Well good news and bad news for me. Good news I have all the parts. Bad news is the Noctigon 32mm does not fit. It will not sit flush against the shelf. Bought the xp32 with LEDs already on so guess iâll be learning to reflow LEDs on a triple :person_facepalming:
I was wondering if them Noctigons would be a good fit or not. Now we know for sure. Thanks for the heads up.
Thatâs strange. Dale (DB Custom) used one in his (link) and I donât recall him saying anything about machining the shelf. Granted, that was on one of the very first units before Sofirn changed emitters, used DTP, etc. Maybe they changed the shelf in the second batch.
I know I didnât machine the shelf, I may have used a file to reduce the 32mm MCPCB slightly. Would have done that by hand, have done that kind of thing so many hundreds of times it wouldnât be something Iâd really remember doing.
I have a 12â double cut bastard file on my work table, I lay it on the edge of the table and run a round mcpcb (or whatever) vertically down the length of the file while giving it a bit of a turn, reset my finger hold and do it again, turning every time to maintain the circular profile. (Thumb and middle finger on the sides, index finger on top, pressing down⊠like a wheel but not rolling, just a slight turn every pass) Takes but a couple of minutes to turn a 32mm copper disc into a 31.7mm disc for an X6, for example. Also drill a hole through the center of the 32mm board, where the center XP pads are, to keep from getting the wires in a bind.
I used 18 ga leads and they fit in the cut-outs on the base of the reflector. As I recall I sealed them in Arctic Alumina Thermal Adhesive so theyâd not short out.
Jerommel, that SS switch assembly lighted by blue is really nice!
I didnât check the e-switch CF8 to see what it was, but the shelf on the Push Button CF8 is 30.5mm. But the reflector was almost a direct replacement for my Convoy C8 Triple SST-40 Optic build using âkiribu-raâsâ spacerâŠneed to take 1.25mm off the back of the spacer, so the bezel closes up, otherwise NICE!
Pretty racy looking Convoy you got there Scott!
Got a pair of C8F side switch hosts in the mail today. Cold and wet, they were! Mustâve been quite a trip getting here, the boxes had been wet inside the bubble wrap long enough to essentially disentegrate when I opened them to get the lights out. Nothing wrong with the lights, of course. Time to build one up and see how she be!
I had forgotten how tricky building one of these is! The copper MCPCB being screwed onto the reflector, then the reflector having the center screw to snug it down inside the head, with the side e-switch, a lot going on in a small space!
Used XP-L2 V6 5000K emitters, 22 ga wires, and built a MTN FET driver with ToyKeeperâs ramping firmware from last century.
Grabbed a rested Sony VTC4 cell and saw 8.25A pull at the tail, with the cell at 3.7V! lol This should be interesting when the cell gets charged upâŠ
Edit: On the fully charged VTC4 it pulls 12.15A at the tail for 3860.55 lumens out the front. Pretty decent, Iâll take it.
Replaced the tail pcb with a copper disc, soldered a heavy gauge berrylium spring directly to this disc. Then put 20 ga bypasses on the two like springs top and bottom. The result? Same VTC4 cell, fresh off the charger, 4115.85 lumens.
Now weâre talkin!
Nice. Iâm curious to know how long it lasts until it getâs to hot to hold. Havenât touched my host yet. Too busy with programming drivers âŠ
I held it for 3 minutes in a 73Âș ambient setting.
I got six of these hosts to play with. The driver retaining ringâs inner diameter is a little too small for my double sided drivers though. I could file it out but Iâm too lazy to do it six times, Iâll just design a new dedicated driver and let OSH Park take care of it
As only one of the very few that can Mike.
Thanks, so itâs pretty usable for high lumen output. I think I will do something similar with my host.
Should probably elaborate, I held it by the head for 3 minutes, it was getting quite warm to the point of being hot indeed. Some cooler night air on it with flow would take it longer, of course.
This should translate out to around 1372 lumens each emitter at just over 3A each, so the heat is fairly manageable for this emitter. Considering slicing and dicing to tighten up the beam profile, have to play with it some more firstâŠ
I chose this light as my first full flashlight mod and it makes me feel better when Dale says the word tricky when describing it. Between the e-switch and the way the reflector comes together things are very tight. Needless to say there is plenty here for me to âlearnâ in just this one single host.
I found it easiest to solder longer-than-necessary wires onto the mcpcb, attach the mcpcb to the reflector (loosely, so it doesnât pull it down tilted due to the centering rings) then put the mcpcb/reflector assembly into the head (with thermal paste) and flip it over to put the central screw in, snugging the assembly into place (have to watch orientation, the mcpcb screw has itâs own cut out in the shelf) Once the driver has switch wires soldered on I cut the leads to length and solder them onto the driver. Everything gets tucked in and the retaining ring installed.
Like doing surgery, almost. lol
After some trial and error this is basically the same conclusion I came to as well. However, since I was not confident in my assembly I kept the longer than usual wires and spent a lot of time stuffing them in the body so I could test before the final âsnipâ. Needless to say I re-did my solder a few too many times (troubleshooting my switch) and I think I bridged something I shouldnât have. I was testing with a protected battery and kept getting no light. I got curious and swapped to a VTC6 and needless to say I got something, magic smoke. Pretty much right after I tightened the battery down I could hear the battery was suddenly âlooseâ in the body. It had instantly vaporized the tail spring including the bypass.
Ordered a new driver to get a clean slate and surgery will resume this weekend.
Ouch!
My buddy wants to know why they call it magic smoke? He says itâs satanic. lol
Iâm thinking of disassembling mine completely and baking the finish, need to differentiate this one from the otherâs and thatâd be a good way to do it. (Yes, I really really like how Kawiboyâs Convoy came out! lol )
I like the way ZozzV6 did his L2 with the gradient. I was able to do something âsimilarâ on my M1 without much experience. The burnt orange going towards the torch end just seems fitting.
My miniature knock off. If I did it again I think I could prevent the bezel (itâs super THIN) from becoming too brown with a little more caution.
