Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
https://www.ebay.com/itm/182838817033
Seller accepted an offer of $9
Thank you.
What is your opinion regarding this holster:
https://www.aliexpress.com/store/product/Genuine-FLYYE-Smoke-Grenade-Pouch-In-stock-Military-camping-modular-combat-CORDURA-G003/1083515_32777569533.html
Is it good buy or do you recommned something else?
Kind regards
Interested also. :+1:
> holster
Also search for “tripod” in the thread. There’s a variety of ways to attach to the tripod socket, some of which include belt clip/quick release attachments.
Just wanted to note that I as well had issues with the indicator light under the switch in my Q8. I think I was one of the first to receive it too, taking delivery in October sometime if I’m not mistaken. Anyway, I wanted to share with the thread that I followed the prompt of Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light - #16704 by AlexGT to remove the switch cover and fiddle around with the LEDs and resistor with a soldering iron (while batteries were installed and the light was off) and I was able to revive the LEDs to full brightness. Before this fix, I had not seen the LEDs illuminate in weeks.
Anyway, let me know if anyone has questions!
Excellent info kubed_zero!! Glad it worked out for you…… :+1:
I remember previous message around December last year that the nth batch of BLF Q8 has been released and it now has Narsil firmware v1.2.
Are the ones shipping from Banggood already with v1.2 firmware?
(My BLF Q8 ordered near end of November, which shipped in December still had firmware v1.0)
Also, are there any other new tiny improvements/adjustments to the Q8 quality issues?
Not sure about the v1.2 firmware.
But the tiny issues were resolved after the first 500 lights…. long ago.
I have not heard any confirmation that they switch firmware to the newer M v1.2. I think they wanted to or planned to, but I don’t think it has happened.
I ordered mine on 2017-12-24 and it is also using version 1.0.
The difference between 1 and 1.2 are only different blink modes, right?
No, the 5 blinky modes are the same.
The main difference would be the wrap around feature. If your using mode sets or are in the blinky modes you can press and hold to go back a level an infinite number of times. NarsilM v1 would turn off when you went back too far.
It also has the 5 click momentary mode.
I think there are a few little things tweaked and improved upon.
Overall, not a big change.
NarsilM v1.2 can also be programmed (at the factory) to ramp up to a certain level below max and then access max (turbo) only with a dbl click. It’s handy on the GT buck driver, but I don’t think they would use that on the Q8 FET driver.
I’m looking to get this light. Would 18650 KeepPower 3400mAh Panasonic NCR18650B Protected Button Top be suitable or should I go with something unprotected? Asking because I already have 4
That should work fine.
Ok thanks. They have only been used together. Just wasn’t sure if it would trip the protection but I think I just found they should do 10a fine
I think the most amps the Q8 will pull with the best cells is about 16 amps. So that’s 4 amps per cell.
The protection circuitry adds some resistance so maybe you will see 14 amps? That’s 3.5A per cell. That should be no problem for those cells.
Oh thank you. I do not think these are crucial features I would need.
What??? Of course you need them. Everyone needs them.
Just curious, how does protection circuitry work?
For instance, I have the LiitoKala Panasonic NCR18650B protected 18650s, whose protection I have tested to trip at around 6A (tested in Astrolux S41S).
I tested using the same single protected Panasonic NCR18650B (only 1 battery) on the BLF Q8, and it does trip when I ramp up the brightness (trips not yet reaching max brightness). Then I tested just inserting 2pcs protected Panasonic NCR18650B in the BLF Q8 — I could turn on the BLF Q8 in Turbo mode and the protection circuit does not trip at all.
Since 1 protected battery trips at 6A, does that mean if 2 batteries used, they would trip at around 12A? Now since the BLF Q8 did not trip when using 2 protected NCR18650Bs at the same time, would that imply the BLF Q8 uses less than 12A at Turbo?
The protection circuitry in batteries do many things.
It protects against:
Over voltage (while charging)
Over discharge (when using)
Over temperature (sometimes)
Over current (limiting amps)
Short circuit
No. There are other factors at play. When you use only 2 of the protected cells you get higher voltage sag. 2 cells will droop down to a lower voltage under load, compared to 3 or 4 cells which limits the amp draw. Higher voltage equals higher amps. Remember Ohms law.
It would not surprise me to see 2 protected cells in the Q8 only draw 10 to 12 amps.
Battery chemistry also comes into play. The Panasonic B & GA cells at 3400mah and 3500mah are designed to give longer runtimes at the expense of max current output.
Then you add the extra resistance of the protection circuitry added to the cell and you just don’t get as many lumens.
It’s still plenty bright, but 4 high drain, unprotected cells will give you the max current and max lumens.
I kind of lost my train of thought here so hopefully I answered your question.
I just put cells back into my Q8 from the first batch, after not using it for a long time, and found that the switch light is no longer working. This is not really a major crisis, but is there a replacement available?
