Hum, I went to heck the differences on HKJ test, and the Efest Purple (vs Windyfire IMR 14500) actually seems to perform better on 3A, 5A. On 7A it has a bigger initial drop, but it holds on a bit better on runtime! On 10A, the Efest seems to have some juice while there is not data for the Windyfire!
Yup, I was surprised as well! I went to check it about a month ago, before ordering some things from MTN. At first I was searching and comparing the Windyfire with the Sanyo. But then I saw the Efest (Purple) on MTN and went to check some info for those!
According to HKJ tests, it is very consistent on lower and higher Amp draw, and it seems to be the best with higher amps. I then ordered 2 of them for some flashlights I wanna use/mod. Letās see how they behave!
They have less capacity than the Sanyo, Sofirn and eventually PKCell, even though HKJ points them to be close to 700mAh, but their performance seems better even in lower Amps
Yes, true! The sag is bigger on the Efest, but they apparently will last longer in runtime! Am I correct? āCause Iām no expert on this so Iām just attempting to interpret the data :zipper_mouth_face:
The Efest also seem to be āunder-ratedā having about 700mAh, instead of the 650mAh advertised! So it is also good
Yes youāre correct.
I bought the WindyFires for high discharge about a year ago.
They perform well on 3 Amperes with a SST-40 LED in a Solarstorm SC01.
It seems the Efests would perform similarly, maybe 30 seconds longerā¦
(edit) thanks for the comparison pictures. :+1:
So the benefits of the WindyFires only show above 4 Amperes and only when theyāre more than half full of charge.
Interesting.
I should pimp my SC01 further with a 5 Amperes driverā¦ or just skip the driver altogetherā¦ :smiling_imp:
Thanks for helping me understand this
I heard about the WF sometime ago, but being a āfireā battery, I never knew how good it was till seeing HKJ tests. But then seeing the Efests, made me go back and I ended up ordering 2 of them as well! Maybe for those 30 seconds
Hum, you use the stock driver or a different one with the SST-40? It draws more than other types of LEDs, right? (like the XPL / XPL-HIā¦)
Also, did you mean :
or
I was a bit confused now, sorry
Over 4Amps, the Efest seem to have better perfomance and the sag is quite similar, being constant, without abrupt drops!
I donāt know, i have always hated the stock driver because of the low frequency PWM.
So i put in a flipped upside down Nanjg 105 driver with an Omten 1288 switch on top of it.
(had to stack 2 of the 7135 chips on top of the other 2 to make room for the switch)
It fits in the pill after some butchering, but only just.
Reverse clicky switch, so no parasitic drain when off.
3 Amperes, or actually 2.8 Amperes (8x AMC7135 = 8x 0.35 Amperes = 2.8 Amperes).
Yes.
No.
The Efests seem to be just as good as the WindyFires with high currents when they are 50% depleted (or 50% charged).
So the Efests have a more steady discharge curve (and last a little longer) but the WF is a little better in the beginning.
If both were available for the same price and shipping cost, i probably would choose Efest.
I think a light should also work just as well on a half full cell.
Thatās why i dislike FET DD drivers.
But also 7135 drivers have their disadvantages, because they give you a default voltage drop of 0.2 Volts.
This can be compensated with a low Vf LED like the SST40, but it would have been better to use a FET DD CC driver like the LD25.
Hum, I know that :person_facepalming: I just ordered 2 of them because I āhad toā order somethings from MTN and I took advantage of the shipping to get them! Otherwise, they are expensive for!
Even from NKON, I purchased 3x18650s a while ago and paid more for shipping than the final value of the batteriesā¦ But maybe NKON can get some of the Efest or Windyfire! For you, living there and even for other countries it would be nice to have that option around here on Europe!
Hum, the Enercig seem to be a nice alternative, maybe having only a little less capacity!
I wish there was a similar cell on the 14500s as the Aspire 1100mAhā¦More capacity and still able to put some current out of it :sunglasses:
Hum, guess I never seen that mod!! Have any pics of it or posted it somewhere around? Would like to learn from it if possible
Being a side switch it must have been a bit troubling! But for your numbers, it must have ended well :smiling_imp:
Oh, now I got it! Had to go to HKJ graphics again to check what you meant! The beginning of the discharge gives the Windyfire a small advantage, but then the Efest gets better on runtime, on the ālast 50% chargeā!
Iāll see how mine behave when I get them Despite I donāt have means to measure it! :person_facepalming:
I didnāt take pictures of that mod.
Yeah, it was a bit of a challengeā¦
Had to change the switch boot too, because you have to press deeper for the switch to āclickā.
I use this peculiar TIR in it: https://www.aliexpress.com/item/YMWO-20-High-quality-Led-lens-CREE-Lens-Size-20X18-07mm-5-degree-Clean-Surface-PMMA/32612075843.html
It projects the LED chip with the centre lens section, you can count the dots on the die, itās quite a large projection.
And the outside is the internal reflector, which adds the rest of the LED light to the beam.
The beam is ugly and has some serious rings around it, but it works very well in output numbers (which i can not measureā¦)
I guess the SST40 die is larger than what the optic is intended for.
I hope to score some Osram Synios soon, that may be a better choice for this thing.
So itās a far from perfect light, but still very bright for the size.
Maybe iāll post it in āwhat did you mod todayā some day, with some pics of the intestines.
PS: The LD25 is a FET CC driver, not DD (i edited it now)
I went to check the driver and saw there the reference to CC, so I perceived it was a āmistakeā Also, I am not familiarized with that driver but is seems quite nice! Most of the drivers Iāve been using are Biscotti driversā¦ :nerd_face:
No problems with the photos, I was just curious about that kind of mods, as I am not aware of how to make them! Well, nor most of other āfundamental modsā being done around hereā¦ Lol
Never seen that TIR before! Seems quiteā¦strange, but having that big ābodyā it must certainly reflect a lot of light!!
Ahah, if you post, Iāll check those! These mods are part of BLF history, they must be documented :+1:
