Thanks once more to everyone on the team!
Brother in law cant wait for his!
Hello, what is the bin of utorch ut02 nw? could it be replaced by this in gt? regards
3D 5000K
You could, if you reflow it yourself at this point
The low voltage protection is set high enough that they would have to be really out of balance for them to be damaged.
If they are around the same age, it should be ok.
Ideally though, each set of 4 cells in each carrier should match.
They just don’t understand the danger in it .
not sure if it was just because of my acct, but i just got the nitecore i8 8bay charger for $29 on amazon—for those of you looking for a 8 slot charger for this set of batteries
aggillator:I know you’re supposed to use new batteries of the same brand, capacity and charge/discharge cycles for giggles. I have 8 sanyo 18650ga flat tops with 3500mah and they are both around the same amount of discharge/charge cycles. Does it have to be exact, or if it’s a couple off is that ok? Thanks all!
Oh, so the main thing is that each set of four have to match, but each set of four doesn’t have to match with each other?
I think you are right, I am reading it wrong
http://www.cutter.com.au/proddetail.php?prod=cut2676
I do see a 3C tint (5000k) E2 flux XHP35 Hi here, maybe a group buy?
Just to clear things up Cutter do not have any E2 3C XHP35 leds left in stock.
Rcvd the light today……holy hell is it big hahahaha still feels good in the hand tho. only one coating blemish in a heat ring that can be covered easily. Everything else appeared intact and without flaws. Battery tube was dirty but not an issue. Overall 110% satisfied with purchase!!! Thanks everyone for the great light.
One question though - Are the battery springs on the carries supposed to be so light pressure?
AlexGT:I think you are right, I am reading it wrong
I thought that was the case when we checked in November.
The springs are a bit light when used with unprotected cells but are nice and tight with protected cells. Lumintop focuses on protected cells for their lights, so it kind of figured they would follow this design.
Personally I wish they were a bit longer to hold the unprotected cells a bit better but they are good enough. I have not had any issues with them.
Texas_Ace: aggillator:I know you’re supposed to use new batteries of the same brand, capacity and charge/discharge cycles for giggles. I have 8 sanyo 18650ga flat tops with 3500mah and they are both around the same amount of discharge/charge cycles. Does it have to be exact, or if it’s a couple off is that ok? Thanks all!
It is best for all 8 to match but yes, as long as the 4 in each carrier match, you will be ok. I have been using both of my GT’s with 30q/HE4’s in 1 carrier and laptop cells in the other. Not officially recommended but it works fine.
Thanks guys! The BLF GT is incredible!!!
Received with cells.
Are these batteries supposed to be flat top, button top or doesn’t it matter?
They need to be button top or solder blobed. Or you could remove the protection PCB, although I would prefer to solder blob them.
Any information when registered 2 boxes with cells will be shipped to EU?
Mike
blinker:Are these batteries supposed to be flat top, button top or doesn’t it matter?
Thanks.
I finished merging lists (The Miller, Coyotehawk) and sorting them based on name and tagging based on PMs already sent out on 2017-12-01 and 2017-12-09.
NO NEW PMs have been sent yet.
The column labeled "Future Round PMs" will be sent --- in the future.
Do not purchase any from that batch until you get a separate PM for it around mid-late January 2018
Also, do not use an old payment PM to purchase additional GT's above what you were approved for.
If you see any issues, PM Texas_Ace, Coyotehawk, and Mr.Scott.
Names |
Request Numbers |
2017-12-01 PMs |
2017-12-09 PMs |
Future Round PMs |
05131996 | [906] | 0 | 1 | 0 |
10fold | [1345] | 0 | 0 | 1 |
18000bph | [1561] | 0 | 0 | 1 |
1C3 MAN | [816] | 0 | 1 | 0 |
220daniel | [1018] | 0 | 1 | 0 |
240 | [136] | 1 | 0 | 0 |
2Grumpy | [1610 1759] | 0 | 0 | 2 |
338LM | [1347 1348 1349] | 0 | 0 | 3 |
666fixed | [264] | 1 | 0 | 0 |
777 | [930] | 0 | 1 | 0 |
A380 | [112] | 1 | 0 | 0 |
a_idiot | [1170] | 0 | 0 | 1 |
a_idoux | [1699] | 0 | 0 | 1 |
Aardvark Spleen | [109 215] | 2 | 0 | 0 |
Abe87 | [280] | 1 | 0 | 0 |
abhinit90 | [483] | 1 | 0 | 0 |
Abqjohnny | [ 50 188] | 0 | 2 | 0 |
abril | [200] | 1 | 0 | 0 |
ace0001a | [1733] | 0 | 0 | 1 |
adamshoward | [868] | 0 | 1 | 0 |
adirondackdestroyer | [213] | 0 | 1 | 0 |
adnj | [120 121] | 0 | 2 | 0 |
AdrianWA | [405 416] | 1 | 1 | 0 |
adsum | [553] | 1 | 0 | 0 |
Ag76 | [491] | 1 | 0 | 0 |
aggillator | [110] | 1 | 0 | 0 |
Aimi92 | [1117] | 0 | 0 | 1 |
airack | [750] | 1 | 0 | 0 |
AirBreaker | [352] | 0 | 1 | 0 |
akawaterman | [1479] | 0 | 0 | 1 |
akoposilester | [ 87 362] | 1 | 1 | 0 |
Akozub | [1639] | 0 | 0 | 1 |
Al747 | [1492 1515] | 0 | 0 | 2 |
Alamo | [1079 1080] | 0 | 0 | 2 |
albertopnp | [91] | 1 | 0 | 0 |
albertosm | [1440] | 0 | 0 | 1 |
alejandrov | [980] | 0 | 1 | 0 |
alex1234 | [ 251 1573] | 1 | 0 | 1 |
AlexGT | [ 37 1353] | 1 | 0 | 1 |
alifpb98 | [1270] | 0 | 0 | 1 |
Alux | [694] | 1 | 0 | 0 |
amaretto | [529] | 0 | 1 | 0 |
AmericanEDC | [ 847 1670] | 0 | 1 | 1 |
ammofox | [1215 1216] | 0 | 0 | 2 |
amorph | [1060 1671] | 0 | 0 | 2 |
amplificus | [300 503] | 1 | 1 | 0 |
Andreiw210 | [1034 1035] | 0 | 2 | 0 |
Andy sto | [1103] | 0 | 0 | 1 |
Angel Martínez | [ 256 262 400 1019] | 1 | 0 | 3 |
angler1088 | [1483] | 0 | 0 | 1 |
AngryFish | [921] | 0 | 1 | 0 |
anitasanger | [820] | 0 | 1 | 0 |
ant0 | [592] | 0 | 1 | 0 |
Anthon | [129] | 1 | 0 | 0 |
antiparanoico | [62] | 0 | 1 | 0 |
aoakeson | [1263] | 0 | 0 | 1 |
apartlow | [1308] | 0 | 0 | 1 |
AppA | [674] | 1 | 0 | 0 |
apt323 | [145] | 1 | 0 | 0 |
Archangel72 | [875] | 0 | 1 | 0 |
archimedes | [84] | 1 | 0 | 0 |
arditty | [722] | 1 | 0 | 0 |
aremihc | [308] | 1 | 0 | 0 |
Ares1744 | [984] | 0 | 1 | 0 |
arficus | [1579] | 0 | 0 | 1 |
Arildb | [1013] | 0 | 1 | 0 |
ArmedRN | [1165 1173] | 0 | 0 | 2 |
ARMS.AARON | [470] | 1 | 0 | 0 |
ARsee | [386 473] | 1 | 1 | 0 |
artwal | [1675] | 0 | 0 | 1 |
Asbestos | [1300] | 0 | 0 | 1 |
