What did you mod today?
10258 posts / 0 new
robo819
robo819's picture
DoNkEyConN wrote:
FmC wrote:
Driver is probably ok.
… check around the + wire joins & spring.
fingers crossed! do you think that battery is still ok?
I have had the same thing happen before. Unless you had the short going for some time , the driver and cell both should be OK. You may have lost a little bit of life off the cell by raising the Internal resistance slightly if anything.
If you haven’t already tested it ,you can get a more controlled result if you have a short jumper wire and just hold it against the end of the tube and the negative end of the cell and then have someone hit the side switch to see if everything is working OK before you put the tailcap on the light. This way if the light does still have a short or anything you can break the connection much quicker than trying to get the tailcap back off.
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
Lexel
Lexel's picture
I would say the battery should be OK if its not getting hot shorting too long, the weak link is the spring and switch
2 26650 Keeppower High Drain cells shorted you look likely at up to 100 amps no wonder spring and switch quit
Those batteries have IR of like 20mOhms, maybe another 30-40mOhms on wires and spring bypass
so we got like 8V on 60mOhms
if the original DTP board does not fit the size of the new you always can drill a hole in the shelf and simply twist one of those self cutting screws in it that are often used in plastic cases if you got no thread cutters
I had the rotating star also a few times, cutting in the wires, never turned out good melting some stuff
You can check the driver if the LED- pad has a very low resistance to ground ring the short created that voltage spike and blew the AMCs, but this usually happens only if the driver had the gate of the AMCs activated
ZozzV6
ZozzV6's picture
Last seen: 1 week 1 hour ago
DoNkEyConN wrote:
I also found the KD board doesn’t meet the L6 screw holes and wire holes….. Frustrating to say the least!
How it cutted the wire? Did you use screws to secure MCPCB? It should not spin. I noticed the hole misalignment on KD stars too and I always grind the MCPCB wire cutouts bigger to fit like this:
kiriba-ru
kiriba-ru's picture
Last seen: 4 hours 54 min ago
Mike C wrote:
khas wrote:
The Khatod optics give a much tighter beam profile, but it’s still very floody.
Nice lights you got there. Got a link to the optics?
https://www.luxeonstar.com/khatod-10-degree-25mm-quad-optic
DoNkEyConN
DoNkEyConN's picture
ZozzV6 wrote:
How it cutted the wire? Did you use screws to secure MCPCB? It should not spin. I noticed the hole misalignment on KD stars too and I always grind the MCPCB wire cutouts bigger to fit like this: !{width:60%}http://img1.indafoto.hu/3/9/134029_e227dae7eadb61c0adb17748b381f0a8/2560...!
Ah i may do this to my star.
i soldered the wires to MCPCB then to fit the screws in i had to turn the MCPCB, im guessing thats when they cut. kicking myself now
ZozzV6
ZozzV6's picture
Now that I showed my led I show the complete build. I made it yesterday. It draws 17.6A and puts out 7800 lumens. I’m still waiting for SMO reflector.
I tried to make the button light show the Hungarian flag colors (red, white, green) but in dark it only shows the red and green because I can’t put white leds in center.
Moon:
Not moon Smile
DoNkEyConN
That’s Beautiful ZozzV6 and everything I want mine to be. nice build Big Smile Thumbs Up
ZozzV6
ZozzV6's picture
Thanks! I had the driver half year ago. Just now got the led and the one L6 of the three that I decided to keep.
MascaratumB
MascaratumB's picture
Last seen: 6 min 24 sec ago
Wieselflinkpro wrote:
MascaratumB wrote:
Cool
How did you get it so clear? Did you polished it, after removing the anodisation?
I have removed the anodisation similar on my short tube of the BLF A6, but its not clear like polished aluminium.
I used caustic soda in cold water to remove the anodizing Thumbs Up
Here are the links to a previous experience that reports the overall process:
http://budgetlightforum.com/comment/1206054#comment-1206054
http://budgetlightforum.com/comment/1206083#comment-1206083
Today, after that I used a dremmel -like tool with a metal “brush disc” to make it more shinny!
And…this may sound strange, but not having something “good” to polish it, I used tooth paste and a tooth brush to clean it after using the dremmel disc Oops Not bad, but not the best method, for sure Wink
KawiBoy1428
KawiBoy1428's picture
Last seen: 11 hours 38 min ago
BLF GT Modified…….De-domed E4 XHP35A-00-0000-0D00E40E1 That I purchased from here.. https://www.ledsupply.com/leds/cree-xlamp-xhp35-high-density I bought the triple and de-domed all three.
