raining out im bored.
just shot the lux meter with the gt on MOONLIGHT
it was 1000 lux at 4 meters on moonlight
probably more if i shot it at 10 meters.
crazy light
OK… It is then up to Lumintop & Neal’s QC to give final pass to reflector.
TA stated that Team OK was given to V1 reflector & anything ‘better than that’ was a bonus.
But it also seems LT is making every effort to provide the best reflector possible in this price point light. Maybe even better quality than was expected.
The slight inconsistencies we are seeing appear to be in the final finish/coating, not in the machining.
It appears possible that maybe a tiny number slipped through the QC control. But, as stated; that is yet to be confirmed.
As I understand what TA said…. everyone will get ….
……. a reflector ’at least meeting’ the standard the Team OK’d.
To me, NikolaS was simply saying they were using a big CHUNK of aluminum. I did not read it as a reference to shape.
I read it as “block” = “chunk”…… nothing more.
block
bläk/Submit
noun
1.
a large solid piece of hard material, especially rock, stone, or wood, typically with flat surfaces on each side.
“a block of marble”
synonyms: chunk, hunk, lump, wedge, cube, brick, slab, bar, piece
“a block of cheese”
Picked up a new toy……………indispensable measuring tool today. I’ve been what I call a connoisseur of light for a decade or so now. My sweet spot is 5500K. I’ve just not been able to get into the neutral or warm Whites. There is only 1 incan bulb in my house. Everything else is LED 5000K or 5500K. Now I can precisely measure all of my home, car, searchlight and other lights’ color temps and the REAL CRI, not just the averaged number usually quoted for marketing purposes. I’ve learned quite a bit over the last week while researching my purchase. The typical CRI number we see is the calculated average of 8 colors chosen decades ago by a Body in France, the name escapes me now. It represents how close a light source comes to the spectrum emitted by Tungsten incandescent light. CRI of Tungsten light is 100 on the CRI Scale. Extended CRI adds another 7 colors to the mix and the Sekonic 7000 meter has the capability to measure and display the additional 7 additional colors. The more color samples that are taken, the more accurate your CRI is going to be. But even CRI is a bit outdated and there have been and are processes in-motion to use another standard or two. There’s a lot more to it but i won’t get that deep. Suffice to say that below, the first 2 pics are of readings of the Sun. The first shows the Color temp in Kelvin (Tcp on the meter) of the Sun at 3:15 PM. Don’t pay attention to any of the lux reading as I did not set up for a precise Lux measurement. The next pic shows the CRI RA average calculated on only the first 8 colors in the bar graph but it also shows specific individual CRI readings from all 15 samples. The higher the bar graph and number to the left, the higher the CRI of each of the sample colors and the closer to the Tungsten standard the measured light source is.
The 3rd and 4th pics are of the same type of measurements of the GT on HIGH, not Turbo. The 5th and 6th pics are of the GT on Turbo. Notice how the R9 Red is absent from the GT and is actually a minus number.
If you search the net to purchase a “block of aluminum” google will show you nothing other than square, flat, or rectangular stock. Anyhow, I get the point…
Teacher, I would like to be on the same page here. This block or chunk of aluminium is round stock and I would assume it is being turned in a CNC lathe?
I’m curious to how this reflector is being machined. Do you or anyone know of the page this info can be found or if this information was revealed, possibly a separate thread?
Not everyone here realizes how much work and time is involved into producing such a (masterpiece) flashlight like this…!
As far as machining goes, I think we should shine some light on the subject. I think it may help ease the frustration of some of those who were unsatisfied or complaining about there reflectors finish.
