35 HI or other throwy led. In my mind that was implied, but my mind is not always clear.
I’m sure there are lights like that already out there, they just need a driver swap. Maybe a Haikelite MT07S or Klarus G35 with one of Lexels drivers.
When his boost driver comes out you could build an even smaller thrower using a 26650. Like the Utorch uto2 which is very cheap.
Don’t wait for BLF to make it. Make it yourself! Lol
I have a MK35 that I might upgrade with a GT/Narsil driver and a 4000K or 4500K led swap. Wish me luck, I’m goin in! The 4000K in the GT has gotten me hooked. I just bought a MX30L4Cvn with XPL Hi 4000K which is now my favorite balanced light.
. GOOD LUCK!!! . :+1: .
Extremely compact 21700 flashlight powerbank.
- USB type C
- Astrolux 22 mm quad lens
- Samsung LH351D, XP-L HI variants
- Texas Commander / LD4 style driver with FET on MCPCB, regulating the light all the way to peak output. Might place other components on MCPCB too it that’s needed to save space.
- Ramping UI
Initial, somewhat incorrect sketch:
I drew it without glass protecting the lens. I’m not sure it that’s a great choice especially that bezel blocks some light, just like it is with S2+ triples.
And there is no place to put threads between head and body tube, so this is a unibody light with press-fit driver. Not sure if that’s feasible with USB and maybe a button on the other side. You can remove the driver by poking it from the optic side.
Why did I say “maybe a button on the other side”? Because I’m wondering if a button assembly plugged into USB slot wouldn’t be a good idea.
It seems that “extremely compact for its battery type” is a very common desire. In general, I’d like to see more lights which are barely bigger than the fuel tank.
Unusually, I’d like to suggest not a from-scratch project but a special edition of existing light.
DQG Spy Ti which has low-bin XP-G2 replaced with Samsung LH351D. Warm CRI90. That’s it.
Well, extra points for shortening it to 10150 or 10160.
ADDED:
Or AR coated lens.
Or glow o-ring.
OK. There are a few things that could be done better.
But nevertheless this is a good light that’s extremely close to being a great light.
I’ve had the concept in my head for a long time…I made some drawings before…but just couldn’t make it right.
Now I managed to put all the pieces together.
Welcome A7, a pocket hotrod.
Features:
- 7 LEDs, XP sized. Dedomed Samsung LH351D would be my pick.
- Though XP-L2 would turn it to a 5-second light
- 21700
- Texas-Commander / LD4 style driver integrated with the LED MCPCB regulating the light to 10+ amps. With Turbo above that.
- Unibody
- E-switch
- DQG style tail cap
Here’s the drawing, next to a rough outline of Emisar D4.
Inspirations (alphabetically):
DB Custom’s Titanium X6, DQG Tiny 18650, DQG Tiny 26650, Emisar D4, Led4Power’s works, Zebralights
