click the image, it will open in a new window, you can click it again in that window for full resolution 30MP
Only the image from my end is 30MP, the G1X is 14MP I think correction, 12.64MP.
Dale,
That is impressive!
Thanks for the hard work and thanks to your brother.
Later,
Keith
Coyotehawk will add your names to his sign up list. You’ll see your name when he does the next update. It will be sometime mid January when you are emailed with the details of where to go and how to order. (Uses PayPal, btw)
You can also buy 8 of the Samsung 35E batteries for $40 at the same time as you buy the light. No sign up necessary for those. There are plenty of batteries in stock.
Welcome to BLF.
Ps, The group buy is still open, but could close at any time.
Sorry, I need to ask this question. What is the difference between opaque black switch covers vs of translucent black?
Opaque black isn’t transparent, blocks light. Translucent allows the lighted switch to shine through.
Which one does BF GT come with?
I see the image info as such
4,352px × 2,904px (scaled to 872px × 582px)
Looked cold and foggy there, Dale
The GT comes with black cover that let’s some light through.
Similar to this.
It is “supposed” to be translucent!
It’s fog season here, but it’ll light up the moon!
AR, in the mid 40’s and the beam was across 1.3 miles of water, about 7’ off the water at my end and maybe 20’ above the water at my brother’s end. Otherwise we have low humidity and it’s a calm night, no fog. (50% humidity now, I took those shots not long after dark, about 7:00PM.
Btw, my leds looked brighter and darker, but it was just the cover. Underneath they were equal brightness.
Here is a quick pic.
i hope i get a shipment notification since 194+168+200
covers the whole first group
Dale…… Was this done with a stock GT or one you have modded??
If modded…. what are mods?
Thank you….
Teacher, I only changed the emitter to a cooler white one taken out of an ArmyTek Barracuda Pro.
Thank you my friend.
Any guess as to how much cooler??
This is pretty doggone amazing!!
A stock GT would not do this would it??
Please add me to the list
Hi Dale! I’m wondering about using the Luminus SST-90 emitter for the GT. I was thinking along the lines of what a de-domed sst90 emitter would compare to as far as throw next to the xhp-35hi? I’ve also looked at the CFT-90, but not sure how one would modify it. I am guessing that the emitter used in the CFT-90 is not the same as the SST-90? Any thoughts on this? Thanks!!!
