No, I don’t think so. The XP-L HI needs to be actually driven hard with a buck driver and multiple cells. Of course in single cell lights it’s not as good.
You are the only person I know of who reports problems with the reliability. There must be more…
Ever tested that m8? Cause i did, dozen times, and after a month the fella hunter is calling: the emitter has a black dot( usualy arround the wond wires)
Ofc at 4.5 it will live, yet it wont be that productive.
I use hard driven Hi emitter unless i dotn have other choice( for those “cool white” fellas)
Warm and nautral white HI emitters do have even more issues though
Yet now, after 8000k SST emerged i dont think i will be using a HI emitter any time soon
Whether it is worth it or not is up to the person buying the reflector.
Yes, most of the additional lumens collected by a deeper reflector go into the corona, this is correct, but there is still a bit more front area to the reflector due to the smaller center hole, which is what increases the lux a little.
A deeper reflector, assuming constant diameter, means it will have a smaller center hole, and more front area as a result.
So the increase in lumens is pretty large due to all the extra degrees collected, but the increase in lux is very little since the center hole size won’t decrease much.
It still does increase the lux, just very little.
I was looking at the SST 90 led from luminus http://luminus.com/products/SST-90.html.
Double lumens and smaller die als with the XHP70.2 thus more throw.
Only problem would be to find a driver. The led4power drivers might work? (1s4p carrier setup of course)
T/A mentioned that he might make a parts list to make the GT driver compatible with 3volt LED’s.
I’m very keen to go that route, & have some of the ‘good’ XP-G2’s on their way as well, which should punch out some really good throw numbers.
For comparison, I’ve taken throw readings on the STOCK production GT. Using 8*30q’s fully charged, I calculated the following readings (to 0.25lux), using a CT-1330B light meter.
Taken @ 10 meters - 1760 meters throw.
Taken @ 15 meters - 1764 meters throw.
Taken @ 20 meters - 1743 meters throw.
Can those who are able, post their NON-MODDED ie STOCK production GT throw numbers, & what cells & meter used also.
I received my GT a few weeks ago. I love the light, especially the 4000k tint. My LED was slightly off center due to some very minor slop in the centering apparatus. I wanted a way to get consistent centering of the LED. To address this, I spent some time filing down a centering ring to fill the void. It did not come out perfect, but I am satisfied with the result I got, especially considering that I only used hand tools.
The head was VERY tightly screwed on. Removing the head was the most challenging part of this project. I had to make a crude strap wrench and clamping fixture to loosen it. I have not removed the bezel yet and am not sure if I will attempt to.The reflector is a tad bit dusty, but it does not really concern me. I lubed the heck out of the head before putting it back on (visible in photos).
Here are some size reference photos next to my ‘other’ superthrower. The GT is absolutely massive. The lux meter goes back and forth between the 2, so I estimate they are about the same in terms of throw. The chrome light is a Fivemega Elephant original with 3 series 18650 carrier, DX 78mm aspheric, wavien collar, modified h22a heatsink, xp-g2 s4 2b (old style), driven by TaskLED h6cc at 5 amps. Plans are to install an Osram Synios fairly soon. The GT will most likely remain stock other than the centering ring enhancement.
This is the same LED being offered by MTN for transplant, for people who don’t like the stock LED.
Taken @ 10 meters – 1833 meters throw.
Taken @ 15 meters – 1849 meters throw.
Taken @ 20 meters – 1841 meters throw.
Compared to the stock readings;
Taken @ 10 meters – 1760 meters throw.
Taken @ 15 meters – 1764 meters throw.
Taken @ 20 meters – 1743 meters throw.
While the GT is a great thrower, & will wow most people, unfortunately it falls short of the “>1 Mcd (ANSI throw >2000 m)”, as promised in the original specs, which is a little disappointing.
Of course, I’m just using a cheap, un-calibrated meter, so there’s bound to be a little give or take in the numbers.
I’m looking forward to see what it can do with an XP-G2
Yep, I have a large spreadsheet of measurements from other lights, taken with the same meter.
I’ll dig out a few other lights to re-measure, in case there has been a change in the meter, but in the past it has been in the ballpark for other known lights.
I don’t see anyone else posting throw numbers for their production GT’s, though. It would be good to see a comparison.
I have the parts here to try the 3V mod. The stock driver will actually drive a 3V LED at the stock 2.5A current, it just can’t handle much more then that as the stock diode will quickly overheat.
Keep in mind that the meters we use favor CW emitters to NW. I generally see about a ~10-15% difference in readings from equal bin emitters of different tints.
So that would actually put both emitters at about the same throw level with that factored in.
Although the total readings you are getting are a bit lower then most, not sure why. High humidity, smog and other factors play into things and since your 20m readings are lower then your 15m readings this leads me to think this is the case for you. Most see the highest readings at 20m.
For example VOB got his 1.29mcs reading at 20m with lower readings are closer distances.
All that said, I can’t say for sure one way or the other. Just theory’s.
Not a mod to the light, but wanted to share my method of sling attachment. I used:
Black split rings
Adhesive lined heat shrink tubing (3 to 1 shrinkage)
Kevlar trip line (80lb. test with good abrasion resistance)
Heat shrinking the split ring prevents scratching and noise when contacting the light. The Kevlar line has been good for other uses, so I am hoping it will stand up to the wear caused by the edges of the attachment points to the light. I made the loops long enough to double up when attached creating mass and reducing slippage and movement. Used simple cows hitched to connect to the light and to the rings.