ashwally | [ 943 1502] | 0 | 1 | 1 |
Aslan | [ 158 1619] | 1 | 0 | 1 |
aslpg | [45] | 0 | 1 | 0 |
Asmartik | [946] | 0 | 1 | 0 |
asnidi2 | [567] | 1 | 0 | 0 |
Attackhorse | [1092] | 0 | 0 | 1 |
Aussi | [1191] | 0 | 0 | 1 |
Awdtsi | [480] | 0 | 1 | 0 |
azj | [1393] | 0 | 0 | 1 |
b1i1l1l1y1 | [723] | 1 | 0 | 0 |
B1reed | [1731] | 0 | 0 | 1 |
backup41 | [791] | 0 | 1 | 0 |
Bad_Reaction | [1290] | 0 | 0 | 1 |
BadGround | [1481] | 0 | 0 | 1 |
Badhombre | [1245] | 0 | 0 | 1 |
bananainmypocket | [1524] | 0 | 0 | 1 |
BanglaBob | [329] | 1 | 0 | 0 |
basslovin808 | [1158] | 0 | 0 | 1 |
battletross | [243] | 1 | 0 | 0 |
Bbop | [763] | 0 | 1 | 0 |
BC4Lyphe | [1226] | 0 | 0 | 1 |
bd52 | [279] | 1 | 0 | 0 |
BDM | [467] | 1 | 0 | 0 |
bdm82 | [665] | 1 | 0 | 0 |
Bdubelyew | [740] | 1 | 0 | 0 |
beanhill911 | [ 866 1302] | 0 | 1 | 1 |
BeardedRaleigh | [239 356] | 1 | 1 | 0 |
BEARS ARE PEOPLE TOO | [848] | 0 | 1 | 0 |
beastlykings | [1523] | 0 | 0 | 1 |
bella-headlight | [ 496 1093] | 1 | 0 | 1 |
Ben_Varney | [935] | 0 | 1 | 0 |
bgondee | [1061] | 0 | 0 | 1 |
bh46118 | [1505] | 0 | 0 | 1 |
Bhevo47 | [1115] | 0 | 0 | 1 |
bhtune | [1581] | 0 | 0 | 1 |
bibihang | [101] | 1 | 0 | 0 |
biczownia | [883 884] | 0 | 2 | 0 |
Biffe-22 | [1383 1384] | 0 | 0 | 2 |
BigBird | [1137] | 0 | 0 | 1 |
bigm | [1234] | 0 | 0 | 1 |
bigrick | [695] | 1 | 0 | 0 |
BigTrout | [815] | 0 | 1 | 0 |
BigusLightus | [867] | 0 | 1 | 0 |
Bill_tong | [287] | 0 | 1 | 0 |
Billcosbysplug | [1365] | 0 | 0 | 1 |
BILLMC89 | [1727] | 0 | 0 | 1 |
Billy X | [1257] | 0 | 0 | 1 |
BingoThink | [899] | 0 | 1 | 0 |
Birddog | [1109] | 0 | 0 | 1 |
bjs55 | [170 462] | 1 | 1 | 0 |
bk1020 | [1478] | 0 | 0 | 1 |
bking | [962] | 0 | 1 | 0 |
bkling | [393] | 0 | 1 | 0 |
BlackAdder | [1089] | 0 | 0 | 1 |
blackbalsam | [803 932] | 0 | 2 | 0 |
blampen | [796 861] | 0 | 2 | 0 |
Blane | [1005 1053] | 0 | 1 | 1 |
blastzone | [1590] | 0 | 0 | 1 |
Blazer296 | [1168 1429] | 0 | 0 | 2 |
Blenman37 | [781 782] | 0 | 2 | 0 |
blf-mode | [1185] | 0 | 0 | 1 |
BLFBob | [839] | 0 | 1 | 0 |
blgrssby | [916] | 0 | 1 | 0 |
BlindingL5s | [93] | 1 | 0 | 0 |
blinker | [1642] | 0 | 0 | 1 |
blitzlinger | [1626] | 0 | 0 | 1 |
Blue2 | [1560] | 0 | 0 | 1 |
blueb8llz | [389 390] | 1 | 1 | 0 |
Bo4ka | [ 436 571 1625] | 1 | 1 | 1 |
Boaz | [144] | 0 | 1 | 0 |
Bob_W | [1551] | 0 | 0 | 1 |
BobbyMK | [463] | 1 | 0 | 0 |
bobdotorg | [658 659] | 1 | 1 | 0 |
BobTB | [ 936 1420] | 0 | 1 | 1 |
bogdanr | [873] | 0 | 1 | 0 |
Boldo | [769] | 1 | 0 | 0 |
BOMBAY | [347] | 1 | 0 | 0 |
Bonham | [27] | 1 | 0 | 0 |
Boonie_Hunter | [1487] | 0 | 0 | 1 |
boostedsubie | [683] | 1 | 0 | 0 |
borealis | [363] | 1 | 0 | 0 |
BorisBar | [468] | 1 | 0 | 0 |
Boschlite | [1344] | 0 | 0 | 1 |
bossf350 | [ 217 1454] | 0 | 1 | 1 |
Box | [ 65 631] | 1 | 1 | 0 |
BoxCarWillie | [1172 1360] | 0 | 0 | 2 |
Bozlight29 | [ 585 1516] | 1 | 0 | 1 |
breenommy | [1435 1436] | 0 | 0 | 2 |
Brett | [851] | 0 | 1 | 0 |
Brian Metcalfe | [855] | 0 | 1 | 0 |
BrianK | [605 727] | 1 | 1 | 0 |
BrianV | [ 991 1014] | 0 | 2 | 0 |
Bribo | [40] | 1 | 0 | 0 |
brightlights | [150] | 1 | 0 | 0 |
brimstn | [1535] | 0 | 0 | 1 |
Britlightbruce | [835] | 0 | 1 | 0 |
Bruno28 | [ 139 448 1577 1655] | 1 | 1 | 2 |
BT100 | [ 418 485 862 1322] | 1 | 2 | 1 |
Buckeye | [1569] | 0 | 0 | 1 |
Bucky the killer | [1689 1762] | 0 | 0 | 2 |
budman | [1161] | 0 | 0 | 1 |
bugman1972 | [1734] | 0 | 0 | 1 |
Bupyc | [343] | 1 | 0 | 0 |
Buttkicker | [1156] | 0 | 0 | 1 |
Buzzing Bulb | [237] | 1 | 0 | 0 |
Buzzy243 | [464] | 1 | 0 | 0 |
BVH | [ 818 819 886 1526 1527 1528] | 0 | 3 | 3 |
bwl123 | [611] | 0 | 1 | 0 |
byarnell05 | [ 624 1462] | 1 | 0 | 1 |
caddylover | [853] | 0 | 1 | 0 |
caelanseth | [877 878] | 0 | 2 | 0 |
Caleb | [33] | 1 | 0 | 0 |
Caleb-v | [163] | 1 | 0 | 0 |
Calmaja | [824] | 0 | 1 | 0 |
camelight | [1728] | 0 | 0 | 1 |
candor | [ 756 1389] | 1 | 0 | 1 |
Captain_Joe | [764] | 1 | 0 | 0 |
caramba | [180] | 0 | 1 | 0 |
cardman625 | [1124] | 0 | 0 | 1 |
carljammers | [1530] | 0 | 0 | 1 |
carmantl | [ 327 521 1691] | 1 | 1 | 1 |
Caseit741 | [937] | 0 | 1 | 0 |
CASEY7777 | [1490] | 0 | 0 | 1 |
CASHESVALLEY | [127 396] | 0 | 2 | 0 |
casi29061965 | [ 24 649] | 1 | 1 | 0 |
Casper2000 | [1336] | 0 | 0 | 1 |
cavorite | [358] | 0 | 1 | 0 |
Cawi | [703] | 1 | 0 | 0 |
cccpull | [700] | 1 | 0 | 0 |
CCl3NO2 | [998] | 0 | 1 | 0 |
celler | [1244] | 0 | 0 | 1 |
cellguy | [842 843] | 0 | 2 | 0 |
cerberos | [1472] | 0 | 0 | 1 |
cgcollege | [1390] | 0 | 0 | 1 |
Charga | [ 46 500] | 1 | 1 | 0 |
charnchai | [1025] | 0 | 1 | 0 |
Chasealmighty | [1205 1512] | 0 | 0 | 2 |
chasm22 | [686] | 1 | 0 | 0 |
chaswolf | [1160] | 0 | 0 | 1 |
CheapThrills | [186] | 1 | 0 | 0 |
cheesecheeks | [812] | 0 | 1 | 0 |
cheffernan | [1230] | 0 | 0 | 1 |
Chemicalkraken | [1720] | 0 | 0 | 1 |
chi2 | [1665] | 0 | 0 | 1 |
ChibiM | [504] | 1 | 0 | 0 |
Chicken Drumstick | [15] | 0 | 1 | 0 |
Chito | [1332] | 0 | 0 | 1 |
chives12 | [1746] | 0 | 0 | 1 |
chokobo | [510] | 0 | 1 | 0 |
chooma | [59] | 1 | 0 | 0 |
chops728 | [636] | 1 | 0 | 0 |
chrisc | [ 89 1620] | 1 | 0 | 1 |
chrispc | [1464] | 0 | 0 | 1 |
christoph | [1232 1315] | 0 | 0 | 2 |
cittroman | [1408] | 0 | 0 | 1 |
cj_86 | [1193] | 0 | 0 | 1 |
CJW | [220] | 0 | 1 | 0 |
clange50 | [526] | 1 | 0 | 0 |
Clarence222 | [1697 1702] | 0 | 0 | 2 |
ClaudeMBallz | [492] | 1 | 0 | 0 |
claywalker0929 | [1710] | 0 | 0 | 1 |
clinicdoc | [444] | 1 | 0 | 0 |
Cliwilnew | [218] | 1 | 0 | 0 |
cloggy | [124] | 0 | 1 | 0 |
Clovis Point | [1458] | 0 | 0 | 1 |
cmflippen | [74] | 1 | 0 | 0 |
cody | [1532] | 0 | 0 | 1 |
CodyWolfeMusic | [926] | 0 | 1 | 0 |
Coheed1121 | [1688] | 0 | 0 | 1 |
ColdFusion | [580] | 1 | 0 | 0 |
comeintothelight | [1256] | 0 | 0 | 1 |
ConcreteTurtle | [857] | 0 | 1 | 0 |
congo | [1111] | 0 | 0 | 1 |
Couchmaster | [207] | 1 | 0 | 0 |
Coughitup | [863] | 0 | 1 | 0 |
Count Zero | [1028] | 0 | 1 | 0 |
COWBOY306 | [ 999 1000] | 0 | 2 | 0 |
Coyotehawk | [1292 1293 1294] | 0 | 0 | 3 |
crackrat | [898] | 0 | 1 | 0 |
Cranky64 | [971] | 0 | 1 | 0 |
CrashOne | [471] | 1 | 0 | 0 |
crayton | [1631] | 0 | 0 | 1 |
Crazyeddie | [582] | 1 | 0 | 0 |
cressdrvr | [766] | 0 | 1 | 0 |
Crushfield | [1629 1630] | 0 | 0 | 2 |
crx88ia | [111] | 1 | 0 | 0 |
