I think that resistor is 1000 ohm. Smaller than I would expect.
The black surface of the switch makes it hard to see the circuits underneath. If you have a continuity tester I would draw out the switch on paper and then test all the wires to see how they are connected.
Did you say the leds are red and green? Does that correspond to the R and G next to them? (Sometimes they do and sometimes they dont, you can’t just assume)
Also, did you tape up the ends of the led wires when you put the driver in? You can’t have those bare wire ends touching anything.
Okay, so the R led is connected to the blue wire and the G led is connected to the yellow wire.
Are the other ends of the leds connected to the red or black wire?
Once you know that, then you can take a battery (maybe a discharged one at 3v) and a resistor (1,000 to 20,000) and run some power through the circuits. Then you know if it’s a positive or negative common wire.
Getting back to the switch problem. Does a continuity circuit show the switch is working like it should? Does it want to ramp up with thd switch cover off? It’s just really odd it works fine, ten minutes later acts like the switch is shorted internally.
The leds sometimes have a unique shape. Some have green dots. Do yours have that notch cut out on both ends, or have that dot under the lens on both sides?
I did a test last night and when clicking the button my tester would beep, let go of button it stops beeping. I thought I was all good to go besides eventually dealing with the switch leds, then the weird thing happened where it just turned on by itself.
I think I have another switch (no leds) and was going to put it in the light and see how that acted, if it works fine then ill know I need to rework the original switch leds, ill get started on switch testing soon.
Light seems to function perfectly with switch and driver not mounted. could there be a short somewhere when I tighten the driver retaining ring? also if I put either of the led power wires to the right side of the diode above the switch wires they will come on, they stay on at all times.
I did run it without any switch and it worked fine, there was some fine solder dust on the pads above the switch pads when I got it. I made sure it wasnt crossing any other pads.
Going to put it back together again with switch hooked up and see how it does.
