[PART 1] Official BLF GT Group Buy thread. Group buy officially closed! Lights shipping.
anybody know where to get their hands on a handle like this, let me know…looks like it would be a slick setup for the mildly heavy blf gt :+1:
and yall think the gt is heavy, this thing clocks in at over 8 lbs !
but man, 4.5 mill lux, and 7500 lumens, me likey :stuck_out_tongue:
what would stop somebody from putting the same hid and driver in the blf gt i wonder ?
If I remember right, the reflector for an HID needs to be designed different than an LED. That, and you would need to machine out the head to accept the HID bulb, and find a way to mount the ballast
I get an occasional “TINK” sound that is faint, doesn’t sound like breaking glass at all. mine does it inside at 70 degrees F or out side at –10 degrees F.
while im on the subject of handles and mods, i got to looking at some extra rubbermaid lids i had laying around
heres what they call a number 2, fits the bezel perfectly :+1:
works as a nice diffuser also :wink:
Just to be clear, I was not suggesting another thread.
I was / am suggesting a Replacement Thread & CLOSE THIS ONE. . :slight_smile:
Sure there could be a “Team Account”.
Pick a “Team user name”, set up a “Team email address”, set up the BLF account, and each “Team member” has the account & email password.
Then there is not the problem associated with one person having control of the account and no timely needed updates if that one person is not around…. as is the case at the moment.
This thread is closed for the next ten hours to allow members to watch the College Football Bowl Games.
Roll Tide & Go Dawgs
:wink:
Like minds think the same. I looked a few days ago, but did not find anything "decent"
Will someone please "list" for me, ALL "Team Members & Affiliation" involved in the BLF project.
I have a little "Treat" as appreciation. For all to "see"
Thanks
Added- This is what I found. Affiliation of each member to the project is also requested.
MRsDNF
Tom E
DEL
The Miller
Thijsco19
Texas_Ace
Neal
M4DM4X
Can someone show tint comparison to Utorch UT02 5000K 3D, I really like this one,and would like to see if GT with 4000K is much warmer or acceptable?
Thanks
Have not got my GT yet, but do have the UT02 3d 5000k. It will be quite a bit warmer I am assuming. I can get a comparison tomorrow after work. My GT is supposed to be redelivered tomorrow…
Nitecore has a handle for their Tiny Monster series, someone might check that one and see if it’d fit the GT…
Does anybody know where i can get a blf gt (giggle thrower)
BOOMER !!!
Yes, from now on the projects should use a Team account to handle all thread making to keep issues like this from happening again.
For now, the issue is that even if we make a new thread most will not find it or read it but the Team will have to read and keep track of both threads.
I don’t see it fixing a lot of issues at this point but it would add a lot of work.
We might could add to the FAQ in the support thread with all the relevant details that can be linked to, still not sure how much it would help though.
I am still not back to myself, I just started eating solid food again a few days ago. So I am doing my best to just scan posts as they are made in this thread.
On the plus side I lost a fair amount of weight, a rare thing to have happen over Christmas. :slight_smile:
So how do I get on the team account thx
I like the idea of the ‘wrap around’ handle because it allows adjustment for balancing the light when loaded with either 4 or 8 cells.
A clamp-on handle also seems much more secure than a handle mounted to the shallow hole of the tripod mount.
I’ve done some searching, and found plenty of things that won’t work. :wink:
My GT’s battery tube is about 56mm or 2.2” diameter at the round section.
All of the add-on handles I could find are too small. Their designs don’t allow for much wiggle room.
Nitecore NHM10
50mm, 1.97” diameter
XTAR handle for S1 or D35
46.5mm, 1.80” diameter
MecArmy CL52
52mm, 2.05” diameter
JetBeam RM46 and MCH46 combo
46mm, 1.81” diameter
I thought an accessory clamp for motorcycle forks could play a part in fabricating a handle, but I couldn’t find any larger than about 50mm.
I’ve made sturdy mounts for my Meteor and Q8 using 50mm (2”) quick-release truss clamps used in theater and stage lighting.
There are a few 60-63.5mm (2.36-2.5”) truss clamps, but they’re the less-elegant non quick-release type. They are a bit larger than the GT’s 56mm diameter.
I hope my (unsuccessful) findings can spark some other ideas for a clamp-on handle! :smiley:
@goshdogit
After my search efforts not finding anything that would fit right, and I really doubt someone will custom make them. I could be assuming wrong.
I thought about something simplistic. Like two velcro straps, sewn to a ridged dacron webbed strap. The idea is a bit primitive, but it would work well.
Thanks nodoubt! I thought it would be quite a bit warmer, and was right…
