No.. I have had my retail license for several years... When the first new models of the Imalents came out I submitted my credentials and they sent me a price list...
While I would never just say what the exact amount would be (that is just something retailers don't do) it is not like it is classified information, it's just kind of an unwritten rule not to go out giving people prices..
What I can say is that price is not even close to Imalent suggested retail price. The company selling at that price would be lucky to break even after shipping,, Maybe depending on how many they purchased and possibly got an extra 10 percent break... At best they would only make a few dollars.
I also intended to mention to notice where I have the light pointed. In the first picture you can see that I have it pointed on the ground about 30 feet from the wall I wanted to light up. The spot is on the ground and it still lit up that entire area.
Same in the second picture, look at the beam I have it pointed above the building and again it still lit up everything you see.
Thanks for the reviews… we should be thanksful with the 15000 lumen and 90k lux for the stock pop can light… 2 years ago, pop can light came in 7000 lumen and 30k lux, unless you buy the modded version. ( still 12000 lumen / 60k lux with the modded light)…
Terry,
If you have a chance, could you upload some photos of the light in hand? Or maybe with some common objects in the photo? Trying to get a grip (pun intended) on the ergonomics of the light. As I mentioned earlier, I love the idea of small form/big performance, and trying to decide if this fits the bill. I did see the opening of your video, which has some “in hand” shots.
Thanks!
You can count on that... Each one will have their own uses. I am more than sure that the 35 high will out throw the 70.2 version and a lot of people want that extra throw over total lumen output. Others want a little of both. I believe that the 70.2 version will be a better choice for someone looking for a light that does both throw and still cover a pretty wide area with intense light.
The 35 high will be the customers that want a much tighter and much farther throwing light. Still enough power and light output to light up a smaller area at long distances. 600 meters for the 35 high should be a walk in the park.
Me I can never choose. I always end up finding some excuse that I need both when models like this come out LOL..
Not really much to compare... The Astrolux is a very bright light it would be better compared to the MT03. Both are massive flooders. The latest version of the MT03 using a TA style driver and 12k lumen output.
Honestly I would need an Astrolux here to compare the two.
To compare it to the MT09R I just can't think of but 1 outcome. The Astrolux would have much wider beam but much shorter. The MT09R with it's extra power and mucj better throw with 90000 candela verses a out 54000 candela.
Just 2 different types of lights.
I have an MT03 here but BangGood shipped it to me with a bad driver. I have a driver on the way, once I install the correct driver I would love to have a chance to do side by side comparison of the 2.
The tir lens of the mf01 puts most of the light into a large hot spot and the spill lighting is pretty weak. Typically you’ll need to move the light around to see to the left, right and around your feet if you walk at night and have the light around 600 to 1000 lumen.
The MT09R 70.2 should have a smaller hot spot combined with more spill light. Under the same circumstances I mentioned above, this reflector based light will allow you to hold it straight and still be able to see left, right and around your feet.
Think the MT09R should have a very similar beam shape as your Q8. Just with a slightly bigger hot spot.
If he includes one in the package with the 35 high sure will, can never have too many chargers...
I wish there was a way people could actually see that blast of light and massive chunks of aluminum this is made from. This is like their MT03 and MT07S very thick very heavy dense aluminum.
Best part is that it really does what it is supposed to do.
It does step down.. At 55 degreesC it will step down but as soon as it does you can kick it right back into turbo and it will stay their for another 60 seconds and step down again. You can do this over and over as long as you can stand the heat. So basically it will hold that max output as long as the batteries hold out. That is why I have not bothered with a run time test. You can just keep kicking it right back in all you want to.
When the 35 high arrives I do need to check lumen output after step down. I realized this morning I had not done that...