crz6662 | [153] | 1 | 0 | 0 |
csteene | [1214 1371] | 0 | 0 | 2 |
Curetia | [528] | 1 | 0 | 0 |
Cutchya | [ 792 793 1470] | 0 | 2 | 1 |
cypher1024 | [ 449 704 1474] | 1 | 1 | 1 |
CYRIL | [1414] | 0 | 0 | 1 |
Cyzan | [1686] | 0 | 0 | 1 |
D-DUB | [1040] | 0 | 1 | 0 |
D10ten | [601] | 1 | 0 | 0 |
dabaum_85 | [1342] | 0 | 0 | 1 |
Dadpool | [664] | 1 | 0 | 0 |
Dan9571 | [1567] | 0 | 0 | 1 |
danallen | [1554] | 0 | 0 | 1 |
Dannyboyy | [1002 1003] | 0 | 2 | 0 |
dariman3 | [ 938 1662] | 0 | 1 | 1 |
DarkerInSol | [301 302] | 1 | 1 | 0 |
Darkestarc | [1075] | 0 | 0 | 1 |
darkpenguin | [ 2 199] | 2 | 0 | 0 |
darowi | [1153] | 0 | 0 | 1 |
darrenm | [588] | 1 | 0 | 0 |
darthmater | [514] | 1 | 0 | 0 |
DarthTader | [257 888] | 1 | 1 | 0 |
DasEtwas | [270] | 0 | 1 | 0 |
davidkappelt | [706] | 1 | 0 | 0 |
DBSAR | [79] | 1 | 0 | 0 |
DBSS | [191 829 856] | 1 | 2 | 0 |
DeadSquirrely | [1386] | 0 | 0 | 1 |
deathless | [221 915] | 1 | 1 | 0 |
DeepCCoug | [775] | 0 | 1 | 0 |
Defiars2 | [1721] | 0 | 0 | 1 |
degringolader | [1083 1328 1329] | 0 | 0 | 3 |
delight | [1475] | 0 | 0 | 1 |
DELLBERTS | [1243] | 0 | 0 | 1 |
Delta_Frog | [1220] | 0 | 0 | 1 |
Denalirotts | [1650] | 0 | 0 | 1 |
DENGOH | [ 895 1402 1616] | 0 | 1 | 2 |
Dennis Bieniek | [1194] | 0 | 0 | 1 |
dentillozie | [615] | 0 | 1 | 0 |
Dep668 | [9] | 1 | 0 | 0 |
derbi | [1238] | 0 | 0 | 1 |
derpilgerer | [140] | 1 | 0 | 0 |
destro | [1534 1753] | 0 | 0 | 2 |
Dewalt101 | [ 754 1677] | 1 | 0 | 1 |
deye223 | [377] | 0 | 1 | 0 |
dhsvcs | [258] | 1 | 0 | 0 |
digitalMessiah | [669] | 1 | 0 | 0 |
diligenthunter | [1570] | 0 | 0 | 1 |
dimitris | [989] | 0 | 1 | 0 |
DIPSTIX | [1411] | 0 | 0 | 1 |
DiscoJoe | [557] | 1 | 0 | 0 |
DisLilLiteOfMine | [1246] | 0 | 0 | 1 |
djburkes | [16] | 1 | 0 | 0 |
djozz | [465] | 1 | 0 | 0 |
DJUnreal | [517] | 1 | 0 | 0 |
djypo | [728] | 1 | 0 | 0 |
Dmitriyrus | [151] | 0 | 1 | 0 |
dmsoule | [ 822 1653] | 0 | 1 | 1 |
DOCFAR | [425] | 1 | 0 | 0 |
Docp723 | [208 209] | 0 | 2 | 0 |
dodo | [73] | 1 | 0 | 0 |
DOHC20 | [562] | 1 | 0 | 0 |
Don.valk | [1287] | 0 | 0 | 1 |
DoNkEyConN | [ 813 826 1703] | 0 | 2 | 1 |
donnieol | [908] | 0 | 1 | 0 |
donttellmywifeiambuyinganotherlight | [1171] | 0 | 0 | 1 |
DooMMasteR | [726] | 1 | 0 | 0 |
dougjones31 | [1387] | 0 | 0 | 1 |
downlinx | [233] | 0 | 1 | 0 |
Dragonatorrr | [1128] | 0 | 0 | 1 |
Dralf | [230 231] | 1 | 1 | 0 |
Dregs | [623] | 0 | 1 | 0 |
DriftMonkey206 | [1480] | 0 | 0 | 1 |
drjamesfox | [710] | 1 | 0 | 0 |
drood | [216 596] | 1 | 1 | 0 |
druidmars | [1261] | 0 | 0 | 1 |
dsiddens | [612] | 1 | 0 | 0 |
dstuhr | [1148] | 0 | 0 | 1 |
dthrckt | [1199] | 0 | 0 | 1 |
DTS Savannah | [1248 1249] | 0 | 0 | 2 |
Duke | [537] | 1 | 0 | 0 |
dukeface13 | [977] | 0 | 1 | 0 |
dummytim | [809] | 0 | 1 | 0 |
dunklerfox | [1187] | 0 | 0 | 1 |
Dustynell | [271] | 1 | 0 | 0 |
Dutcheee | [172] | 1 | 0 | 0 |
Dwantink | [122] | 1 | 0 | 0 |
Dydi92 | [ 484 1758] | 1 | 0 | 1 |
e10sno | [190] | 1 | 0 | 0 |
EagleShield | [913] | 0 | 1 | 0 |
ecobalans | [1507] | 0 | 0 | 1 |
EDCPlus | [817] | 0 | 1 | 0 |
Edness | [ 626 1737] | 0 | 1 | 1 |
eekazum | [637 707 708] | 1 | 2 | 0 |
EggsnBacon | [1504] | 0 | 0 | 1 |
Eggun | [384] | 1 | 0 | 0 |
egrep | [ 910 1723] | 0 | 1 | 1 |
eigenmeat | [1108] | 0 | 0 | 1 |
Eivwer | [57] | 0 | 1 | 0 |
ejschmitt | [1541] | 0 | 0 | 1 |
electricjelly | [ 28 1754] | 1 | 0 | 1 |
Elephant007 | [1135] | 0 | 0 | 1 |
ElginAgain | [735] | 1 | 0 | 0 |
elpaulo | [1624] | 0 | 0 | 1 |
elrcpilot | [1228] | 0 | 0 | 1 |
emarkd | [18] | 1 | 0 | 0 |
enesrap | [238] | 0 | 0 | 1 |
Epsilon748 | [661] | 1 | 0 | 0 |
Eraursls1984 | [353] | 1 | 0 | 0 |
eric800 | [323] | 0 | 1 | 0 |
erick_151 | [944] | 0 | 1 | 0 |
ErrolRS | [768] | 1 | 0 | 0 |
ersecu | [874] | 0 | 1 | 0 |
Erwin18 | [1755] | 0 | 0 | 1 |
Essexman | [478] | 1 | 0 | 0 |
evgen2004 | [1463] | 0 | 0 | 1 |
Evo1986 | [693] | 1 | 0 | 0 |
F.i.l.a.s | [1022] | 0 | 1 | 0 |
f1rstb81 | [1761] | 0 | 0 | 1 |
fabiomars | [1339] | 0 | 0 | 1 |
Falconda | [1181] | 0 | 0 | 1 |
famous36 | [382] | 0 | 1 | 0 |
fantomR | [752] | 1 | 0 | 0 |
Far Thrower | [ 947 1443] | 0 | 1 | 1 |
fberna | [1266] | 0 | 0 | 1 |
FBsLights | [226] | 1 | 0 | 0 |
fed893 | [616] | 1 | 0 | 0 |
feetball | [1305] | 0 | 0 | 1 |
feilox | [1271] | 0 | 0 | 1 |
FHAREN | [1335] | 0 | 0 | 1 |
Fighterplane1956 | [1212 1213] | 0 | 0 | 2 |
firedome | [351] | 0 | 1 | 0 |
Fjrjim | [1284] | 0 | 0 | 1 |
Flanny | [531] | 1 | 0 | 0 |
flaschi | [545] | 1 | 0 | 0 |
Flash-O-Maniac | [406] | 1 | 0 | 0 |
flashaholic1 | [1591] | 0 | 0 | 1 |
Flashalot111 | [1307] | 0 | 0 | 1 |
Flashem | [1607] | 0 | 0 | 1 |
Flasher2 | [1358] | 0 | 0 | 1 |
flasher96 | [852] | 0 | 1 | 0 |
FlashIight | [1664] | 0 | 0 | 1 |
flashlightfrenzy | [892 893] | 0 | 2 | 0 |
FlashMax | [293] | 1 | 0 | 0 |
FlashPilot | [147] | 1 | 0 | 0 |
flasky | [712] | 1 | 0 | 0 |
Fldub | [1632] | 0 | 0 | 1 |
flinders_72 | [1140] | 0 | 0 | 1 |
fluffman86 | [1086 1432] | 0 | 0 | 2 |
Flusher | [1255] | 0 | 0 | 1 |
Flybar | [1063] | 0 | 0 | 1 |
flybird | [ 632 1698] | 1 | 0 | 1 |
Flying Luminosity | [973] | 0 | 1 | 0 |
FmC | [ 729 1556] | 1 | 0 | 1 |
FMcamaroZ28 | [1729] | 0 | 0 | 1 |
fonfan | [58] | 1 | 0 | 0 |
fonLED | [1180] | 0 | 0 | 1 |
foton | [359] | 0 | 1 | 0 |
FrankFlash | [547] | 1 | 0 | 0 |
Frankie Baby | [294] | 0 | 1 | 0 |
Franz | [573] | 1 | 0 | 0 |
Fred Fortney | [1468] | 0 | 0 | 1 |
Fredylee | [309] | 0 | 1 | 0 |
FreeMagenta | [375] | 1 | 0 | 0 |
freeme | [490] | 0 | 1 | 0 |
freethink | [1055] | 0 | 0 | 1 |
frissonic | [1588] | 0 | 0 | 1 |
FritzHID | [887] | 0 | 1 | 0 |
Frost1235 | [1068] | 0 | 0 | 1 |
froz | [911] | 0 | 1 | 0 |
Fubs261 | [1594] | 0 | 0 | 1 |
funkycowboy | [1419] | 0 | 0 | 1 |
fusion_m8 | [1065] | 0 | 0 | 1 |
fuzun | [407 685] | 0 | 2 | 0 |
fuzzyvader | [931] | 0 | 1 | 0 |
G0OSE | [49] | 1 | 0 | 0 |
g_sintornillos | [ 51 1379] | 1 | 0 | 1 |
GameOfDeath | [690] | 1 | 0 | 0 |
gamezawy | [143] | 1 | 0 | 0 |
gangstead | [103] | 1 | 0 | 0 |
Garfield189 | [1062] | 0 | 0 | 1 |
gastonpatagonico | [890] | 0 | 1 | 0 |
geepaw | [627] | 1 | 0 | 0 |
Geese | [622] | 1 | 0 | 0 |
gehrmo | [455] | 0 | 1 | 0 |
George7806 | [1735] | 0 | 0 | 1 |
Gerald Wright | [1301 1511] | 0 | 0 | 2 |
Gerrh | [ 35 175 176 427 428] | 0 | 5 | 0 |