Boosted the driver with a R075 for 3.01amps at the emitter. De tuned with 4.5’‘ long Tinergy 24awg leads I reduced the current pull to 2.76-2.78amps at the emitter, where my Light Meter stayed steady. (Ghetto Tuned)
I marked the leads at what I thought were 1/2’‘ lines, but they were 1’‘ lines, and dropped the driver, unsolder the leads, snipped (a 1/2” at at time then a 1/4’‘ when I got closer) then soldered the leads to test,, till I got the desired pull (current increase) from the driver, and the light meter didn’t increase, Never upsetting the reflector/head set-up.
Played with a 12v XHP70 while I was at it…
KB1428 “Live Life WOT
Agro
Agro's picture
Last seen: 3 weeks 17 hours ago
Does it throw better than XHP35 HI E2?
KawiBoy1428
Yep when both drivers were stock, and both being CW, according to my light meter.
And now the E4 is boosted, YEP! Possibly more LUX gain when I shave the centering ring bar down, I opened up the holes in the bar and mcpcb slightly to allow more float, kept the mcpcb screws slightly loose, the spot didn’t look right after the re-flow, it needed better centering, loosened the head and tightened it a few times, floated it in, the spot looks great now crisper! It’s a Massive reflector, so any misalignment your going to see it, so is the meter!
You’ll see when you get yours and start messing with it…
Jtm94
Last seen: 3 weeks 5 days ago
Dropped a TA driver from Lexel into my MF01 today. Now I have no problems with the light. The UI is amazing I wish more lights came with such intuitive firmware that makes sense, but maybe it will happen now that Emisar and the BLF Q8 are out there. The LEDs are being driven as they should be and the light becomes too hot to touch at 30 seconds then holds heat for at least 4 minutes. With my approximating shoe box I’m reading around 15,000 lumens. That makes it twice as bright as my Q8 after bypasses and TLC.
KawiBoy1428
BLF GT XHP70.2 Used the SD75 6volt XHP70 MCPCB and 2xSD75 (2S2P 8.4v) battery carriers in series, had to modify slightly to make the 2S (-) connection on the carriers, spring bypass’s. Running a Modified 30mm Hyperion FETDD (https://www.arrow.com/en/products/bsc009ne2ls5atma1/infineon-technologie...) Simple 5 modes, 18awg leads 20+ amps at the emitter depending on batteries. seen as high as 21.7amps VTC5A’s but running 8×30Q’s 20.2amps.
So far I have run these emitters thru the GT, and I’m not happy with them…the 5700k isn’t too bad, but I have 3 other emitter I’m going to try out,see if they work/look better…..the XHP70B01D0BP240E to me looks like the exact tint that the Stock BLF GT XHP35HI NW 4000k looks like, if your into that flavor?
https://www.mouser.com/productdetail/cree-inc/xhp70b-01-0000-0d0hm440g?q...
https://www.mouser.com/productdetail/cree-inc/xhp70b-01-0000-0d0bp240e?q...
https://eu.mouser.com/ProductDetail/Cree-Inc/XHP70B-01-0000-0D0BP20E2/?q...
As a added bonus, the GT’s MCPCB fits the SD75 so I built one more SD75 XHP35 HI using Lexels E2-3A that I had in this GT before I converted it to XHP70.2
Really like the XHP35 HI E4-3A I purchased from Lexel, first time I have ever seen or used this bin/tint in a build, I should of purchased a couple more!!!! Facepalm
DB Custom
DB Custom's picture
Last seen: 21 hours 1 min ago
Yes, you should have, then sent me a few. Silly
Nice work Kawi, very elaborate exchanges, still need some beam shots though. Smile
ZozzV6
ZozzV6's picture
Today I putted in an SST40 in my heat colored L2 and TA OTSM 20mm driver. Still need to replace switch with a reverse clicky and make orange lighted tailcap and make some photos and beamshots from the end result.
And here is my shorty clear S2+ with stainless button with blue lighted tailcap and screw clip.
NeutralFan
NeutralFan's picture
Last seen: 2 days 6 hours ago
Nice looking shorty S2+ ZozzV6! What did you use for the lighted switch?
I’d rather use my flashlight around the house than turn on the lights.
ZozzV6
ZozzV6's picture
Same things and preparations as in this build
Some correction : You doesn’t need to grind down the steel button lower edge for clearance. it is good for more light coming out.
