Ah Shoulda mentioned it earlier. Look for those using XPL HI. More throw with reasonable output. Maybe can contact RMM of mountain electronics to custom build one for you
Your own firmware modes and output
I did list the 3 things I am looking for in my first post
Emisar D1? Has a slightly larger head but you get better throw, side switch, and a modern UI.
Ha! Missed the uniform factor part. Sorry!
All links are not aff.
Fitorch P26R XHP70.2 3600Lumens FCD Rechargeable Portable LED Flashlight +26650
https://banggood.app.link/0EBXrGygcJ
Can use 18650 with a sleeve.
Jetbeam TH15 XHP E2 1450Lumens Ultra-High Performance Tactical Outdoor LED Flashlight
https://banggood.app.link/myMZ8xDgcJ
Might appeal to you. Can get discount code from M4DM4X.
JETbeam TH20 XHP70.2 3450Lumens High Performance Tactical Flashlight
https://banggood.app.link/vHGUuzJgcJ
Not exactly budget either. Can get code from M4DM4X as well. But seems like a contender.
Klarus XT2CR XHP35 HD E4 1600LM Rechargeable Tactical LED Flashlight+18650
https://banggood.app.link/gj7Q9YOgcJ
M4DM4X can help u out.
Hope those help
Thank you! These are good options.
Are there any downsides of the options that I listed above? I realize that they are not “budget” brands and may not be fav of the folks here but the Emisar, Klarus etc. are $100+ as well.
you can look at the BLF A6 XPL
cheap and very good. i have one :sunglasses:
Sofirn has also some cheap but very good ones in kit with battery and charger
You might want to check out the Imalent DN35 on gearbest, they have it on sale for 48.99 that fits nice in the hand and it has USB charging.
Unless you want to spend $100 or more ……. (Wrathbringer27 linked some nice lights, that Fitorch P26R is something I would like, except the $$:money_mouth_face:
For something almost tube style, and with good throw, I will second this………
Normally sells for around $40.
https://intl-outdoor.com/emisar-d1-mini-thrower-p-922.html
or when he gets more in stock
http://www.mtnelectronics.com/index.php?route=product/product&product_id=876
For a pocket thrower on a reasonable budget, I think it will be hard to beat.
…General info that may be helpful with your selection……….there are exceptions, but they are few.
1) Throw is mostly tied to reflector size (bigger = longer throw), and a LED w/high surface brightness. Tube lights will suffer here due to size restrictions.
2) A de-domed or HI version of a given LED will throw better.
3) large LEDs (XHP50, XHP70, MT-G2) are generally better at flood, though they can have decent throw in a large reflector
XHP35 is the thrower of the XHP line
Be prepared to end up with multiple lights. Once you have the batteries and charger it becomes a slippery slope.
The emisar isn’t $100+ but the some Klarus models are. Klarus so far hasn’t had any bad rep here except for some output issues. Eagtac is just really expensive but you are paying the premium for quality. Convoy is a community fav brand and nitecore is okay. Lumintop is also not bad. In fact they’re the manufacturer of our giggles
Convoy S2+
Convoy S9
How important is user interface? You haven’t mentioned anything on the subject. Some people absolutely hate having to cycle through blinky modes and do not want to replace driver or firmware, others don’t mind or even like blinkies.
Another light you might want to look at is the Convoy S9. I don’t have one yet (they are on the way) but appears to be a nice light with micro USB charging port. Convoy S9
I think you would be happy with one of the Convoy flashlights from the official Convoy store: convoy.aliexpress.com.
There are plenty to styles to choose from, including different tints and mode options.
I’ve purchased from Simon (the owner of Convoy) numerous times and have never been disappointed. He sells high quality flashlights and parts for very reasonable costs.
And if you don’t see exactly what you want, you can ask Simon to make something custom.
I have ordered a Convoy S2, Panasonic batteries and a charger. Figured S2 is well regarding in this community and the cost is low enough to get familiar with the modern flashlights and understand various terms. I may order a Convoy S9 as well once I receive all the items.
I had been looking into Convoy for some time and one of the reasons I started this thread was 2k or higher lumen range by Nitecore and Eagletac in same size footprint as S2+.
Regarding the question of UI, I don’t mind clicking through for various modes as long as I can lowest lows and highest highs.
Thanks for all the suggestions!
As you described, Sofirn SF32 is a good choice, portable and 18650 battery.
I like the MH12GT better since it’s more compact.
The USB charging is very useful because you don’t need to carry an 18650 charger around, and not even open the flashlight.
Just plug it in with the same cable you probably use with your phone.
MH12GT looks pretty interesting based on specs. Are you folks taking a risk buying new products/new vendors to see what works and what doesn’t? Of course discussions like these and collective wisdom of this forum helps to rule out a lot of bad stuff (e.g. my recent purchase of Ultrafire from ebay for $5 which claimed 6K lumens).
I haven’t seen much discussion about DX3B Pro on this forum. 2,480 lumens and beam distance of 165 yards or 1,870 lumens and beam distance of 280 yards but smaller footprint. Is there something fishy with their specs?
thx
DX3B Pro seems to be OK, a bit less lumens than advertized
As someone pointed out, it is a slipper slope. Once you have the charger and few battery, it is a dangerous thing. A light for $10 here, another one for $15 here and soon you know, I will end up on “Hoarders” show
I have some good suggestions to look more into. As far as battery goes, are folks still liking 18650 over others? Are there any tradeoffs to another size in terms of size versus performance?
LiitoKala can cover both Lithium and NiMH batteries
Once you have that, makes sense to go for Convoy S2/S2+
This is not hoarding
LiitoKala charger and two S2+ are on the slow boat from China…
Looking forward to use them.