Gerrit | [41] | 1 | 0 | 0 |
GF357 | [1401] | 0 | 0 | 1 |
GHOSTSS | [1076 1077] | 0 | 0 | 2 |
Giancarlo | [1192 1555] | 0 | 0 | 2 |
gigbyt | [403] | 1 | 0 | 0 |
giorgoskok | [ 5 98 99 100] | 1 | 3 | 0 |
Giovanni Delle Foglie | [1082] | 0 | 0 | 1 |
Gj | [ 621 1361 1445 1668 1669] | 1 | 0 | 4 |
Gladimir_Gluten | [719] | 1 | 0 | 0 |
gleamer | [634] | 0 | 1 | 0 |
Glenn7 | [823] | 0 | 1 | 0 |
GlinnDamar | [982] | 0 | 1 | 0 |
gloomywarfreak | [325] | 1 | 0 | 0 |
Glov | [1144] | 0 | 0 | 1 |
Gman | [1498] | 0 | 0 | 1 |
gman7228 | [1130] | 0 | 0 | 1 |
Goatkeepers | [1676] | 0 | 0 | 1 |
GoMeR | [1430 1461] | 0 | 0 | 2 |
Goodtobeking | [1690] | 0 | 0 | 1 |
gorky | [96] | 1 | 0 | 0 |
goshdogit | [198] | 1 | 0 | 0 |
GozonM | [1377] | 0 | 0 | 1 |
gravelmonkey | [ 340 1501] | 2 | 0 | 0 |
Greener | [1007] | 0 | 1 | 0 |
Greenterror2112 | [1029] | 0 | 1 | 0 |
greg | [410] | 1 | 0 | 0 |
gregor | [116] | 1 | 0 | 0 |
Griley89 | [1704] | 0 | 0 | 1 |
GroinOfSteel | [663] | 1 | 0 | 0 |
GrumpyCoffee | [1047] | 0 | 1 | 0 |
gtaguy235 | [1306] | 0 | 0 | 1 |
gtxxl | [1099] | 0 | 0 | 1 |
gungoat | [70] | 1 | 0 | 0 |
Guns712 | [535] | 1 | 0 | 0 |
Gunslinger686 | [773 774] | 0 | 2 | 0 |
Gwest | [1354 1446] | 0 | 0 | 2 |
gyros-pita | [799] | 0 | 1 | 0 |
h5550 | [1155] | 0 | 0 | 1 |
hampshire | [102] | 0 | 1 | 0 |
hardlybowing | [1304] | 0 | 0 | 1 |
Hardusvd70 | [882 891 897 927] | 0 | 4 | 0 |
Hardware | [716] | 1 | 0 | 0 |
harty73 | [724] | 1 | 0 | 0 |
HAWK | [1288] | 0 | 0 | 1 |
Hayseed | [957] | 0 | 1 | 0 |
hazG | [1166] | 0 | 0 | 1 |
heatwaves | [552] | 1 | 0 | 0 |
heikman | [1489] | 0 | 0 | 1 |
Hemietr06 | [1031] | 0 | 1 | 0 |
Henk4U2 | [589] | 1 | 0 | 0 |
henningap | [1073] | 0 | 0 | 1 |
hex1979 | [1608] | 0 | 0 | 1 |
Hezekiah | [666] | 1 | 0 | 0 |
HighCaliber | [189] | 1 | 0 | 0 |
hikearound | [ 992 1001] | 0 | 2 | 0 |
Hiperdart | [1439] | 0 | 0 | 1 |
hippotomato | [1469 1663] | 0 | 0 | 2 |
hjalti | [1599] | 0 | 0 | 1 |
hksmatrix | [1547] | 0 | 0 | 1 |
hoekjor | [1152] | 0 | 0 | 1 |
Hombreluhrs | [788 789] | 0 | 2 | 0 |
Hoosierrunner | [1410] | 0 | 0 | 1 |
Hootbubba | [1351] | 0 | 0 | 1 |
Hovsky | [1204] | 0 | 0 | 1 |
howlin4you | [1583] | 0 | 0 | 1 |
hron61 | [1186 1575] | 0 | 0 | 2 |
Hugh Johnson | [1149] | 0 | 0 | 1 |
HughQ | [953] | 0 | 1 | 0 |
Hully86 | [1601] | 0 | 0 | 1 |
Hundelampe | [533] | 0 | 1 | 0 |
Hunter | [1685] | 0 | 0 | 1 |
hunter1 | [ 55 1373] | 1 | 0 | 1 |
Hunter29078 | [1456 1457] | 0 | 0 | 2 |
I73770k | [1054] | 0 | 0 | 1 |
I_like_lamb | [457] | 1 | 0 | 0 |
Icarus | [ 275 1701] | 1 | 0 | 1 |
igeigeige | [399] | 0 | 1 | 0 |
IH8MYX | [1196] | 0 | 0 | 1 |
Iktinos | [1285] | 0 | 0 | 1 |
Ilellero | [433] | 0 | 1 | 0 |
ILIKEFLASHLIGHTS | [968] | 0 | 1 | 0 |
Illuminati | [1184] | 0 | 0 | 1 |
illusum | [739] | 1 | 0 | 0 |
Ilmatic | [558] | 1 | 0 | 0 |
ilovejesuschrist | [409] | 0 | 1 | 0 |
ImA4Wheelr | [66] | 1 | 0 | 0 |
ImagioX1 | [1545] | 0 | 0 | 1 |
IndyArcher | [ 493 1450] | 1 | 0 | 1 |
Innerlight | [527] | 1 | 0 | 0 |
inphinity | [811] | 0 | 1 | 0 |
iron potato | [268] | 1 | 0 | 0 |
IronManMosier | [1011 1012] | 0 | 2 | 0 |
Irvinh8767 | [1658] | 0 | 0 | 1 |
Iselldrugsforgolf | [1657] | 0 | 0 | 1 |
ISO | [130 655] | 1 | 1 | 0 |
istrayli | [1203] | 0 | 0 | 1 |
itchy96 | [1705] | 0 | 0 | 1 |
Itsme | [ 734 1343] | 1 | 0 | 1 |
itsme5k | [ 164 1722] | 1 | 0 | 1 |
itsonlyme | [339] | 0 | 1 | 0 |
izkidd | [801 802] | 0 | 2 | 0 |
J-Dub74 | [167] | 1 | 0 | 0 |
j0sh | [374] | 1 | 0 | 0 |
j8048188 | [1553 1747] | 0 | 0 | 2 |
jack-bkk | [223] | 0 | 1 | 0 |
jack83 | [644] | 1 | 0 | 0 |
Jalben | [368] | 1 | 0 | 0 |
jama | [289] | 1 | 0 | 0 |
jamaya | [790 909] | 0 | 2 | 0 |
james y | [ 369 1725] | 1 | 0 | 1 |
JamesB | [31] | 1 | 0 | 0 |
jamio | [1521] | 0 | 0 | 1 |
JanS | [1027] | 0 | 1 | 0 |
JaredM | [242] | 1 | 0 | 0 |
Jarms | [1009 1010] | 0 | 2 | 0 |
jasaero | [1587] | 0 | 0 | 1 |
JasonB1993 | [838] | 0 | 1 | 0 |
JasonWW | [912] | 0 | 1 | 0 |
JAthe1ST | [1162] | 0 | 0 | 1 |
jatle | [702] | 1 | 0 | 0 |
jaynick | [364] | 1 | 0 | 0 |
JayWallis | [ 609 1503] | 1 | 0 | 1 |
Jaza | [ 305 1618] | 1 | 0 | 1 |
jazzyone1212 | [1167] | 0 | 0 | 1 |
Jbraman | [1636] | 0 | 0 | 1 |
Jeansy | [64] | 0 | 0 | 1 |
Jeffstanton | [602] | 0 | 1 | 0 |
Jensa41 | [438] | 1 | 0 | 0 |
Jerommel | [458] | 1 | 0 | 0 |
jerrod | [299] | 1 | 0 | 0 |
jerrytx | [584] | 1 | 0 | 0 |
jescereal | [522 523] | 1 | 1 | 0 |
Jesjes | [205] | 0 | 1 | 0 |
JesperW | [1236] | 0 | 0 | 1 |
JETMOTO21 | [1359] | 0 | 0 | 1 |
Jhicks2018 | [1684] | 0 | 0 | 1 |
Jiffy | [1520] | 0 | 0 | 1 |
JIGHEADWORM | [705] | 1 | 0 | 0 |
Jimmy007 | [298] | 1 | 0 | 0 |
jimmy23 | [569] | 1 | 0 | 0 |
jingleberry | [354] | 0 | 1 | 0 |
JJMcGee83 | [670] | 1 | 0 | 0 |
Jkatalik4 | [988] | 0 | 1 | 0 |
jkbam | [272] | 1 | 0 | 0 |
jlemond | [1726] | 0 | 0 | 1 |
JLM86 | [1298] | 0 | 0 | 1 |
JM87 | [ 560 1459] | 1 | 0 | 1 |
Jmiddlebrook | [914] | 0 | 1 | 0 |
jmm244 | [1438] | 0 | 0 | 1 |
jmoots | [232] | 1 | 0 | 0 |
jmpaul320 | [194] | 1 | 0 | 0 |
Joat | [516] | 1 | 0 | 0 |
JockRobbins | [165] | 0 | 1 | 0 |
joel95ex | [591] | 1 | 0 | 0 |
JoeRodge | [1605] | 0 | 0 | 1 |
Joey Adams | [371] | 1 | 0 | 0 |
JOHN PYRAMID | [1484 1485] | 0 | 0 | 2 |
JohnCalvin | [1291] | 0 | 0 | 1 |
johnjohn | [604] | 1 | 0 | 0 |
Johny | [975] | 0 | 1 | 0 |
johny723 | [34] | 1 | 0 | 0 |
jonathandowers | [1585] | 0 | 0 | 1 |
JonnyC | [ 993 1131] | 0 | 1 | 1 |
Jorgen | [1016 1017 1612 1613] | 0 | 2 | 2 |
JorisFRST | [680 825] | 1 | 1 | 0 |
joseabul | [420] | 1 | 0 | 0 |
josephhendrix | [1641] | 0 | 0 | 1 |
Jouna | [972] | 0 | 1 | 0 |
JPG | [1250] | 0 | 0 | 1 |
JPLight | [360 361] | 1 | 1 | 0 |
JPM3 | [ 800 1558] | 0 | 1 | 1 |
Jryeping | [1281] | 0 | 0 | 1 |
jscan | [315] | 1 | 0 | 0 |
jsmn4vu | [736] | 1 | 0 | 0 |
JStyle | [1738] | 0 | 0 | 1 |
jtechl | [864] | 0 | 1 | 0 |
jtedder1967 | [783 987] | 0 | 2 | 0 |
jtq | [1211] | 0 | 0 | 1 |
jturn480 | [974] | 0 | 1 | 0 |
Juandre | [1568] | 0 | 0 | 1 |
juaquin | [288] | 1 | 0 | 0 |
juddvong | [889] | 0 | 1 | 0 |
Jump909 | [1741] | 0 | 0 | 1 |
JumpingJackflas… | [1637] | 0 | 0 | 1 |
junkman88 | [1750] | 0 | 0 | 1 |
justanotherguy | [ 844 1409] | 0 | 1 | 1 |
Juusto | [1428] | 0 | 0 | 1 |
jveneziano | [ 837 1102] | 0 | 1 | 1 |
