LUMINTOP GEEK ✺ Rechargeable Multifunction Flashlight
The LUMINTOP Geek LED Keychain Flashlight born and designed for the enthusiastic pursuit of ultimate craft and superior quality, which combine the multiple technology and functions in an extremely compact size. Aluminum alloy with CNC integrated processing creates a solid and reliable body. Key shape design, compact in size allows one hand easily control. Dual lights lighting with a max 350 lumens output, provides more lighting manners options in your camping, walking, reading or EDC gears etc. Built-in lithium polymer battery and Micro USB charging design allow easy to charge the light without a charger. Battery and charging indicator on the side shows the approximately battery percentage clearly in green, blue or red. Dual switches operation, lock-out function, big key holder, IPX-6 waterproof classification, all these make Geek a masterpiece in the industry.
Features
- Utilizes Cree XP - L HD LED for front light, and high CRI Nichia LEDs for side light with a lifespan of 50000 hours
- 4 output levels plus Strobe, SOS and Beacon for front light, two modes set for side light to meet your luminous needs in different situations
- Made of aircraft aluminum alloy with CNC integrated processing, 1.5m impact resistance
- Autokey structure design, compact and multifunctional
- Dual switch for one hand operation
- Micro USB rechargeable with charging indicator, you don't need to buy batteries
- Built-in 3.7V 530mAh Li-polymer battery, max runtime up to 43h
- Battery level and low power indicator to protect your flashlight from hurts
- Lock-out function to prevent accidentals activations
- Waterproof IP-X6, suitable for rainy days
Specification
- Emitters: Cree XP-L HD,Nichia
- Emitters Quantity: 6
- Luminous Flux: high / strobe / SOS / beacon 350LM; mid 125LM; low 25LM; moonlight 1LM
- Luminous Intensity: 1225cd
- Color Temperature: 7000K + 4000K
- Feature: Compact,Lightweight,Lock-out Function,Portable,Waterproof
- Battery Type: Lithium Polymer
- Battery Quantity: 1
- Battery Included or Not: Yes
- Rechargeable: Yes
- Waterproof Standard: IPX-6 Standard Waterproof
- LED Lifespan: 50000h
- Working Voltage: 3.7V
- Beam Distance: 50-100m
- Impact Resistance: 1.5M
- Product weight: 0.0510 kg
- Product size (L x W x H): 6.00 x 3.60 x 1.60 cm / 2.36 x 1.42 x 0.63 inches
- Package Contents: 1 x LUMINTOP Geek LED Flashlight, 1 x English User Manual, 1 x Lanyard
If you are interested, notify in this thread (not in PM)
My main thread: GearBEST.com Coupon Codes&Flashsales