On the left grinded button with six led board. On the right stock button 2 led board:
For more info see” this topic
“:http://budgetlightforum.com/node/37851
NeutralFan
Another standard Convoy S2+ mod. This one with an RMM 3 amp Moonlight Special driver and a Nichia 90+ CRI LED, but with a couple noteworthy (read time consuming) enhancements.
First, I trimmed down the driver retainer ring so I could screw down the driver rather than solder it in.
Second, I added a green lighted switch (read the most time consuming part).
I really like the warmer 4,000K tint that the Nichia LED produces. And considering how small the flashlight is, it still throws pretty well.
Here’s a link to my build (which I wrote to try to encourage others to consider modding): Convoy S2+ Mod With A Lighted Switch
XXX-Man
XXX-Man's picture
Last seen: 10 hours 1 min ago
Not a flashlight, but I changed my fog lights from 4000K to 2600K Smile
Sorry if it’s offtopic, but it makes me happy and I wanted to share it…
“The saddest aspect of life right now is that science gathers knowledge faster than society gathers wisdom.” - Isaac Asimov
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F /// Zanflare F1
Flashy Mike
Flashy Mike's picture
Last seen: 5 days 17 hours ago
Emisar D4, RGB + White:
The 5 channel full ramping driver (FET+1 for white, red+green+blue) with 2 additional resistors for ultra low white moonlight and red indicator light, color channels pretty overdriven for about 1.5 Amps at each color XP-E2 (NOT recommended though):
Very nice beam:
Even nicer rosy beam with all LEDs on max current, about 1500 lumen (white LED is XP-G2):
djozz
djozz's picture
Last seen: 13 hours 29 min ago
Wonderful! That is a cool driver.
I had made a similar light two years ago with the DrJones RGBW driver, a Dsche quad board with some cuts, and a re-build Solarstorm SC02 (and it is still one of my favourites!), but the D4 makes it way easier.
Flashy Mike
Thanks, it were your posts about the color driver with D882 which made me build this driver. I’m using this light as EDC for about 3 weeks now and it’s the best EDC I ever had.
MRsDNF
MRsDNF's picture
Last seen: 3 weeks 5 hours ago
Thats one amazing clever mod Flashy Mike. Well done. Beer
djozz
djozz's picture
My adventures with that driver felt quite lonely, I do not think after me anyone has ever tried to use it like that. But i’m glad it inspired at least you Smile
DB Custom
DB Custom's picture
Way cool, great out-of-the-box thinking guys, well done! Big Smile
CRX
CRX's picture
Last seen: 3 months 1 day ago
Very nice Thumbs Up
ToyKeeper
ToyKeeper's picture
Last seen: 1 week 4 days ago
That’s interesting… What is the driver? How does it do 1.5A per color instead of 350mA? Do the chips get hot burning off the wide voltage gap for color LEDs? How low can the color ramps go? What is the firmware and interface like?
ToyKeeper
ToyKeeper's picture
This reminds me I should probably finish a few more details on my RGBA firmware. It’s not intended for flashlight use though; it makes patterns which look more appropriate in a lightsaber. The general idea is that the user can make their saber’s illumination pattern(s) unique in much the same manner that one builds new sounds on an analog synthesizer. Except, um, simplified to make it more accessible using a single button.
Flashy Mike
Driver is my own design, Attiny 841 with FET + 7135 for white channel and 3x D882 transistors, one for each color channel. Got inspired by Djozz’ posts about a simple RGB driver with this transistors which Richard sold a while ago and Kaidomain still sells. Maximum current through color LEDs is controlled by the base resistors, and the D882 indeed get pretty hot since they are seriously overdriven with 1.5 Amps. For ‘standard’ users I would suggest higher base resistor values for lower LED currents. But I’m using the light for about 3 weeks now in this configuration, often fully powered, without any problems.
In addition there are resistors from mcu i/o-ports to both white and red LED for ultralow pwm-less moon (with sleeping mcu e. g.) and red indicator light (using the red LED).
As you recognized the lowest color ramp value would still be pretty bright so I increased the pwm range for the lower ramp part (which lowers the pwm frequency of course), but pwm frequency is switched back to about 16 kHz with higher currents. Color LEDs brightness at lowest ramp value is now similar to lowest 7135 level with white LED. Ramping is completely smooth.
UI is a ramping one, similar to Narsil, with some gimmics and optimized for color cycling.