Jvrthp321 | [286 394] | 0 | 2 | 0 |
k125bw | [1104 1441] | 0 | 0 | 2 |
k2-bk-bl-rd | [1660] | 0 | 0 | 1 |
Kafar | [429] | 0 | 1 | 0 |
kahvitahra | [981] | 0 | 1 | 0 |
KaiserSosa | [ 432 1656] | 1 | 0 | 1 |
Kalihi | [487] | 1 | 0 | 0 |
Kasi55 | [1233] | 0 | 0 | 1 |
KawiBoy1428 | [ 10 193] | 0 | 2 | 0 |
KayakMikeP | [1465] | 0 | 0 | 1 |
kaybi | [ 295 1499] | 1 | 0 | 1 |
Kbdrake07 | [1133] | 0 | 0 | 1 |
KCSmith | [1097] | 0 | 0 | 1 |
KDM | [1715] | 0 | 0 | 1 |
Kdoggy94 | [806] | 0 | 1 | 0 |
kebal_omega | [990] | 0 | 1 | 0 |
keengeorge | [412 413] | 1 | 1 | 0 |
Keepitsharp | [ 12 1679] | 1 | 0 | 1 |
Keisari | [437] | 1 | 0 | 0 |
keithd | [6] | 1 | 0 | 0 |
keithober | [859] | 0 | 1 | 0 |
Kemikos | [1201] | 0 | 0 | 1 |
Kendo | [1210] | 0 | 0 | 1 |
Kenjii | [123] | 1 | 0 | 0 |
Kent Lake | [1760] | 0 | 0 | 1 |
kevinfc | [570] | 0 | 1 | 0 |
Khameleon | [1087] | 0 | 0 | 1 |
khr | [1251] | 0 | 0 | 1 |
Khuan | [23] | 1 | 0 | 0 |
Kindle | [ 154 1375] | 1 | 0 | 1 |
King201002 | [1380] | 0 | 0 | 1 |
Kingjohn | [1049 1338] | 0 | 1 | 1 |
Kinniver | [1538] | 0 | 0 | 1 |
Kit Latura | [518] | 1 | 0 | 0 |
Kjosn | [1143] | 0 | 0 | 1 |
Kkelleher | [922 923] | 0 | 2 | 0 |
KlementinSwede | [955] | 0 | 1 | 0 |
kml1987 | [1052] | 0 | 0 | 1 |
KnifeNutsJake | [689] | 1 | 0 | 0 |
Knox8992 | [949] | 0 | 1 | 0 |
kntx | [269] | 1 | 0 | 0 |
knudsengj | [250] | 0 | 1 | 0 |
Koaksijalac | [95] | 0 | 1 | 0 |
Kodachrome40 | [ 146 1415] | 0 | 1 | 1 |
koenigsegg | [1154] | 0 | 0 | 1 |
kommessy | [63] | 1 | 0 | 0 |
korpzgrinda | [381] | 1 | 0 | 0 |
KOSTA88 | [1295 1296] | 0 | 0 | 2 |
kotobuki | [211] | 1 | 0 | 0 |
Kourtinoksylo | [366] | 0 | 1 | 0 |
koyotee | [ 534 1647] | 1 | 0 | 1 |
Kozy | [88] | 1 | 0 | 0 |
krazypoloc | [1141] | 0 | 0 | 1 |
Kristmann | [1600] | 0 | 0 | 1 |
Krisz1100 | [1297 1324] | 0 | 0 | 2 |
krutone | [551] | 0 | 1 | 0 |
KuanR | [650] | 0 | 1 | 0 |
Kulumatic | [240] | 1 | 0 | 0 |
Kurdolf | [134] | 1 | 0 | 0 |
Kurt_Norway | [ 97 105 808] | 1 | 2 | 0 |
kvnyay | [1549] | 0 | 0 | 1 |
KW | [349] | 1 | 0 | 0 |
kyleharleyanderton | [933] | 0 | 1 | 0 |
l1mb0 | [499] | 1 | 0 | 0 |
Lamboboy732 | [900] | 0 | 1 | 0 |
LandoLakes | [755] | 1 | 0 | 0 |
Larryd888 | [1145 1146 1147] | 0 | 0 | 3 |
lawallac | [ 61 1444] | 1 | 0 | 1 |
lcortez321 | [879] | 0 | 1 | 0 |
leaftye | [633] | 1 | 0 | 0 |
LeatherJacket | [1673] | 0 | 0 | 1 |
ledalex | [778] | 0 | 1 | 0 |
LEDtec | [219 758] | 1 | 1 | 0 |
lelantosthrow | [692] | 0 | 1 | 0 |
lenniehawk | [1565] | 0 | 0 | 1 |
lennshow66 | [1272] | 0 | 0 | 1 |
LenZ | [833 834] | 0 | 2 | 0 |
Lepricahn1955 | [1433] | 0 | 0 | 1 |
leroycp | [ 17 348] | 1 | 1 | 0 |
LessDark | [316] | 0 | 1 | 0 |
lewc | [1589] | 0 | 0 | 1 |
Lexel | [1635] | 0 | 0 | 1 |
Lfatman | [135] | 1 | 0 | 0 |
Liber8 | [86] | 0 | 1 | 0 |
lichtpfadfinder | [447] | 1 | 0 | 0 |
light junkie | [255 593 630] | 0 | 3 | 0 |
light up | [594] | 1 | 0 | 0 |
Light Years | [846] | 0 | 1 | 0 |
Light11 | [1719] | 0 | 0 | 1 |
lightknot | [751] | 1 | 0 | 0 |
lightlight22 | [ 342 1743] | 1 | 0 | 1 |
Lights-Out | [276 277 282 283] | 2 | 2 | 0 |
lightsoff | [1622 1683] | 0 | 0 | 2 |
lionheart_2281 | [26] | 1 | 0 | 0 |
Lipfit2000 | [559] | 1 | 0 | 0 |
Lips | [1713] | 0 | 0 | 1 |
Litefighter | [761] | 1 | 0 | 0 |
litenutz | [1695] | 0 | 0 | 1 |
LloydV | [225] | 1 | 0 | 0 |
lolcat | [1497] | 0 | 0 | 1 |
Lone Eagle | [639] | 1 | 0 | 0 |
LongN159 | [1752] | 0 | 0 | 1 |
Longtom | [1602] | 0 | 0 | 1 |
Lopan | [350] | 1 | 0 | 0 |
LSX | [82] | 1 | 0 | 0 |
Lumen_Dodger | [1572] | 0 | 0 | 1 |
lumenhunter | [1123] | 0 | 0 | 1 |
Luminental | [ 732 1138] | 1 | 0 | 1 |
Luminosity | [1518 1519 1740] | 0 | 0 | 3 |
LuminousIgnis | [ 787 1707] | 0 | 1 | 1 |
Lund1660 | [ 142 1596] | 1 | 0 | 1 |
Lyubo Yanev | [159 160 657] | 1 | 2 | 0 |
m000 | [1473] | 0 | 0 | 1 |
M3L8BQMjr2m | [656] | 1 | 0 | 0 |
M78 | [13] | 1 | 0 | 0 |
mack303 | [1543 1544] | 0 | 0 | 2 |
macktastic | [513] | 1 | 0 | 0 |
MACS0647 | [520] | 1 | 0 | 0 |
MAD777 | [635] | 1 | 0 | 0 |
Maggats2 | [1303 1388] | 0 | 0 | 2 |
magnet | [314] | 1 | 0 | 0 |
MagPap | [253] | 1 | 0 | 0 |
Maiden666 | [539] | 1 | 0 | 0 |
maildroid | [ 590 1378] | 1 | 0 | 1 |
Mainstream | [1533] | 0 | 0 | 1 |
Majoroverkill | [304] | 1 | 0 | 0 |
makapuu | [934] | 0 | 1 | 0 |
malamask | [114] | 1 | 0 | 0 |
malcolmb | [1021] | 0 | 1 | 0 |
MaleNurse | [278] | 1 | 0 | 0 |
Maliblue | [960] | 0 | 1 | 0 |
Mallow | [1048] | 0 | 1 | 0 |
Manimok | [598] | 1 | 0 | 0 |
ManWithoutShadow | [1331] | 0 | 0 | 1 |
manxbuggy1 | [744 785] | 1 | 1 | 0 |
Mapster | [918] | 0 | 1 | 0 |
Marcello | [777] | 0 | 1 | 0 |
Marcopolo86c | [940] | 0 | 1 | 0 |
marius21 | [1661] | 0 | 0 | 1 |
MarkoNW | [952] | 0 | 1 | 0 |
marsalla | [338] | 1 | 0 | 0 |
Martini | [203] | 0 | 1 | 0 |
martook | [606] | 1 | 0 | 0 |
MartWilliams | [1176] | 0 | 0 | 1 |
martytown | [748] | 1 | 0 | 0 |
Marvin8 | [1407] | 0 | 0 | 1 |
Masejoer | [261] | 1 | 0 | 0 |
Mastorakos | [996] | 0 | 1 | 0 |
mattar12 | [1651] | 0 | 0 | 1 |
mattardel | [805] | 0 | 1 | 0 |
Mattfox27 | [963 985] | 0 | 2 | 0 |
mattlward | [7] | 1 | 0 | 0 |
mattyd58 | [961] | 0 | 1 | 0 |
maukka | [75] | 1 | 0 | 0 |
Maverick1947 | [1700] | 0 | 0 | 1 |
mazda96hatch | [1139] | 0 | 0 | 1 |
mazer0001 | [1312] | 0 | 0 | 1 |
MBuitendorp | [477] | 1 | 0 | 0 |
MCT | [118] | 1 | 0 | 0 |
mdeni | [182] | 0 | 1 | 0 |
Mecallie | [357] | 1 | 0 | 0 |
Megabassie | [597] | 1 | 0 | 0 |
megathrower2017 | [1578] | 0 | 0 | 1 |
Metallurgist | [1241] | 0 | 0 | 1 |
meti | [1217] | 0 | 0 | 1 |
mezzmen7 | [587] | 1 | 0 | 0 |
mgorshe95 | [1239 1240 1362] | 0 | 0 | 3 |
mgracia85 | [1340] | 0 | 0 | 1 |
mhanlen | [81] | 1 | 0 | 0 |
michael.k | [466] | 1 | 0 | 0 |
MichaelA | [1537] | 0 | 0 | 1 |
michaellee64 | [958] | 0 | 1 | 0 |
MichielSanders | [1580] | 0 | 0 | 1 |
mickscot | [780] | 0 | 0 | 1 |
mickscott | [ 779 1355] | 0 | 2 | 0 |
Migacz112 | [1550] | 0 | 0 | 1 |
Mikael | [482 555] | 1 | 1 | 0 |
Mike9028 | [1427] | 0 | 0 | 1 |
MikeH | [1350] | 0 | 0 | 1 |
mikelights | [1508] | 0 | 0 | 1 |
Mindaugass | [254 266] | 0 | 2 | 0 |
Minty | [869 870] | 0 | 2 | 0 |
Mitko | [3] | 1 | 0 | 0 |
mizou51 | [235] | 1 | 0 | 0 |
mjgsxr | [721] | 1 | 0 | 0 |
mk4off | [431] | 0 | 1 | 0 |
Mkduffer | [344] | 1 | 0 | 0 |
ML1 | [1122] | 0 | 0 | 1 |
