Here’s the final install of the green lighted switch in my Convoy S2+.
This is the 6.9K ohm bleeder resistor (4.7K and 2.2K in series) that worked with the RMM Moonlight Special driver with BLF A6 firmware. Certainly a lot higher than I would’ve ever imagined.
And here’s the 47K ohm resistor used in the lighted switch.
I measure 0.03 milliamps for the lighted switch. A lot lower than I was expecting since it’s plenty bright at night. Here’s how it compares to the Meteor M43 turned off (FYI, the M43 lighted switch gets brighter when the flashlight is turned on).
Yes, the reverse press works as it should along with all the other functions. I kept experimenting with different bleeder resistors until I found the right value.
Are you sure?
without bleeder resistor on driver it works with 3/5 fw but for BLF A6 and Biscotti it turns the driver next mode memory for me in all cases. So for biscotti I always use bleeder.
…the blf x5 and x6 came with this lighted tailcap and bistro driver but in fact the lighted tail works easier with the older blf-a6 driver that was never tuned for it. Essential for working without endless tuning of resistors is a single and high Vf emitter, like the XP-L Hi that was in the X5/X6 lights. Using it in a triple and/or with a low Vf led like the 219c or XP-L2 means trouble with resistor values, but the blf-a6 driver can be tuned well with some effort (the bistro driver that has the Attiny25 is quite hopeless and you end up with a very dim tail light).
Pilotdog and myself have made those ring boards
I added balance resistors to it so it can have 6 different LEDs Lighted tail switch board replacing the washer around the switch
For the exampke pink and warm white, other combinations possible the board with balance resistors could use more than 2 different colors
For those that are fans of the Generation 1 lighted switch, here’s something to consider when installing your switch. The washer is essentially a diffuser for the switch LEDs. The clearer the washer, the more light that can pass thru, but also shows more artifacts (outline of the switch and the position of the LEDs). Less transparent the washer, less light, but a more uniform illumination of the tailcap.
I initially used the Home Depot washer from the link in the OP (left picture below): 5/16 in. Nylon Washer (3-Piece per Pack). I had to sand down the perimeter to make it fit in the Convoy S2+ and the hole was too big for the Omten switch so I filled the gap with a smaller washer that I also sanded down. When installed it looked good, but it seemed to block too much light from the LEDs and looked a little dull. So I made some washers from some plastic items I had in my workroom.
Here are some of the washers on the switch (left is the Home Depot washer).
And here’s how they look in the flashlight. Please notice (and I tried to take the pictures to show this) that the left is less bright and a little dull, but uniformly lights the tailcap. The middle is bright and crisp, but definitely shows some artifacts. And the right is a good compromise.
The clear washer and the semitransparent washer had the same effect in the tailcap. I then sanded 1 side of the semitransparent washer, and then both sides, but that still wasn’t enough to adequately defuse the light. So I sanded down 2 washers to make them thinner and stacked them. I’m pleased with the final result.
Because the classic lighted tail set is for sale, it is attractive for people who do not solder to build this version. Fiddling with the washers is something within reach of almost everyone
