Already tried. I assembled the Convoy L2 with XHP 50.2 and the FX-6 driver. Two-channel board with OSH Park, LEDs nervously flicker
It is necessary to try the bypass resistor between the anode and the cathode, but with what resistance?
Here’s the final install of the green lighted switch in my Convoy S2+.
This is the 6.9K ohm bleeder resistor (4.7K and 2.2K in series) that worked with the RMM Moonlight Special driver with BLF A6 firmware. Certainly a lot higher than I would’ve ever imagined.
And here’s the 47K ohm resistor used in the lighted switch.
I measure 0.03 milliamps for the lighted switch. A lot lower than I was expecting since it’s plenty bright at night. Here’s how it compares to the Meteor M43 turned off (FYI, the M43 lighted switch gets brighter when the flashlight is turned on).
Yes, the reverse press works as it should along with all the other functions. I kept experimenting with different bleeder resistors until I found the right value.
Are you sure?
without bleeder resistor on driver it works with 3/5 fw but for BLF A6 and Biscotti it turns the driver next mode memory for me in all cases. So for biscotti I always use bleeder.
…the blf x5 and x6 came with this lighted tailcap and bistro driver but in fact the lighted tail works easier with the older blf-a6 driver that was never tuned for it. Essential for working without endless tuning of resistors is a single and high Vf emitter, like the XP-L Hi that was in the X5/X6 lights. Using it in a triple and/or with a low Vf led like the 219c or XP-L2 means trouble with resistor values, but the blf-a6 driver can be tuned well with some effort (the bistro driver that has the Attiny25 is quite hopeless and you end up with a very dim tail light).
Pilotdog and myself have made those ring boards
I added balance resistors to it so it can have 6 different LEDs Lighted tail switch board replacing the washer around the switch
For the exampke pink and warm white, other combinations possible the board with balance resistors could use more than 2 different colors