mlodyulek | [1495] | 0 | 0 | 1 |
mmalive | [1392 1517] | 0 | 0 | 2 |
mnautox | [1593] | 0 | 0 | 1 |
Modden | [538] | 1 | 0 | 0 |
Modestep | [1742] | 0 | 0 | 1 |
Modulor | [162] | 1 | 0 | 0 |
Moelns12 | [1269] | 0 | 0 | 1 |
Momo | [1574] | 0 | 0 | 1 |
Mongoose49 | [865] | 0 | 1 | 0 |
moomoosan | [1085] | 0 | 0 | 1 |
Mops1 | [1113 1437] | 0 | 0 | 2 |
moptrf | [1633] | 0 | 0 | 1 |
Mord_Fustang | [1129] | 0 | 0 | 1 |
moretorque05 | [1125] | 0 | 0 | 1 |
Morgy | [505] | 1 | 0 | 0 |
moridin | [332] | 1 | 0 | 0 |
morning_wood | [1372 1628] | 0 | 0 | 2 |
MorpheusT1 | [149] | 1 | 0 | 0 |
MortyDuck | [128] | 1 | 0 | 0 |
MountainMan | [550] | 1 | 0 | 0 |
mphlorin | [1179] | 0 | 0 | 1 |
Mr McLumen | [1142 1279] | 0 | 0 | 2 |
Mr.Poppy | [688 745 746 871 872] | 1 | 4 | 0 |
Mr.Scott | [94] | 1 | 0 | 0 |
mradeck | [1050] | 0 | 0 | 1 |
MRDOOLEY | [1096] | 0 | 0 | 1 |
mrheosuper | [177] | 1 | 0 | 0 |
mrod67 | [ 978 1667] | 0 | 1 | 1 |
MRsDNF | [ 701 1020] | 1 | 1 | 0 |
mrstealyourgains | [367] | 1 | 0 | 0 |
mstephens22 | [515] | 0 | 1 | 0 |
Mt.B | [1431] | 0 | 0 | 1 |
mtrsteadman | [1694] | 0 | 0 | 1 |
mtsuther | [1247] | 0 | 0 | 1 |
mugs | [939] | 0 | 1 | 0 |
musso1 | [1529] | 0 | 0 | 1 |
Mustang90 | [1277] | 0 | 0 | 1 |
mustig | [1506] | 0 | 0 | 1 |
muthagoose | [1316] | 0 | 0 | 1 |
Muto | [155 156] | 2 | 0 | 0 |
Mwsilverado09 | [1341] | 0 | 0 | 1 |
mxyzptlk | [1198] | 0 | 0 | 1 |
Myers | [741] | 1 | 0 | 0 |
Myrdden | [1423 1424 1471] | 0 | 0 | 3 |
Narwhals | [810] | 0 | 1 | 0 |
Natasha | [603] | 1 | 0 | 0 |
Natasha Bernardo | [1320] | 0 | 0 | 1 |
Nathan42 | [579] | 1 | 0 | 0 |
Nav88 | [1188] | 0 | 0 | 1 |
nbjly | [1105] | 0 | 0 | 1 |
NCled | [804] | 0 | 1 | 0 |
needmorlts | [252 306] | 0 | 2 | 0 |
Neomis | [1006] | 0 | 1 | 0 |
netgear68 | [115] | 1 | 0 | 0 |
netprince | [ 32 1678] | 1 | 0 | 1 |
Nev | [1310 1611] | 0 | 0 | 2 |
Newlumen | [628] | 1 | 0 | 0 |
nfetterly | [196] | 0 | 1 | 0 |
Nguyen | [629] | 1 | 0 | 0 |
Nichia | [797] | 0 | 1 | 0 |
nick91900 | [1311] | 0 | 0 | 1 |
nickdude | [1638] | 0 | 0 | 1 |
NickG | [1539] | 0 | 0 | 1 |
Nickke | [738] | 1 | 0 | 0 |
Nicolaas | [4] | 1 | 0 | 0 |
Nicolicous | [ 20 610] | 1 | 1 | 0 |
NightLight | [320] | 1 | 0 | 0 |
NikolaS | [185] | 1 | 0 | 0 |
niktak11 | [197] | 1 | 0 | 0 |
Nine9n1ne | [673] | 1 | 0 | 0 |
nitekayak | [1718] | 0 | 0 | 1 |
nitrader0 | [548] | 1 | 0 | 0 |
nitro | [770 770] | 1 | 1 | 0 |
NLivsey | [1265] | 0 | 0 | 1 |
nnmnu1 | [476] | 1 | 0 | 0 |
Nnugkcin | [772] | 0 | 1 | 0 |
No-2-Ageing | [1552] | 0 | 0 | 1 |
no1muzzy | [1064] | 0 | 0 | 1 |
Nocturnel | [1319] | 0 | 0 | 1 |
nodoubt | [380 383 894] | 0 | 3 | 0 |
noetik | [489] | 1 | 0 | 0 |
nofear87 | [443] | 0 | 1 | 0 |
noob | [292] | 0 | 1 | 0 |
Nooner | [1467] | 0 | 0 | 1 |
Noopjl | [1313] | 0 | 0 | 1 |
Norddeutscher | [227 228] | 2 | 0 | 0 |
nordlicht | [730 731] | 1 | 1 | 0 |
northbeard | [1280] | 0 | 0 | 1 |
NorthCentralPos… | [1229] | 0 | 0 | 1 |
Northwoods | [247] | 0 | 1 | 0 |
Nortson | [245] | 1 | 0 | 0 |
notn41 | [1258] | 0 | 0 | 1 |
NotSure | [660] | 0 | 1 | 0 |
nqcken | [29] | 1 | 0 | 0 |
NuggetMcNugget | [212] | 1 | 0 | 0 |
nvanlaar | [925] | 0 | 1 | 0 |
nydude | [733] | 0 | 1 | 0 |
O26Rcr | [1352 1586] | 0 | 0 | 2 |
Oal | [544] | 1 | 0 | 0 |
Oamaruvian | [1222] | 0 | 0 | 1 |
object_in_space | [1692] | 0 | 0 | 1 |
Oborowatabinost | [1218] | 0 | 0 | 1 |
octav | [411] | 1 | 0 | 0 |
octopus7750 | [807] | 0 | 1 | 0 |
Offgridled | [625] | 1 | 0 | 0 |
offroadatnite | [1026 1045 1452 1453] | 0 | 2 | 2 |
Oh it is | [1106] | 0 | 0 | 1 |
ohbreeeezy | [1447] | 0 | 0 | 1 |
ohhhtravis | [1482] | 0 | 0 | 1 |
OKCOREY | [1254] | 0 | 0 | 1 |
okreddirt | [1323] | 0 | 0 | 1 |
OldSee | [995] | 0 | 1 | 0 |
OleMissRbl | [1597 1598] | 0 | 0 | 2 |
olivedrab | [474] | 0 | 1 | 0 |
OneLumen | [901 902 903] | 0 | 3 | 0 |
oolong | [1046] | 0 | 1 | 0 |
optntdr13 | [502] | 1 | 0 | 0 |
orbit308 | [1466] | 0 | 0 | 1 |
orbitalforest | [1382] | 0 | 0 | 1 |
osb40000 | [281 440 441] | 1 | 2 | 0 |
Ozythemandias | [ 641 1717] | 1 | 0 | 1 |
p_dedy | [1674] | 0 | 0 | 1 |
Pablogy | [765] | 1 | 0 | 0 |
PabloVerde | [617] | 1 | 0 | 0 |
PabstyLoudmouth | [794 950] | 0 | 2 | 0 |
Paladinaus | [1008 1525] | 0 | 1 | 1 |
PancakeMan | [1557] | 0 | 0 | 1 |
Papalumen | [1476] | 0 | 0 | 1 |
papaslightsaber | [206] | 1 | 0 | 0 |
Pasakulu | [965 966] | 0 | 2 | 0 |
patchman | [1084] | 0 | 0 | 1 |
patmet | [561] | 1 | 0 | 0 |
patmurris | [ 681 1672] | 1 | 0 | 1 |
Patriot36 | [814] | 0 | 1 | 0 |
Patt | [1259] | 0 | 0 | 1 |
Patuperkel | [1242] | 0 | 0 | 1 |
Paul brabus | [1659] | 0 | 0 | 1 |
pcctex | [1317] | 0 | 0 | 1 |
pcmunson | [1745] | 0 | 0 | 1 |
peabody | [ 119 1696] | 1 | 0 | 1 |
Pegaso | [30] | 1 | 0 | 0 |
pelle470 | [684] | 1 | 0 | 0 |
pepinfaxera | [426] | 1 | 0 | 0 |
Perdu | [1074] | 0 | 0 | 1 |
pete21 | [1364] | 0 | 0 | 1 |
Peter Wijono | [1174] | 0 | 0 | 1 |
Phantom1 | [554 575] | 1 | 1 | 0 |
Phlipp | [1571] | 0 | 0 | 1 |
Phoenix_FIN | [36] | 1 | 0 | 0 |
phoenixphil | [1273 1274 1275] | 0 | 0 | 3 |
phunqe | [1404] | 0 | 0 | 1 |
PickleFuzz | [850] | 0 | 1 | 0 |
pilotdog68 | [600] | 1 | 0 | 0 |
piotrek966 | [ 439 1510] | 1 | 0 | 1 |
pirate joe 22 | [ 645 653 1190] | 0 | 2 | 1 |
plaidshorts | [244] | 0 | 1 | 0 |
Plan-B | [1015] | 0 | 1 | 0 |
Plat | [1209] | 0 | 0 | 1 |
pleply | [599] | 1 | 0 | 0 |
pmsignal | [1493 1494] | 0 | 0 | 2 |
pmtech | [1090] | 0 | 0 | 1 |
Pocket Torch | [1381] | 0 | 0 | 1 |
podo | [1071 1072] | 0 | 0 | 2 |
Pok | [85] | 1 | 0 | 0 |
polarweis | [578] | 1 | 0 | 0 |
pommie | [19] | 1 | 0 | 0 |
pooptoast | [224] | 1 | 0 | 0 |
possumwater | [970] | 0 | 1 | 0 |
POWER MIKE | [1648] | 0 | 0 | 1 |
Prairie-oysters | [1299] | 0 | 0 | 1 |
praveendk | [259] | 1 | 0 | 0 |
Precision777 | [1120] | 0 | 0 | 1 |
prepro | [696] | 1 | 0 | 0 |
PrinceValorum | [311] | 1 | 0 | 0 |
prisma | [168] | 1 | 0 | 0 |
Prodeje79 | [956] | 0 | 1 | 0 |
Promio | [1442] | 0 | 0 | 1 |
proq | [1051] | 0 | 0 | 1 |
pscal | [507] | 1 | 0 | 0 |
psinha | [1434] | 0 | 0 | 1 |
Pssymon | [1426] | 0 | 0 | 1 |
psumo | [1736] | 0 | 0 | 1 |
puccio1969 | [141] | 0 | 1 | 0 |
Pugna | [1088] | 0 | 0 | 1 |
Pulsar | [446] | 1 | 0 | 0 |
PVCC | [1132 1395] | 0 | 0 | 2 |
pwm40hz | [1744] | 0 | 0 | 1 |
Pöbel | [54] | 1 | 0 | 0 |
