Good lubricant for O rings and threads?
103 posts / 0 new
mmalive
Last seen: 2 years 4 months ago
Hey guys, Any input? I have been using regular vaseline because I figured it will not harm human skin so it will not harm flashlights? Please advise. Thanks.
Box
Supposedly petroleum lube (Vaseline) degrade the rubber. Make them dry over time and they crack.
I always been recommended silcone grease. I use Nyogel by Armytek. I’ve got a small tube of it which I’ve been using for years and it’s not even half empty
Thetasigma
Superlube from harbor freight, cheap, readily available, and useful on a variety of applications. The teflon content is handy
mmalive
Box wrote:
Supposedly petroleum lube (Vaseline) degrade the rubber. Make them dry over time and they crack. I always been recommended silcone grease. I use Nyogel by Armytek. I’ve got a small tube of it which I’ve been using for years and it’s not even half empty
Thanks for input. Thank goodness I only used a little bit. BTW, should I just wipe clean on what I have on there now?
mmalive
WOW!!! I buy at Harbor Freight and never knew it. I shop there at least 3-4 times a week. Thanks for input.
malkoff junkie
malkoff junkie's picture
Last seen: 20 hours 3 min ago
Malkoff !
Beachlogger
Last seen: 17 hours 25 min ago
Coconut oil
mmalive
Thanks guys for input. I would like stuff more readily available. Harbor Frieght and coconut oil seems good. If any others besides ones listed please add to list.
skinny_tie
skinny_tie's picture
Last seen: 37 min ago
I use silicone grease on my torches and fountain pens. Apparently it’s also used on SCUBA equipment.
mmalive
Do you mean the stuff that can be bought at Home Depot, Lowes, Orchard, etc…. ?
moderator007
moderator007's picture
I use this stuff most of the time. Flashlight Lube
Although I do have some nyogel from fordmotorcraft , thats suppose to be good, same thing as the Armytek but cheaper.
I found this out back when I was a member of that other forum. you can google search for “sold out nyogel 760g” if you wanna read up.
barrybluejeans
Has anyone else tried PB Blaster silicone spray? http://blastercorp.com/fullsite/Silicone-Lube
I have a couple cans in the garage, tried it out earlier today and it seemed a little thin. Haven’t tried SuperLube or Nyogel but may pick up some SuperLube next time I’m near Harbor Freight.
WTB ArmyTek Prime C1 body tube only, cree 1A xpl led, single TIR reflectors
wstrachan
Last seen: 4 weeks 20 hours ago
Vaseline will cause rubbe rorings to swell and distort. Try chap-stick (blue) or silcone grease.
light addict....yeah I've got the bug.
Atrolux MF02_O2S
Imalent DT70
Emissar (All Models)
Lumintop ODL20C
Wuben A21 & T70
thrunite tn32 ut
acebeam k60
many, many others...
deleted-200707
Last seen: 1 year 4 weeks ago
I use militec-1 (grease & oil) on my knives, guns and flashlights
moderator007
Thought PB blaster had some kind of corrosive stuff in it. Thought that’s how it attacks rust to free things up.
I checked the link out, not the same stuff as I was thinking of.
ChrisGarrett
ChrisGarrett's picture
Last seen: 9 hours 51 min ago
Nye Nyogel 760G. Started with a 2oz./57gm tube 6 years back and it’s still pretty full.
I do things every six months, or so.
Chris
SIGShooter
SIGShooter's picture
Last seen: 38 min 33 sec ago
My personal opinion is that it doesn’t really matter what one uses as long as they clean and re-lube regularly. I doubt many (or any) who offer an opinion have done detail scientific research into the best lubricant. I personally go with what I have handy and within reach when I’m cleaning the threads.
barrybluejeans
Their penetrating oil does. Their silicone spray product does not, as far as I know. Not that I’m recommending it – I’ll probably pick up something thicker soon.
RobertB
RobertB's picture
Last seen: 16 hours 52 min ago
The XG-12 Ford Motorcraft Electrical Grease is Nyogel 760G. GM and Chrysler also have it. Can be picked up at your local Ford dealer parts counter.
mmalive
Thanks guys for all info. I do not regularly use vasaline so I think I am OK. Just used it once. But better safe than sorry. One of my lights is $380 range and definitely do not want to mess it up. Thinking of buying Fenix TK75 2018 and that bad boy will be $300 plus range so need some good lube.
moderator007
!{width:100%}https://i.imgur.com/iHyHTJI.jpg!
I was always told it was the best. Guess that’s why Armytek started selling it in smaller tubes.
skinny_tie
US hardware retailers seem to have bigger ranges than Australian retailers, but the stuff I got from a big retailer here (for tap washers) was brownish rather than clear so I bought some online. It was easier to buy online than visit a specialist shop, and you only need a tiny amount.
RollerBoySE
RollerBoySE's picture
Last seen: 9 hours 27 min ago
I’ve been using this stuff for a couple of years now and it seems to do the job.
http://flashlight.nitecore.com/ACCESSORIES/Others/SG7/
dw911
Last seen: 1 year 2 weeks ago
I use silicon, either the paste, liquid or spray depending on what i want to put it on.
I used to use Vaseline on maglights as that was what was recommend dont know if it still is anyway i found it broke down the orings and certain plastic bits of the maglights over time
adnj
Last seen: 1 year 1 day ago
Krytox. If you can afford it, its the best possible grease for knife pivots and o-rings that you can buy.
gchart
gchart's picture
Last seen: 41 min 48 sec ago
A little KY always seemed to make things slide well Wink
J/K… I use a little tub of silicone grease, probably from Harbor Freight or an auto parts store.
RotorHead64
RotorHead64's picture
Last seen: 8 months 3 weeks ago
XG-12
Nev
Last seen: 1 year 12 months ago
I just spit on em.
Jerommel
Jerommel's picture
https://www.fasttech.com/p/3586300
Doesn’t run at all, is why i like this.
raccoon city
raccoon city's picture
Last seen: 1 hour 19 sec ago
A stick of butter.  })
moderator007
More than 20 years using WD40, never failed :
!{width:100%}https://www.wd40.com/img/product_family_multi-use.png!
You use it on your O-rings?
