MT03 Driver swap. Texas Avenger FET driver, NarsilM ramping firmware
pictures of switch-
those pictures are not good enough I need macros where I can see the traces and the small green markings on the LEDs
I think that resistor is 1000 ohm. Smaller than I would expect.
The black surface of the switch makes it hard to see the circuits underneath. If you have a continuity tester I would draw out the switch on paper and then test all the wires to see how they are connected.
Did you say the leds are red and green? Does that correspond to the R and G next to them? (Sometimes they do and sometimes they dont, you can’t just assume)
Also, did you tape up the ends of the led wires when you put the driver in? You can’t have those bare wire ends touching anything.
You can see the arrows on the pcb showing led orientation.
Bearded, are the leds both facing the same direction?
LEDs are red and blue, working on testing continuity. yes the wires have heat shrink on them so they do not short on anything.
I’m not really sure how to tell.
Okay, so the R led is connected to the blue wire and the G led is connected to the yellow wire.
Are the other ends of the leds connected to the red or black wire?
Once you know that, then you can take a battery (maybe a discharged one at 3v) and a resistor (1,000 to 20,000) and run some power through the circuits. Then you know if it’s a positive or negative common wire.
Getting back to the switch problem. Does a continuity circuit show the switch is working like it should? Does it want to ramp up with thd switch cover off? It’s just really odd it works fine, ten minutes later acts like the switch is shorted internally.
The leds sometimes have a unique shape. Some have green dots. Do yours have that notch cut out on both ends, or have that dot under the lens on both sides?
I did a test last night and when clicking the button my tester would beep, let go of button it stops beeping. I thought I was all good to go besides eventually dealing with the switch leds, then the weird thing happened where it just turned on by itself.
I think I have another switch (no leds) and was going to put it in the light and see how that acted, if it works fine then ill know I need to rework the original switch leds, ill get started on switch testing soon.
Just use the 2 switch wires off the driver and touch them together, see if the driver is not the problem first.
I did that, I want to use an actual switch so I can reassemble it and check then.
Oh so the driver worked fine?
He has a strange problem. It works fine at first, then…
some info on switch, switch works fine not soldered to anything (put tester on red and black, push button tester beeps)
pics. kind of ironic blue wire lights up red led lol.
Also I wired up my other switch and it is seeming to work.
EDIT!!!
I let the light run at a lowish brightness for about 3 minuts and again it ramped up and went to configure! WHY ME?!
this is with a completely different switch and I am POSITIVE nothing is shorted out.
Now when I screw battery tube in it just ramps right up.
At 18 seconds I had NOT clicked the button.
Light seems to function perfectly with switch and driver not mounted. could there be a short somewhere when I tighten the driver retaining ring? also if I put either of the led power wires to the right side of the diode above the switch wires they will come on, they stay on at all times.
What if you remove all switch wires from the driver.
Then just short the two switch pads to turn it on. Will it still ramp up on its own?
Do you see any excess in solder on the switch pads or anywhere else on the driver that might be creating a connection where there should not be?
I did run it without any switch and it worked fine, there was some fine solder dust on the pads above the switch pads when I got it. I made sure it wasnt crossing any other pads.
Going to put it back together again with switch hooked up and see how it does.
