Unfortunately, I do not personally own a DRY, so cannot confirm that for you.
However, this cell fit all my lights - width wise - even those that are quite narrow, so the width shouldn't be an issue. On the other hand, it is quite long, and there is only a limited amount of length available in the DRY's battery carrier, so it would be best to check the available length in the carrier before settling on a battery to use.
Ok, thank you. I know Chicago X is selling some washers for the DRY, right? Anyway I have already ordered this TF 3000mah flame last week and waiting for it coming. I will see how it goes.
Today I received 4pcs from Manafont.
Resting voltages at arrival were: 3,83V, 3,84V, 3,85V and 3,86Volts.
Charged up to 4,17V with Xtar, now discharging to 2,7V with Imax B6 @ 1Amp.
Will give some capacities for comparison later in the evening.
I just received 2x 2-packs of these Trustfire 3000mAH 18650 cells from Manafont. They seem like legitimate cells and not fakes, if anyone is concerned. All cells appear to be very well built. The have very good quality, well-printed wrappers on gold-hologram foil, and have the Trustfire hologram sticker on the outside of the overwrap. Unfortunately, I don't have a way to test cell capacity, but they look like the legitimate product.
Have you or anyone else tested the protection circuit? I already had an issue with one of those and most of my other "thunderflames" are in multi-cell flashlights, so I am a bit worried...
Wow 2 weeks and still not finished discharging... sure you set them at 1A? maybe accidentally set 1mA? JK
Anyhow since some others are expecting result, I also got a couple of TF3000 Flame from Manafont recently and Imax B6 gave reading of 2400++ mAh (don't remember exact) at 1A, discharge to 3V.
After discharge to 3V, I let them rest a while, pop the discharged cell into the 3-mode Ultrafire Manafont drop-in and whoa... still lots of light. Tail cap read at 1.4A. Quite amazing. The battery still have some good juice left after discharging to 3V. The current seem to be stable too, dropping only a bit at slow rate.
I didn't quite test the discharge down to 2.7V BUT from the feel of it, even at 3v and the way it supplies current, it should still have 100-200 mAh left. I believe you could get 2500+ mAh from these cells. Well, at least from this batch.
I shorted mine on the 10A setting of my DMM, 5.6A for a sec, after that 0.0. Shut down in UF980L on High (Direct Drive) after about 30min of a buttload of light, 20min usable light and 15min of firefly.
Just to mention that I got some of these cells from DX and they are now selling the same old fake 2400 (not the good 2400 flame) wrapped in this new shell. All of the 4 I've tested are actually 2000mah at 1A discharge. Still decent quality for the price, but definitely not as good as the ones tested at the beginning of this thread.
