New subject to hopefully move past all this bickering.
A few weeks ago I was contacted by a NASA sub-contractor about wanting a GT for research and testing.
They were not very forthcoming about the details but it seems that they are wanting to test it out for use on Drones that are used for mapping the earth / disaster areas.
So in a few weeks when they get their light, you can officially say that the GT is being used in research for NASA! How cool is that!
They have had a bunch of questions about different options for the light as well.
You can try contacting Neal about the batteries, if the light has not shipped it is possible. If it has shipped already they have a separate purchase page for the cells alone, it just costs a little more.
Within four years, Osram Sylvania predicts that LED headlamps will be installed in 20 percent of all new cars. The Toyota Corolla and Ford Explorer come with standard LED low-beams, and as fuel-efficiency regulations tighten, LED headlights will play a key role in reducing energy consumption. Indeed, they each draw between 15 and 18 watts of power, versus 55 to 65 watts from a halogen and 42 watts from an HID. Their response from off to full strength—known as “rise time”—is just one millisecond. An incandescent bulb is 250 times slower, which makes LEDs especially advantageous for brake lights. There’s no question that LED headlights are brighter (3000 lumens at low beam versus 800 lumens for halogen, although this varies depending on the optical system used) and output light at a color temperature closer to daylight (5500 Kelvin versus 4500 for HID and 2500–3000 for halogen).
I really don’t care about the stock tint, will use it for a while and if I don’t like it, I will switch it for something I like more…
I do have a question about the led bin intensity.
The stock is a XHP35 HI in D4 bin, which yields about 2500+ lumen on turbo.
If I were to change it for an XHP35 HI E4 bin, in theory how much lumen would I get on turbo?
If I were to change it for an XHP35 HDE7 bin, in theory how much lumen would I get on turbo? I know this one is an HD not a HI emitter, I wonder if the increase brightness will compensate the increase in hot spot size…
I thank in advance for your input, it is greatly appreciated!
I don’t know or care what part of these new headlights are but a lot are to bright . Won’t do you much good if u get hit headon by some body you blinded.
I measured 2049 lumens on the 4000K emitter in my light box, 2225 lumens on the cool white version I swapped in.
My light, measured at the emitter with a loop in the negative lead contact and a Uni-T clamp meter, made 2.43A in Turbo and 1.93A in High. Changing my cells from the LG M25 to Sony VTC5A didn’t alter the output significantly.
I have never heard of an E7 bin, they usually stop at 4 and then go up to the next letter with the xhp35.
Each bin is worth about 7% output change (they also have a 7% tolerance range, so keep that in mind).
So going to an E4 bin would be worth about a 14% increase over the stock LED. Although I have not seen any E4 bin XHP35 HI’s except for a few that cutter got.
The HD would still net you lower CD even with higher output. Although I have heard that dedoming an HD LED can give you better lumens and throw over a HI LED, if you are willing to put up with the tint shift (I am not).
Yeah, that is an E7 tint and C4 flux, so around 3000k. I got the 90 CRI version of that LED actually and tested it awhile back.
I also have that 3C E2 LED. In fact it might be what is in the Giggles prototype actually come to think of it. Personally I prefer the stock LED better but I will wait till I get the prototype back to do a direct comparison (well, VOB will do it first I am sure).
