Not really. Even the 30Q can only do 15A continuous and 20A in pulses according to HKJ. They tend to get pretty hot. Plus you get a lot of voltage sag. More batteries means less voltage sag and more lumens.
I think the Imalent DX80 has about the right battery to output levels. 8 x xhp70.2, 32,000 lumen and 8 x 18650. That’s 4,000 lumen at 5A from each emitter. It works pretty well.
Once you start going over that, like 11 of the xhp70.2 at 5A each, you need 12 cells. If you have 11 at 8A each, then 16 cells. This would be a practical use light I’m talking about. Not a 5 second wonder.
Imagine the GT with its 5.5” diameter head and a copper insert to load up 11 or 12 xhp70.2 using small reflectors. Then a special driver that can handle the power. It would probably be 2 drivers combined or stacked. That would be an awesome light. Now that the GT is shipping, I wonder who will be the first to mod it?
I think DBCUSTOM was talking about running 4 x xhp70.2 with each one in a C8 reflector. That would be cool.
There are batteries that can handle 20-25 amps , like VTC5A .
Mf-03 will probably take 8*18650 , from what i understand from the pics . If there are 2 carriers , in parallel , but each one is in 2S2P config , max current with 15amp batteries like 30q will be ~60amps .
If we forget that we have an xhp35 , and assume we have 8*xhp70.2 P2 , max output for the available current would be about 5900*8= 47.2k lumens . Not bad :innocent:
i hear you have went on a vacation ?
hope your enjoying yourself…
they gave you fair warning, and you still got banned after that ?
tell me again who’s ignorant ?
lol…man oh man….unreal…
enjoy…
Be careful making it too floody that annoys people when the lights shining into their houses or cars. Unless using it in not so populated area, else it will sure annoy neighbors.
It is cool to us, but annoying to others especially when the lights flood so widely.
What is real and what is a render on these pictures?
The flashlights can not lay over each other in that way. The Flags and the Cap are not real.
The desk and the room are real and perhaps the hand and the green flashlight.
