Pure white is a strong relative term. A lot depends on the lighting that surrounds us. For me, the range I like is 4000-7000K, but the most is 5000K. At night, 4000K works better with street lighting or fog. On a cloudy day, I prefer 6500K etc.
The graph helps in determining whether there are any additional shifts towards a certain color. To calculate the temperature of light on the basis of x / y, I use such a simple formula
Yeah, a lot of the cheap lights come with the blue emitters. That’s why it’s great to get such a good tint in the Convoy C8, nice price and nice output, win win .
Convoy is gone use a new kind of clear ano right?(clear l6 giveaway)
Is the c8 gone get this new ano to. I got a clear c8 right now but it looks kinda cheap imo.
I prefer the 3D tint that a lot of BLF lights use, rather than the the 3A tint that Convoy uses. The 3A is okay, but it looks a little harsher than the 3D, to me.
I agree, on mine the clear anodizing looks kind of cheap to me too, but I really like the light overall, especially the programming and the 3A tint. I actually prefer the anodizing that’s on both of my XinTD V5 lights. These are just super quality lights. They have a 3C tint, which is really nice too, a favorite of mine. I do wish that they had the same programming as the Convoy so I could use half-presses to change output. Is this something that could easily be done, and if so, how?
That sounds like the driver used in the Convoy L2 (3A, 900mA, 80mA; with half-double-press for strobe).
I’m not sure if the Convoy L2 at low modes has PWM or not though.
A friend asked me to build a host C8 in clear ano for him, at first he wanted a triple, mega power, but after some talking to him he decided on an XHP-70.2. So today I built his light.
I had some issues with the 70.2’s I had on hand, mostly they were previously used and removed for whatever reason, but the main two I tried only had two working dies. One produced dim light, the other a lot of light but still only two dies. So I removed a sliced and diced 70.2 from a Solarforce light I have that is never used, the orange peel reflector is heavy enough that it fares better with a 70 anyway. And WOW!
I built a Zener modified FET driver with 6 modes, Vishay SIR800DP MOSFET and 20 ga leads. SinkPAD board, stacked a couple of copper discs on the spring pad to clear the retaining ring and the two Aspire 18350 cells fit right in, no other modification necessary aside from opening up the reflector to clear the larger 70.2 substrate. Would you believe it does 11.82A at the tail and 6676 lumens out the front? Crazy C8! My friend is just gonna fall out! lol
It is hard to believe those 18350s can pull that many amps. I have a “close” setup, but using a pair of 26350 and a xhp70 and can only get maybe 8 amps from them.
I was thinking it’s the limit of the purple batteries. Maybe a 70.2 will pull more power from them?
I’m waiting for Lexels boost driver. It should do at least 6A at 6v so you can run a 70.2 with a single 18650 or 26650 and gave consistent output.
So 80W in a Convoy C8, impressive! That must be close to the heat build-up speed in a D4. If only you could have Toykeepers D4-type thermal management in a clicky driver, that would be very useful in this light.
I know, right? Heck, I about fell out when I saw the meter! Really close to the output of a fully modded L6, from a C8! Of course, run time will be counted in seconds instead of minutes, but my buddy likes the wow factor so it’s right down his alley… lol
