[PART 1] Official BLF GT Group Buy thread. Group buy officially closed! Lights shipping.
If you disagree with another user on a forum, attack their argument instead of attacking the user and what/how many lights they own.
It’s not hard, in fact it’d be really easy to answer… but I’m thinking you’re asking something to question, critique or otherwise cause trouble… and I don’t want that…
It would simply reduce the red and green wavelengths, and make the beam almost not visible.
The reason cool white LEDs have a much more visible beam is because they output a lot more blue and green light.
I would love to see that to Joey.
Especially if it was done in a controlled manner as the Neat Test Dale (DB Custom) Did . That actually shows something where ’the rubber hits the road’…… the target.
Theory is one thing, and not a bad thing either; but seeing it makes it real… to me anyway. :slight_smile:
And the photo of beamshot on target, taken at target…… is hard to beat.
Fantastic Dale!! Kudo’s to you…… :+1:
Post #13932 / DALE’S (DBCustom) MOST EXCELLENT TEST…. 1.3 Mile Beamshot on target photos.
It only effects run time. This is a buck driver, it take the 16.8 volts and regulates it to a steady lower voltage (13 something volts, I can’t remember the exact number). So as long as the batteries stay above that specific voltage, the driver stays “in regulation” and it can deliver max power.
Once the batteries drop down in voltage (below 3.5v ?) it drops out of regulation and can not produce full power any longer so the output slowly declines.
4 30Q cells gave 45 minutes of regulated power at 2A then another 45 minutes of reduced power before the lvp kicked in. So 8 cells should double those numbers.
Maybe someone can chime in with the exact voltage this drivers drops out if regulation at.
This is a subjective opinion, not a fact.
“better” will depend on what someone prefers.
Just like 10k lumens and 100m throw isn’t better than 100 lumens and 10km throw, it completely depends on what the person wants.
I will also point out that a lot of people who tested/bought the GT mentioned how much everyone they showed it to was amazed by the beam, including themselves.
Just curious what hes going to compare his newly aquired BLF GT too, why is that so hard to answer?
Guess you smell it too. Cause I didn’t post anywhere near you.
Oh, it seemed like you were going to criticize him if he didn’t have many flashlights, or didn’t have any warm white flashlights, or something like that.
I never got the feeling that LuminousIgnis was trying to set up an attack on Spartan16 by asking what lights they have. If anything it could offer some insight into what tints and temperatures they have personally experienced.
No… I think there was a more sinister motive at work than that… like just trying to cause trouble and grounds to critique and judge another member.
I did…! Very much so…!
I think you are being overly critical. I don’t see where anyone has asked for “another blue light for mindless consumers”.
Neutral white is just that Neutral.
Not “Blue” & “Not Yellow/Orange”.
Maybe we can add a disclaimer to all group buys stating that the seller will try their best to give early sign ups prefered shipping, but it can’t be guaranteed. Lol
This is still better than the Q8 GB in which everyone got to buy at the same time. First come first served.
Correct. What I was referring to and forgot to be clear, was the ability to illuminate targets for human eyes at distance under real life conditions, as is the primary purpose of a so called thrower, in most people’s opinion.
With these defining details it becomes fact instead of opinion.
Correct. As a lightsaber, the higher color temperature version would most likely be “better”. Or “mo’ betta”.
Ah, I agree then. :+1:
I’m back and I want them all.
On the user manual included with the GT, it mentions a Momentary mode. Is this a mistake or am I reading over it on how to get into in?
Hmmmm… Make sure it is not your own upper lip you are smelling.
Just a friendly tip…… :+1:
5 clicks from off if I remember, and to get out of momentary mode loosen tail cap
