Amazon had a package deal the last week of December where I picked up this light, a Sofirn SF31, 18650 and USB charger for $16 but that deal has passed. Always good to look at the bottom of the main description for offers like that. I almost missed it.
I received from AE the blue SP10B a couple days ago - the black was out of stock.
Very nice AA/14500 light with side switch for the price! Very bright too. From what i can measure off a ceiling bounce, it is a tad brighter then UT01 and Mi7 and it is noticeable in real use. I also like the beam.
The only annoyance is the UI and mode spacing. Although i do have a number of lights with the ‘long press’ for on/off, i still don’t like it much. I can get used to it if i use one of those lights on a regular basis but each time i pick one at random i struggle to turn it on and off.
The other issue is the gap between what amounts to a very low moon mode and a rather bright mid mode. There should be a ‘regular’ low mode in between.
Overall a very good value 14500 light.
Well done Sofirn! :+1:
I”m guessing the black SP10B run out of stock during the flash sale. I think their SP10A which comes in black is now being sold as the black SP10B. They updated the SP10A with the newer driver so it is practically the same light.
I guess now the SP10A is now the black version an the SP10B the blue and red versions! Both having the “old” black SP10B driver (ML-L-M >> H / >>> Strobe / >>>> Lockout).
Hey, did anyone ever measure parasitic drain in the A and/or B?
Reason I’m asking is that I was carrying both, one with an eneloop and the other with an LFP cell, and both were dead dead dead after 1 day. The LFP might be suspect, as my LK202 “charged” it in minutes right out of the wrap, and after dead also “charged” it in just a few minutes. Even resetting it and forcing the LK to think it’s a Li-ion cell (3.7V vs 3.2V), it just charged a minute or so more. Odd.
Still, to kill an eneloop which is now charging pretty much from 0, seems really odd. Don’t think both got accidentally turned on in my bag and thus ran down completely, but…
I’m going to run both through some alkaleaks and hope they don’t do what they’re (in)famous for. After that, some more tests (if I can find where I put my meter last… :confounded: ).
Didn’t measure, as I don’t have means to do so! But mine (SP10B) is “stopped” with a Sofirn 14500 inside (with some use), all threads tightened up and it works fine! No major drain, at least not like yours!
Lightbringer, I don’t know if that may have something to do with this case, but at least the SP10B manual doesn’t refer any “compatibility” with Ni-MH or LiFePO cells. Not sure if that is just a way to protect those types of cells once it only has Low Voltage Protection for Li-Ion cells.
DMM’s reading a rather bouncy 20µA-40µA, and that’s it. Not likely to drain anything so fast. eneloop took a long while to charge from essentially 0, so maybe the switch just got bumped on in my bag/pocket (forgot which I was carrying where). Both LFPs I’m playing with charged to and are holding 3.35V, and after intentionally burning ’em down maybe 5min on H in both lights (A and B).
Think actual TCLO is safest, ’though the B has its soft LO.
Do have to say, even though I liked the A quite a bit, the B kinda blows it away. Doubleclick to turbo, real firefly mode, soft LO, and a much nicer tint (nowhere near as yellow-green).
Hum, don’t know, but that may have happened, switching it on inside the pocket!
I know this may sound weird, but perhaps you need to try one more time with the exact same sets, to check if there was a anomalous drain or to see if there was an accidental turn ON.
Normally these side switch lights, I loose the head a bit or the tail just to avoid accidental turn ON in the pockets, a slight loose, enough to turn with one hand when I want to turn it ON again. I do that with the Manker E11, Olight S1R, Emisar D4, Sofirn SP10B.
In that way, tailclickies are better
But I do agree, the SP10B is :heart_eyes: !
I can’t see any “greenish” tint on mine, it has beautiful NW tint
I was going to leave them home, but not LOed, to see if there was any kind of drain. But with both the A and B only sipping ~30µA, I doubt they’re to blame. Probably just turned on accidentally, and drained ’em dry.
And people piss’n’moan about twisties…
Not the B, which is a nice non-green 5500K-6000K if I had to guess. The A, though, is kinda horribly yellow-green. Doesn’t seem like it at first, but when I got 2 of ’em side-by-side shining on the ceiling… gah!
I’d say the A is about on par with the F1 and Jet-I/-II as far as greeniness.
The brightness of my B is not far behind my S2+ with a 14500 . Mine holds charge in pocket but I glued a washer around the button . What is going on now with the Black A , red and blue B thing going on ? Is the A the same as the B now ?
Mine’s a first-edition A, but the latest As seem to have the same UI as the Bs, from what I heard. I don’t have any, so can’t attest to that personally.
