You might like it a whole lot more if you place a 30-45 degree TIR optics instead of the original reflector and lens. Put a 20mm o-ring behind the tir (not in front). Perfect fit and and you have a pretty dandy floodlight for close up work.
Would have posted a pic but as soon a friend saw it (modded) i had to part with it. Another one is already on the way. This one is a keeper to me. A low instead of the strobe would make it almost perfect.
If i must... i would really have liked they managed to do a different design of the body. It is so unappealing and cheap looking compared to the aesthetically well copied head (Zebra? Spark?).
I'm also liking the beam like it is. More flood than my Zebralight but still gives me better throw than my UF-H3 that is completely flood. If I need just flood, I use the UF-H3.
And by the way, the form factor of this type of lights with the rubber strap, is the best solution for headlamps, much better than the hinged ones, with less adjustment, and not that long lasting system normally.
This one adjusts quite well the inclination and stays where you leave it, I thought with the clip it would not work that good.
Do not use 14500s with it, not in high mode and strobe. I reckon 14500 in low mod is ok. High mode is like 2.2A with a freshly charged TF Flames and even if it is at 3.3V unloaded, it still drew 1.8A. Low mode is 0.2A. That's way too much for the driver electronics/LED.
I like this light a lot. The UI is a little different than usual, as Chidwack said. You have to actually 'click' the rubber switch on the head to change through the three modes. When you want to shut it off, you have to 'click' AND keep it pressed for a full second for it to turn off.
Fit/finish of the body is great, no issues. Has really nice heat-sinking in the head, maybe the best I've seen, and the clip is fairly unobtrusive. Nice color on the anodizing as well. It looks a little top-heavy (unlike the Trustfire Z1), but it still tailstands nicely. I don't know if it has already been mentioned, but the beam is pretty neutral, much warmer than the white of the Z1.
Fun little light, with a lot of flood from a single Eneloop. Other than the Strobe mode, what is not to like?
Another thing that the light does. You can set it on it's back with the beam pointing to the ceiling. It just rests on the clip and the screws that hold the clip on and it works for ceiling bounce if you want.
It's kinda weird how much throw the little light has. With all the flood you wouldn't think it would have any throw but it does surprisingly well.
The light seems well made and has a good finish but I have to say, This thing is ugly. It looks like it fell out of the ugly tree and hit every branch on the way down. It's so ugly it almost makes it's way back to cute.
The heatsinking in the head is excellent, on AA's I don't see heat being a big issue. I don't think it is an issue on any single AA light unless you are using 14500's. I don't remember ever having anything fry on an AA light with Alkies or Eneloops.
Has anyone checked this light to see how waterproof it is?
You're welcome Huny74. Yes you can lock out the tailcap. I would recommend doing so if you are going to carry the light in a backpack or something like that as the button does click on quite easily.
