Same for other threads with your pictures.
Already fix some. Will do the rest (hopefully) after finished with packing tonight
- Clemence
E21A CCT & tint shots:
With faceted TIR lens, the 4 LEDās was very well mixed
The quadtrix under spherical lens. Itās just a bad aspheric lens from a cheap zoomie pull, please donāt complain about the beam.
- Clemence
what is āALLā ?
what is āALLā ?
sm203 + sm303 + sm403 + sm503 all at once
Check this thread: New VirEnce MCPCB for E17/E21/119/144/233U
Aha, i see.
There really is a sm503 R9080 clemence? (2nd from the right)
Yes, sm303 and sm503 R9080 have been in the store for almost a year. You can also check my āherbalā tint shot
- Clemence
- Clemence
I was thinking of the 219B/C variety, hahaha, sorry. Itās available in the store all right, https://www.virence.com/blank-rwrlr/nvswe21at.
Those E21 Nichias, I understand that dedicated boards are on their way, but I wonder if these LEDs have been used with existing boards? I am really interested in domeless high cri LEDs, the 083b being my grail at the moment.
Yes they have. Scroll up and then click this link to see almost anything you need to know about the development of the boards
Hi guys, I'm going to make custom copper round CDTP MCPCB for a single Nichia 144A. This new board will have several features: Non insulated for superior heatsinking with direct soldering OR Insulated with options to use either thermal adhesives or pad High reflectance white masking ink High temperature masking ink (lead free/direct soldering friendly - less yellowing) Hopefully will performs same or better than my previous 30mm x 30mm VirEnce board (will post the test result ā¦
- Clemence
ma tumba:Those E21 Nichias, I understand that dedicated boards are on their way, but I wonder if these LEDs have been used with existing boards? I am really interested in domeless high cri LEDs, the 083b being my grail at the moment.
New VirEnce MCPCB for E17/E21/119/144/233U- Clemence
Thanks for the reference! I had read that thread thoroughly. Just was wondering if those LEDs had been used in flashlights before. Maybe with the boards used for 119s?
clemence: ma tumba:Those E21 Nichias, I understand that dedicated boards are on their way, but I wonder if these LEDs have been used with existing boards? I am really interested in domeless high cri LEDs, the 083b being my grail at the moment.
Ah I see. I assumed you asked about existing VirEnce boards. AFAIK, Iāve never seen any flashlights made using this LED as OEM. The only flashlight I knew was Jensen567ās P60. Maybe heāll be kind enough to share his builds to us here.
And as for the 119 boards, Djozz tested these LEDs with his 119 board. But the gap is too wide for it to work properly. You need 0,2mm gap with E21A/E17A. Nichia E17A/E21A series (April 19th: updated with output tests in the OP)
- Clemence
Even mine is not really a flashlight, just a beam tester. I need a 17mm boost driver to actually run it in a flashlight since I setup the emitters in 2S2P configuration. But this does at least show the quadtrix configuration gives a very nice beam without any donut hole, even just using a simple P60 OP reflector. I havenāt tried SMO but I suspect there would be a donut. I will be building lots more with E21A once I get some more components.
Does not look like a multiple core LED at all. Thanks for sharing, good to know!
E21 has the same footprint as Cree XQ series.
If you can find a XQ board, you can put a E21 on it without any positioning problems.
I see the custom Armyteks listed on the site now. Does this mean the boards are coming in soon?
The boards will be shipped by this week or next week according to the latest factory update. The Armyteks still needs fine tuning especially for correct optics selection and reliable fastening method.
- Clemence
Update 180111:
MCPCB shipped to Indonesia
- Clemence
Great news!