qandeel | [ 47 475] | 1 | 1 | 0 |
Quickstrike2 | [1369] | 0 | 0 | 1 |
quijibo | [1366 1367 1368] | 0 | 0 | 3 |
Qwibbles | [1163] | 0 | 0 | 1 |
R-Lo | [1023 1024] | 0 | 2 | 0 |
R.D. | [335] | 1 | 0 | 0 |
R10500 | [576 646] | 1 | 1 | 0 |
r1derbike | [1069] | 0 | 0 | 1 |
Rafał | [1514] | 0 | 0 | 1 |
rag | [307] | 0 | 1 | 0 |
Rah_BE | [760] | 1 | 0 | 0 |
rajun50 | [77] | 1 | 0 | 0 |
Randolph | [524] | 1 | 0 | 0 |
RapidLux | [828] | 0 | 1 | 0 |
Rarrar | [1126] | 0 | 0 | 1 |
Rat | [994] | 0 | 1 | 0 |
Ratus | [1536] | 0 | 0 | 1 |
realtree | [1488] | 0 | 0 | 1 |
rebuswind | [929] | 0 | 1 | 0 |
recumbent | [1044] | 0 | 1 | 0 |
Redlyne22 | [1756] | 0 | 0 | 1 |
rejsr | [832] | 0 | 1 | 0 |
ReManG | [841] | 0 | 1 | 0 |
renegade87 | [1202] | 0 | 0 | 1 |
repollo | [1548] | 0 | 0 | 1 |
Revarious | [1078] | 0 | 0 | 1 |
rhburke | [1396] | 0 | 0 | 1 |
Ricflair | [267] | 0 | 1 | 0 |
Rick | [422] | 0 | 0 | 1 |
rick1944 | [983] | 0 | 1 | 0 |
riggz | [1448 1449] | 0 | 0 | 2 |
rizky_p | [614 640] | 1 | 1 | 0 |
Rj2 | [1330] | 0 | 0 | 1 |
Rob1563 | [1640] | 0 | 0 | 1 |
rob799 | [1564] | 0 | 0 | 1 |
Roberrt777 | [317] | 0 | 1 | 0 |
Robert007 | [1150 1151] | 0 | 0 | 2 |
RobertB | [11] | 1 | 0 | 0 |
robertglenanderton | [928] | 0 | 1 | 0 |
Robosaur | [1405] | 0 | 0 | 1 |
RocketTomato | [161] | 0 | 1 | 0 |
RockHugger | [1098] | 0 | 0 | 1 |
Rokypop | [1334] | 0 | 0 | 1 |
RoloFresh | [1477] | 0 | 0 | 1 |
romanus | [421] | 0 | 1 | 0 |
Romey310 | [1221] | 0 | 0 | 1 |
Romp23 | [1749] | 0 | 0 | 1 |
Ronen98 | [401] | 0 | 1 | 0 |
Rossano95 | [830] | 0 | 1 | 0 |
RotorHead64 | [166] | 1 | 0 | 0 |
Rozzy | [1455] | 0 | 0 | 1 |
rpscuba | [821] | 0 | 1 | 0 |
rsac | [1127 1252] | 0 | 0 | 2 |
rsmith7226 | [1314] | 0 | 0 | 1 |
RsquaRed | [1417] | 0 | 0 | 1 |
RT— | [1356] | 0 | 0 | 1 |
run4jc | [1711] | 0 | 0 | 1 |
rvr | [42] | 1 | 0 | 0 |
Rxich | [581] | 1 | 0 | 0 |
ryanferg | [858] | 0 | 1 | 0 |
saabluster | [330] | 0 | 1 | 0 |
Sabowan | [1227] | 0 | 0 | 1 |
sac02 | [488] | 1 | 0 | 0 |
Saigon | [326] | 0 | 1 | 0 |
SamHaLeKe | [717] | 1 | 0 | 0 |
samis | [546] | 1 | 0 | 0 |
samnavy | [108] | 1 | 0 | 0 |
SampleSizeOne | [904 905] | 0 | 2 | 0 |
samsung913 | [445] | 1 | 0 | 0 |
Samuel AUDIBERT | [919] | 0 | 1 | 0 |
san san | [328] | 1 | 0 | 0 |
sandro | [1100 1101] | 0 | 0 | 2 |
Sarge930 | [174] | 1 | 0 | 0 |
sb56637 | [184] | 0 | 1 | 0 |
scannerguy1968 | [1121] | 0 | 0 | 1 |
Scavman | [1451] | 0 | 0 | 1 |
scdaf | [285] | 0 | 1 | 0 |
Schkü | [336] | 1 | 0 | 0 |
Schlaucher | [1278] | 0 | 0 | 1 |
schlichtie | [860] | 0 | 1 | 0 |
scianiac | [481] | 1 | 0 | 0 |
Sciencetists | [131] | 1 | 0 | 0 |
SCNole | [1042 1542] | 0 | 1 | 1 |
Scope17 | [1112] | 0 | 0 | 1 |
scotlarock | [460] | 1 | 0 | 0 |
seanok | [1540] | 0 | 0 | 1 |
sebastiang | [1107] | 0 | 0 | 1 |
Sebastianzon | [1621] | 0 | 0 | 1 |
seben | [1059] | 0 | 0 | 1 |
Seeker1 | [1030] | 0 | 1 | 0 |
Seelevel | [827] | 0 | 1 | 0 |
seery | [1595 1693] | 0 | 0 | 2 |
SG3 | [1197] | 0 | 0 | 1 |
sgt253 | [236] | 1 | 0 | 0 |
Shadowfax | [273] | 1 | 0 | 0 |
ShadowMerchant | [1110] | 0 | 0 | 1 |
shakeym | [896] | 0 | 1 | 0 |
shan6oob | [509] | 1 | 0 | 0 |
shanefletch | [ 881 1652] | 0 | 1 | 1 |
Shawnlayman25 | [1376] | 0 | 0 | 1 |
Shelf Queen | [976] | 0 | 1 | 0 |
sherman2k | [1592] | 0 | 0 | 1 |
shimano3000 | [83] | 1 | 0 | 0 |
shirnask | [260] | 1 | 0 | 0 |
shogan | [178] | 1 | 0 | 0 |
shooterschmidty | [450] | 1 | 0 | 0 |
shrick | [321 322] | 2 | 0 | 0 |
Shur | [365] | 1 | 0 | 0 |
SikSemper | [1604] | 0 | 0 | 1 |
Silent_Star | [434] | 1 | 0 | 0 |
SILIWANGIPARAHYANGAN | [1421] | 0 | 0 | 1 |
silverecco | [1531] | 0 | 0 | 1 |
simplex | [1566] | 0 | 0 | 1 |
Sirawatka | [1681] | 0 | 0 | 1 |
Sirius9 | [204] | 1 | 0 | 0 |
SirMehsAlot | [1207 1391] | 0 | 0 | 2 |
Skookmb | [1357] | 0 | 0 | 1 |
Sky | [638 759] | 1 | 1 | 0 |
slackwolf | [290 291 355 671] | 0 | 4 | 0 |
Slayer1 | [442 469] | 1 | 1 | 0 |
sledge0816 | [876] | 0 | 1 | 0 |
Sledgestone | [107 501] | 1 | 1 | 0 |
slickpenguin | [229] | 1 | 0 | 0 |
slimkango | [854] | 0 | 1 | 0 |
slow2go | [ 39 423 424 1732] | 1 | 2 | 1 |
sma | [106] | 1 | 0 | 0 |
Smarquis | [1513] | 0 | 0 | 1 |
Smittymojo | [ 117 1666] | 1 | 0 | 1 |
smokuxx1987 | [297 753] | 1 | 1 | 0 |
Sniper | [1116] | 0 | 0 | 1 |
solRNY | [452 620] | 1 | 1 | 0 |
solsol | [1157] | 0 | 0 | 1 |
somnambulism | [1268] | 0 | 0 | 1 |
Sonofspectrum | [549] | 1 | 0 | 0 |
Sonpham | [8] | 0 | 1 | 0 |
southcovekayak | [435] | 0 | 1 | 0 |
southland | [ 14 563 564 565 566] | 1 | 4 | 0 |
sp5it | [472] | 1 | 0 | 0 |
spacemanspliff | [1289] | 0 | 0 | 1 |
spade413 | [1208] | 0 | 0 | 1 |
SPAMBOT | [997] | 0 | 1 | 0 |
specialk | [274] | 1 | 0 | 0 |
species8472 | [ 907 1235] | 0 | 1 | 1 |
Speed4goal | [385] | 0 | 1 | 0 |
spkzzz | [214] | 0 | 1 | 0 |
sportlampa | [1609] | 0 | 0 | 1 |
spotlighter | [595] | 1 | 0 | 0 |
square74 | [767] | 0 | 1 | 0 |
squidaudio6872 | [1177 1178] | 0 | 0 | 2 |
srwaite | [687] | 1 | 0 | 0 |
Ssthis | [757] | 1 | 0 | 0 |
st33lboy | [713] | 1 | 0 | 0 |
stanmore | [1712] | 0 | 0 | 1 |
StarCity | [577] | 1 | 0 | 0 |
staticx57 | [ 21 1617] | 1 | 0 | 1 |
stayintheshadows | [1264 1748] | 0 | 0 | 2 |
steel_1024 | [ 312 1043] | 1 | 1 | 0 |
SteelyPhil88 | [749] | 1 | 0 | 0 |
steve404 | [1260] | 0 | 0 | 1 |
SteveMidwest | [583] | 1 | 0 | 0 |
SteveRocks | [1253] | 0 | 0 | 1 |
Stittville Ed | [53] | 0 | 1 | 0 |
Stoneface | [459] | 1 | 0 | 0 |
strayz | [ 104 1223] | 0 | 1 | 1 |
strongtower1 | [1091] | 0 | 0 | 1 |
Subiext73 | [845] | 0 | 1 | 0 |
SubSailorVet | [742] | 1 | 0 | 0 |
Subwoofers | [1114] | 0 | 0 | 1 |
Sukoi | [234 454] | 1 | 1 | 0 |
sulaco | [1283] | 0 | 0 | 1 |
Sullysat | [370] | 1 | 0 | 0 |
Suncoaster | [568] | 1 | 0 | 0 |
Sundance | [964] | 0 | 1 | 0 |
sunfire | [1182 1576] | 0 | 0 | 2 |
Superslicknick | [795] | 0 | 1 | 0 |
Superspprt327 | [1403] | 0 | 0 | 1 |
surasakkongtha | [1286] | 0 | 0 | 1 |
suratyu | [642] | 1 | 0 | 0 |
Suxelebut | [1425] | 0 | 0 | 1 |
Svensk | [709] | 0 | 1 | 0 |
Swennie | [572] | 0 | 1 | 0 |
Swordfish | [1058] | 0 | 0 | 1 |
sybersonix | [954] | 0 | 1 | 0 |
Sycamore | [880] | 0 | 1 | 0 |
Syncronisator | [1118] | 0 | 0 | 1 |
T18 | [675 676] | 1 | 1 | 0 |
Tally-ho | [ 697 1370] | 1 | 0 | 1 |
tanaka- | [1460] | 0 | 0 | 1 |
