Leatherman Tread Flashlight Bit
That is ridiculously cool!!
Nice work.
So, how do you light it on ?
If you see the small check out of the back corner of the unit, well there is a corresponding piece of copper press fitted into the leatherman segment so you push the LED unit back into the body until it makes contact and push it from the back to turn it off, like a slide switch. Itās held in by friction. Doesnāt look too bright in the pictures as I need new cells.
CRX - this is getting out of handā¦.
:+1:
8) 8) :sunglasses:
I do not respond to all of your mods (soo many), but I do think they are all outstanding. But this one is extra cool because it fits so well in what a multitool must be.
Awesome build, CRX!
What do you think of adding elements with color LEDs?
Thanks mate
Thanks. Yeah Iāve been thinking about how to do an unobtrusive light on the tread for a while, the problem was always the cells.
These two SR364ās are in series, which was the hardest part, check out my first attempt with an XP-G2 :laughing:
Can be cool, your D4 colour mods are great :+1:
I think the last colour mod I did was the dual DQG Hobi amber
Pls crx go away. Your mods are way too awesome!
Seriously, very impressive! What you can come up with and make.
Same here.
Great job CRX.
They say great minds think alike.
The mcu can measure voltage internally. Voltage divider would be required for multicell serial setups though, which is not the target for this driver. Itās mainly designed for multicolor lights.
Unbelievable, this is way too crazy cool as with all your mods ā¦
:+1:
I didnāt even know such a thing existed, and here you are modifying it! Sweeeeeet!
MRsDNF, if great minds think alike that leaves youā¦ where, exactly? (you know good and well you left that wide open!)
A guy here struggling to make a simple triple and you make this CRX?!!! Aināt fair
Nice mod, thatās really cool!!! :sunglasses:
Aināt it the truth MacaratumB? Heās putting out Picassoās while some of us are playing with crayonās.
And on that crayon note, I stuck an Zener modified FET driver in the little solid copper X5, put a sliced and diced XHP-50.2 on an XM-L board with 20ga leads, stripped the resistor off the lighted tail cap (Zener modded FETās donāt like those) and will be using the little copper light with a pair of 14250ās. Charging 2 of those up to see how much light they give, it looks neat in there anyway even if the little cells arenāt up to it.
From the BLF Kronos group buyā¦
Number 003 of 400
I have a tread copy from Gearbest. I really neeeeeeeed to make this flashlight mod. What other mods you made to it? I saw some magnets and tritiums and a black thing on that flashlight piece next to the glassbreaker. What it that?
Iām just a poor old dumb Moose, :cry:
