Less space between the inner diameter of the reflectors and more throw. Better usage of aviable space.
hIKARInoob: JasonWW: hIKARInoob:with non overlapping reflectors what are the advantages?
No strange petal shapes around the edge of the spill. You get a perfectly round spill edge.
Yes I understand. I thought the discussion was about a single piece 9 emitter design; what are the advantages compared to 9 discrete reflectors?
Ah I think I get it. Even with discrete reflectors you should be able to further increase diameter looking at what it is now. But I can imagine if you want to squeeze out the last millimeter of space between two reflectors you need to switch to a single design.
leaftye:Can we get the driver specs to Lexel, TexasTA and whoever else can start designing a good driver for this? It can’t hurt Astrolux to share that info since there’s no way they’ll make a driver that will satisfy all of us, probably not even half of us. Play the game Ford does with the Mustang, and get the pertinent info out there so the aftermarket is ready with mods, which will help drive even more sales.
The Texas Avenger driver will not work in this light due to the dual switches and dual emitter sizes. Astrolux is probably combining 2 different drivers into a single pcb or else using 2 pcb stacked to drive it.
I believe Astroluxs driver design will be kept secret and not made available to anyone. Sorry.
On the other hand, if you want to forget about powering the xhp35 and just use the 70.2’s, then the current TA driver will work fine for that. It will only use one of the switches.
This is not true on this size of the driver it would be no problem using 2 MCUs to control each LED type seperately, with upcoming Boost driver on Schokis boost chip next month we can also deal with 12V XHP voltage from 2S battery pack
Wieselflinkpro: hIKARInoob: JasonWW: hIKARInoob:with non overlapping reflectors what are the advantages?
Even with separate reflectors of the XHP70s you can CNC the edges off so that their radius is with little gap or overlapping
Assuming it will be using 8 18650s and with the best cell being able to output 30A, maximum current will be 120A with 2s configuration. This means 15A max per emitter= more or less 65.000lm at the absolut limit.
All 8 cells would be depleted in just 5-6mins!
Better 12x 21700 cells for double runtime :money_mouth_face:
Exactly. You still have a little gap, pfff… like a millimeter or so. If you want to get rid of that then you could look into a single piece 9 emitter design. But that’s most likely not worth it (besides looking darn good).
Wow, this is great news. I did not know you were working on a boost driver.
Plus you can have 2 MCUs? Awesome news!
You never stop amazing me Lexel. Lol
Assuming it doesn’t melt internally first. Lol
need more tease?
1st prototye
can you share more info on this Lexel?
I was wondering why there was such a gigantic hole in the center of the head “shelf” of the black MF03. Now We know why…reflector !
WOW King Arthur surrounded by his knights! A flooder with throw! How SWEET is that Thank you M4D M4X for the Picture! AWESOME :+1:
Following
Lexel:with upcoming Boost driver on Schokis boost chip next month we can also deal with 12V XHP voltage from 2S battery pack
He’s working on making his own boost driver. Here is what he told me.
For 17-30mm is a Boost driver in development which should deliver 5-6A at 6V and 2.5-3A at 12V
I’m hoping it will be able to run NarsilM, but I haven’t heard back from him on that.
rizky_p: Lexel:with upcoming Boost driver on Schokis boost chip next month we can also deal with 12V XHP voltage from 2S battery pack
Here are more Information / Pictures: Driver & Led PCB Community Edition | Taschenlampen Forum
Any hind regarding the expected price for this monster light?
@M4D M4X: in the OP you state 7 x XHP70… but i count 8 in the pictures you posted.
Even at a conservative 3k lumen per emitter that’s no less then 24k lumen! This light will certainly peel paint and repel bears from a mile away!
Good point, I want to know too :laughing:
Hey, your right. At first it was 7, but now we see 8. I’m not complaining! Lol
8 seems to fit just fine. 7 might have too much wasted space.
i asked for 8 at the beginning - they said 7 .
but i got surprised with 8 of the big ones :D
i am not complaining either ;)
i like the Excalibur reference :)
This looks simply amazing. I can’t wait to see more.
