[PART 1] Official BLF GT Group Buy thread. Group buy officially closed! Lights shipping.
Does the entire head fit inside the light box?
Welcome 18000bph! :+1: Come on in, the waters fine :stuck_out_tongue: :smiley:
I’ve been giving this some thought. A few miles away there is a straight road that runs between two huge cornfields. There are buildings at the end of it. But I never “clocked” the distance. I just checked Google maps and it’s over a mile long.
The light box fitment is not ideal, my opening is 4.25” so the GT actually mates up to the light box. This moves the lens back away from the shelf a light normally sits on. Shouldn’t make much difference to a long distance thrower. I can check my DBC-06.7 build and see if the numbers are different at the same position relative to the box.
–25ºF? Insane! Air should be nice and clear, I use Google Earth to locate a clear space, when I tested the TN42 I found an area across our lake that worked well. We have room on a couple of rural roads nearby as well, will probably use the roads for this light as it’s a lot closer and easier to navigate, I had to leave my wife on one side of the lake with the video camera and tripod and find my way around to a boat loading ramp on the other side, didn’t like leaving her over there. She was at a Marina, about 70 yds from the lighted parking area, but still. On that occasion I cleared it first with the local Law Enforcement, just so they’d know if they got a call…. they’d already know what was going on. Also told them I planned to “sight it in” using a laser, so it was all on the up and up.
I have a double clamp that I use for this, clamps on my main vertical of the tripod just under the camera mount, then the second clamp holds the light. Figured if I clamped a laser in then set up the tripod so the laser was on target across the lake, removing the laser and replacing it with the light would also have the light zero’d in on the 8 1/2 x 11 sheet of paper that was the target. Worked pretty nicely.
(to clarify, I had 2 tripods with my wife… the target on one and her camera on another. Then I used a 3rd tripod at my end. :wink: )
+1 for me. Looks awesome guys.
Dale, yes, –25 without the windchill figured in. We’ve had colder in years past. I’ve seen it below –30.
My brother had a good idea, throw a bunch of water into the air to see if I could make snow. I bet I could if I put the water into an agricultural sprayer. But enough of that; now it’s back to our regular scheduled programming.
I heard at –25 like we have been seeing, if you boil water, the steam will turn to snow
I have seen our moist air from inside spill outdoors and ice crystals form out of that.
That driver is so nicely done, really looks premium :slight_smile:
CrashOne, strange that you should mention that. As I was scrolling down and before I got to your comment I noticed the same thing also. It caused me to pause. It just caught my eye. I know nothing about those boards, but it just looks very professionally laid out. Well done TA and DEL! It really is a thing of industrial beauty.
Sorry, I know this is off topic… but it is for science. :wink:
Del gets full credit for the driver, I was busy when the driver was designed and unable to help at all.
With all the GT's getting lit up, the spring thaw could come early for you folks in the colder climates
It’s cold where I am, and the GT really draws the heat from my hands.
I managed to slip a length of bicycle inner tube onto the body of my GT.
The 20 x 2.35 tube is a very tight fit, but I’m pleased with the result. I used a heat gun to soften the tube as I wrangled it on.
I’ll be showing off the GT at a party tonight, and decided to use the vinyl cutter to embellish the front end a bit. :partying_face:
Would you be willing to sell me a couple of them fancy stickers?
I like the thought of that
Added
I did not consider your location. I may be asking a bit much. LOL
Another thought, maybe engraving the light would workout better?
Added
I bet somewhere out there, there is a Neoprene sleeve that would fit these monsters
I wonder what the temp’ was for that.
There’s got to be a way to do it. Heck, the ski areas do it. But they use compressed air to both make fine droplets and chill the water. Maybe for us, out of a paint spray gun. I’m just brain storming since I don’t have a spray gun.
goshdogit, yes aluminum sucks the heat right out of anything hot when it’s cold out. Even with gloves I don’t like to handle the aluminum feed scoop to refill the poultry feeders.
Just played around with the moonlight settings and can report that:
Level 1: no light detected even in complete darkness
Level 2: only barely lights up all 4 dies (one is visibly dimmer than the others), similar to level 1 with my Q8
Level 3: which is the default, is a usable low moon light and probably what I will leave it at
goshdogit I love that sticker! I’m gonna blame you if I end up getting a vinyl cutter
Please add me to the list
is the strobe full throttle on this light ?
