Convoy L6... XHP70 Beast!
Same…Block or Ring style 2x26650 tubes will work between the L2/L6 even the 2pc L2 tubes. all interchange/lego.
Yep. XHP70 and XHP70.2 are the same.
Excellent. thankyou KawiBoy :beer: :beer:
:beer: :wink: :+1:
I have a question about where to buy silicone sidecaps?
contact simon on Convoys aliexpress store.
https://convoy.aliexpress.com/store/330416?spm=2114.12010615.0.0.6679a900rqxbiN
send him a message and he may be able to send you some just for the cost of shipping.
thank you
I got 2 protected KeepPower 26650s from Banggood for $18.11. I used the generic 4BLF discount code. Ordered 6 December and received just after Christmas. These are the batteries Convoy recommend for the L6.
They are in stock. I just checked.
the keeppowers are real shortage why its drivin me nuts… been checking nkon forever and they are never in stock… i dont get it, is the production on those halted for now or?
Can you order them from Banggood? They had them in stock a few hours ago when I checked.
Thats good new, thanks!
Is 10-12A discharge ok for a 26650 battery for the L6?
10-12A is rocking along pretty good, fairly high end without being a top fuel dragster. :slight_smile:
Thanks! Wasn't sure as I don't understand the technical side of it but if you say its good, I'm good!
That is about the most a xhp70 can handle.
The xhp70.2 can handle 18 to 22 amps.
Sweet! It’s really a good one.
  • Low – 50mA
  • Med – 200mA
  • High – 1700mA
  • Turbo – 5000mA
Based on the the L6 info above, for a set of 5200mAh batteries, would my run times be in the ballpark below?
Low=100 hrs
Med=25 hrs
High=3 hrs
Turbo=1 hr
I would say that looks very accurate on the runtimes more or less.
Theoretically, yes.
Realistically run times will be longer as the light will quit pulling those listed current draws as the cell dies which will put the run time on a curve in the end.
I’ve wondered for a long time about absolute run time even on a constant current driver, because as the cell dies the driver will pull on it harder to maintain the set current and make the cell die even faster, so the tail amp draw goes up as the cell’s voltage goes down, would a 5000mAh cell deliver one hour of run time at 5A constant current? Don’t know that I’ve seen anyone chart that kind of driver out for provenance. (they probably have, I just don’t remember)
I haven't been game enough yet to just leave my L6 on in different modes to test how long it really runs.