Tarvos | [92] | 1 | 0 | 0 |
tatasal | [397] | 1 | 0 | 0 |
Tclementi1 | [762] | 1 | 0 | 0 |
td1042k | [1276] | 0 | 0 | 1 |
Tdh66 | [836] | 0 | 1 | 0 |
teacher | [ 183 341 1627] | 1 | 1 | 1 |
teachtom | [72] | 1 | 0 | 0 |
techieman33 | [494] | 1 | 0 | 0 |
TechnOMatriX | [532] | 1 | 0 | 0 |
TeeZocker | [1164] | 0 | 0 | 1 |
Tejasandre | [1582 1739] | 0 | 0 | 2 |
Teknofiliak | [1134] | 0 | 0 | 1 |
Tender | [771] | 0 | 1 | 0 |
terry b | [714] | 0 | 1 | 0 |
Terry White | [618 619] | 1 | 1 | 0 |
Tete | [113] | 1 | 0 | 0 |
Texas_Ace | [497 498] | 1 | 1 | 0 |
texmaster | [1225] | 0 | 0 | 1 |
Th8tredude | [1394] | 0 | 0 | 1 |
The Groundsman | [1363] | 0 | 0 | 1 |
The Miller | [1] | 1 | 0 | 0 |
The Swabian | [1262] | 0 | 0 | 1 |
The_crx | [486] | 1 | 0 | 0 |
The_Driver | [246] | 1 | 0 | 0 |
theanghv | [786] | 0 | 1 | 0 |
TheConsultant | [798] | 0 | 1 | 0 |
thegameisrigged | [345] | 1 | 0 | 0 |
TheLonelyLumen | [682] | 1 | 0 | 0 |
Theodore41 | [126] | 1 | 0 | 0 |
theoldbill | [169] | 1 | 0 | 0 |
TheOnlyDocc | [187] | 0 | 1 | 0 |
thesciencenut | [192] | 0 | 1 | 0 |
Thewrights11 | [1563] | 0 | 0 | 1 |
Thin Man | [1603] | 0 | 0 | 1 |
thnxtank | [1094] | 0 | 0 | 1 |
thommy | [303] | 1 | 0 | 0 |
Threadneedle | [941] | 0 | 1 | 0 |
thslw8jg | [ 248 1416] | 1 | 0 | 1 |
thumper36 | [1757] | 0 | 0 | 1 |
ticketme | [1644] | 0 | 0 | 1 |
tino79 | [654] | 1 | 0 | 0 |
TitaniumLight | [849] | 0 | 1 | 0 |
Tjhosan | [495] | 0 | 1 | 0 |
tkmckay | [737] | 1 | 0 | 0 |
tmx009 | [652] | 1 | 0 | 0 |
tmxod | [181] | 0 | 1 | 0 |
TNT | [324] | 0 | 1 | 0 |
toddlearound | [1649] | 0 | 0 | 1 |
Tom E | [ 43 44 461] | 2 | 1 | 0 |
Tom_182 | [831] | 0 | 1 | 0 |
tomas.hrubovcak | [ 540 1206] | 1 | 0 | 1 |
Tombird83 | [1037] | 0 | 1 | 0 |
tommydadog | [1032 1033 1398] | 0 | 2 | 1 |
Tomogchi | [1282] | 0 | 0 | 1 |
tonylim | [ 530 1716] | 1 | 0 | 1 |
TopAs | [1562] | 0 | 0 | 1 |
Toppe | [920] | 0 | 1 | 0 |
Toppel | [1136] | 0 | 0 | 1 |
torchmanSp1111 | [1346 1682] | 0 | 0 | 2 |
TorinoFermic | [698] | 1 | 0 | 0 |
torqu3e | [1175] | 0 | 0 | 1 |
Total Package | [1422] | 0 | 0 | 1 |
Touchofred | [1337] | 0 | 0 | 1 |
Transient | [1169] | 0 | 0 | 1 |
travis a | [1036] | 0 | 1 | 0 |
Tredd | [1333] | 0 | 0 | 1 |
TreyGhost252 | [1057] | 0 | 0 | 1 |
treysoucie | [202] | 0 | 1 | 0 |
troisanh | [ 71 1509] | 1 | 0 | 1 |
tronx | [1709] | 0 | 0 | 1 |
tru3s1lv3r | [319] | 1 | 0 | 0 |
trume_3454 | [398] | 1 | 0 | 0 |
tucsonmike | [1200] | 0 | 0 | 1 |
Tuigali | [691] | 1 | 0 | 0 |
turboBB | [379] | 1 | 0 | 0 |
turgid_fervor | [917] | 0 | 1 | 0 |
Turningbluechips | [ 718 1546] | 1 | 0 | 1 |
turpulator | [417] | 1 | 0 | 0 |
two fifty | [1496] | 0 | 0 | 1 |
twodollarbill | [ 310 1654] | 1 | 0 | 1 |
twoleftfeet | [747] | 1 | 0 | 0 |
tzmxxhh | [90] | 0 | 1 | 0 |
ulfm1 | [1413] | 0 | 0 | 1 |
Umcookies | [1606] | 0 | 0 | 1 |
Umpi2000 | [392] | 1 | 0 | 0 |
uncle_muscle98 | [1706] | 0 | 0 | 1 |
uncleJ | [1309] | 0 | 0 | 1 |
unit311 | [536] | 1 | 0 | 0 |
unknown00101 | [ 648 1399 1400] | 1 | 0 | 2 |
Upper_tanker | [1687] | 0 | 0 | 1 |
uqs1000 | [1067] | 0 | 0 | 1 |
uwould | [1418] | 0 | 0 | 1 |
validum | [1231] | 0 | 0 | 1 |
vamper | [346 699] | 1 | 1 | 0 |
Van | [337] | 1 | 0 | 0 |
velarpinch | [1486] | 0 | 0 | 1 |
velocraig | [ 152 1321] | 1 | 0 | 1 |
Venomdefense | [1714] | 0 | 0 | 1 |
VernonDent | [1491] | 0 | 0 | 1 |
vestureofblood | [ 296 1081 1615] | 1 | 0 | 2 |
vex_zg | [1195] | 0 | 0 | 1 |
Viking 3XL | [1056] | 0 | 0 | 1 |
vinte77 | [586] | 0 | 1 | 0 |
viper1138 | [419] | 1 | 0 | 0 |
ViperAUG | [1219] | 0 | 0 | 1 |
viperbart | [133] | 0 | 1 | 0 |
Vlad Vasiliu | [1584] | 0 | 0 | 1 |
vol | [195] | 0 | 1 | 0 |
vonuscyg | [967 986] | 0 | 2 | 0 |
VRT | [945] | 0 | 1 | 0 |
vxlomegav6 | [1634] | 0 | 0 | 1 |
w4rkry | [ 662 1119] | 1 | 0 | 1 |
Walker Klondike | [519] | 1 | 0 | 0 |
walty | [132] | 0 | 1 | 0 |
wapd2 | [541] | 1 | 0 | 0 |
Warenzevon | [1183] | 0 | 0 | 1 |
warzi1975 | [ 76 715 1522 1559 1623] | 1 | 1 | 3 |
WaylonJennings | [ 556 1374] | 1 | 0 | 1 |
wdkingery | [1614] | 0 | 0 | 1 |
Wedgetarian | [1004] | 0 | 1 | 0 |
weklund | [1224] | 0 | 0 | 1 |
Wekr | [1318] | 0 | 0 | 1 |
Wennn | [ 607 1708] | 1 | 0 | 1 |
Wesleyflores | [1751] | 0 | 0 | 1 |
WestBam | [711] | 1 | 0 | 0 |
westcoastwonders | [173] | 1 | 0 | 0 |
what_are_birds | [672] | 1 | 0 | 0 |
whooda4 | [333 391] | 1 | 1 | 0 |
Wieselflinkpro | [48] | 1 | 0 | 0 |
wiestom89 | [52] | 1 | 0 | 0 |
will34 | [668] | 0 | 1 | 0 |
WillBeatz | [776] | 0 | 1 | 0 |
williamscott999 | [1325 1326 1327] | 0 | 0 | 3 |
Willy89 | [1500] | 0 | 0 | 1 |
WillyD | [222] | 1 | 0 | 0 |
wilwok | [ 613 1397] | 1 | 0 | 1 |
wimmer2121 | [643] | 1 | 0 | 0 |
Wineslurper | [68 69] | 2 | 0 | 0 |
wintermute76 | [1385] | 0 | 0 | 1 |
wishiwereaskibum | [784] | 0 | 1 | 0 |
wkhchin81 | [402] | 1 | 0 | 0 |
WolfA | [125] | 0 | 1 | 0 |
wolfstyle | [667] | 1 | 0 | 0 |
Wrathbringer27 | [56] | 1 | 0 | 0 |
wstrachan | [924] | 0 | 1 | 0 |
WuTang | [543] | 1 | 0 | 0 |
X0R | [508] | 1 | 0 | 0 |
xanderolo | [1406] | 0 | 0 | 1 |
Xandre | [22] | 1 | 0 | 0 |
xCentrino | [479] | 1 | 0 | 0 |
xcpilot | [1412] | 0 | 0 | 1 |
Xenovora | [1189] | 0 | 0 | 1 |
xertian | [743] | 1 | 0 | 0 |
Xombie86 | [942 951] | 0 | 2 | 0 |
Xonkorvich | [1730] | 0 | 0 | 1 |
xray291 | [408 608] | 1 | 1 | 0 |
xseven | [1041] | 0 | 1 | 0 |
xtrosity | [542] | 1 | 0 | 0 |
xxx | [574] | 1 | 0 | 0 |
XXX-Man | [ 647 1645] | 1 | 0 | 1 |
Yammie | [948] | 0 | 1 | 0 |
Yanlee13 | [969] | 0 | 1 | 0 |
yasenf | [334 725 840 885 979] | 1 | 4 | 0 |
yclongthrow | [284] | 1 | 0 | 0 |
yenkoz | [959] | 0 | 1 | 0 |
YoFlash | [137] | 1 | 0 | 0 |
Yokiamy | [651] | 1 | 0 | 0 |
YouFunnyGuys | [1724] | 0 | 0 | 1 |
Yourrid | [414] | 1 | 0 | 0 |
Yousir | [1237] | 0 | 0 | 1 |
Youville | [1159] | 0 | 0 | 1 |
YummyBacon | [1643] | 0 | 0 | 1 |
zachary6227 | [511] | 1 | 0 | 0 |
zelee | [80] | 1 | 0 | 0 |
ZempOh | [1038 1039] | 0 | 1 | 1 |
Zeratull | [387] | 1 | 0 | 0 |
zeremefico | [ 376 1646] | 1 | 0 | 1 |
zeroair | [ 241 1680] | 1 | 0 | 1 |
zifzif | [720] | 1 | 0 | 0 |
zipelgas | [395] | 1 | 0 | 0 |
ZMANZ71 | [1095] | 0 | 0 | 1 |
zortan | [679] | 1 | 0 | 0 |
zoysiamo | [512] | 1 | 0 | 0 |
ZozzV6 | [78] | 1 | 0 | 0 |
Zweemil | [1070] | 0 | 0 | 1 |
Bravo, what a job, awesome guys!
