Are we sure the OP that people are seeing is actually that and not just milling marks.
I grabbed a couple of lights and had a look at their reflectors and realised that my “silky smooth” Niwalker light actually appears to have ring marks on the reflector when you look at it from the right angle.
Still waiting for mine to land in the UK - well, it might be in the UK but no tracking has made its way to me.
lol Dale. When the comment was made that your reflector must have been perfect to hit the water tower I chuckled knowing that our lights shipped at the same time and likely looked the same. My gt has the exact same surface as yours. I’m happy with mine. What is really great is it was suggested that the reason the warmer emitter version had less light on target was because it was probably a light with a slight op reflector. Looks to me like the light you swapped the cw emitter in has the same dreaded op ish reflector. Thanks for the pictures once again! It would seem the the throw of the gt is excellent with that reflector
Tom knows about the switch light on off “feature”. I’ve done it many times on the Q8. When your ramping up from on or anywhere hold the switch from the ramping then quickly click it off. That should change the standby switch light from off to on or vice versa. The software on the GT is different and I played with that setting not my GT, just the Q8. Hope that helps.
Mine arrived in Sydney Australia yesterday, 1 day before the DHL estimate, ~3 weeks after payment.
What an amazing flashlight, it is great to see we can still make such high quality items at decent prices.
I could now use a cradle to mount it in a vehicle, also perhaps a snap-on cover to spread the light as an option; simply some accessory ideas from a happy customer - thanks to all who made it happen.
@DB Custom and lawallac
thanks, but no result. Switch cover is definitely not opaque, I unscrewed it.
It must be lighted, at least after successfull factory reset.
