At 225m the BK-FA0S hotspot it not as tight as modded MF02 given its larger reflector, what gives?
The battery tube threads for the head and tail cap is only* 2-3* turns and it is not anodized (cannot lockout)? Is it adequate?
Thanks for the review and tear down Lexel!
At first I thought I wouldn’t like all the extra buttons but now I agree with you they are a nice feature.
Niwalker didn’t make the S42 did they?
Maybe you were talking about the MF02 there?
Genius of you to bash the tail cap onto a piece of wood.
@ Lexel: can you please check if its battery-carrier is different from this? :
Please update when prize is confirmed.
My flashlight needs are fulfilled now, but after other investments in 2018 i might need a better thrower in 2019, then again there will probably be more alternatives by then :sunglasses:
One think people in German forum surprised the light is 70g lighter that the Astrolux MF02,
so carrying it is easier
the main difference makes the battery carrier which is about 75g heavier on the MF01 so both lights are almost balanced at the same point
I noticed today that the light sometimes flicker in Turbo after a few seconds then a few seconds later it stops again
I looked now again close on the driver and its used parts
The driver uses a pretty bad MOSFET compared to new Infineon and Vishay types
and the driver has no Output capacitor to smooth the PWM from the Buck regulator
So I did 3 improvements replacing 2 parts that could cause the flicker investing 2€ of parts
- first remove the old MOSFET and solder one of the best available ones there
- second remove the Diode and put in a 10A SMD type
- third add a 4.7uF 07R capacitor parallel to the main LED
I have also found some inconsistencies in the UI
for example if I switch the light on with an auxiliary button then click the main switch the light turns off
while I turn the light on with main button switch to aux buttons then main switch gets me back to memorized modes
Another odd thing is this
I have a medium mode memorized for main switch
I turn on the light with Turbo on auxiliary button and turn it off with the same auxiliary or the main button,
then the light comes on in moon the next time I switch it on with main switch
after this I turn the light on with a blinky mode on the other auxiliary
now I switch it off with that button or main button
and now switching on the main switch recognizes again the stored medium mode
Next thing
I switch the light on with blink mode on aux1 or switch it on with main button then switch to aux1
then switch to turbo on the 2. aux button
if I click now the main switch I do not get the memorized light level instead I get again the blinky mode of aux1 button
You`re brave!
Nice review Lexel. Are you updating with one of your own drivers?
The modded MF02 does roughly 15-20% more Lumens and is driven a bit harder, so the hotspot is overall bigger with more light in it,
but still the Niwalker has a higher peak intensity in the smaller hotspot
The light can be locked out by a full turn, then the carrier does not touch the tail boards ground ring
there are no solder bridges or stuff on the boards of the carrier, the traces are fully covered with solder mask
no risk of a short here
also the Carrier is wired 4S, so reversing a battery wont do a short
Playing more with the light I notice at some points a whining sound from the driver, I am pretty sure the unshielded inductor is causing it
So I switched out the Inductor with a 10uF shielded one
just in case I added another 4.7uF cap on the input in case the used inductor was smaller value
Awesome review :sunglasses:
So we’ll have to put up with yet another boring destruction with a hammer? Come on Lexel, don’t disappoint us like that….
Make a sabot and launch it from a Leopard 2 tank, that should ensure high speed impact testing, and spectacular slow motion footage, cuz i want to see the sabot peel away to reveal the flashlight
And i am sure the bundeswehr would be helpful
wonderful
viele danke
comparing with TN42 and MK35 would be interesting )
Mauuka has one review light as well and he also owns a TN42, so he can compare
Great review!
Disappointed in the driver quality.
Yeah the Astrolux MF02 driver is more sophisticated with better parts
I hope they change driver for production run
The last light I had with flickering output was a Klarus XT11GT which died after a few weeks with electronic crisp smell
made a NarsilM design for it
Niwalker BK-FA30S
added 3 pads for the auxillary switches,
one providing 5V for the Turbo switch
one sets multiples the current by 10 or goes to Turbo
the other divides the current by 10
Nice driver! Will you make it? I would like one!
I have ordered 3 prototype boards from Oshpark
I got yesterday the MF02 ones that have a little design error but nothing dramatically, same on the Niwalker Prototype
I got here the TN42 driver that fits the Niwalker light, but they do not support the auxillary switches
I need to test them but I am pretty sure they will work, so I got 2 boards left
