This is the original D4 switch (without dome), 4.5 x 4.5 x 0.6 mm (height approx. incl. dome):
(Got a cheap macro lens for my smartphone)
Height without dome is 0.4 mm, so I think giorgoskok found the right one. Thanks!
Updated previous post with a 30pcs link ,if it’s the correct switch of course :+1:
Another seller:
https://de.aliexpress.com/item/AJ-098-Imported-ALPS-film-type-dust-SKRM-light-touch-switch-4-5-4-5-4/32777851533.html
Height is claimed different, but I guess it’s just a typo.
Just finished my 2nd triple
There are a few things though
I’m not really happy with how close the amc’s are with the spring and its not noticeable brighter then my other triple with 2,8A convoy biscotti.
The last thing is, i wanted a lighted tailcap, Lexel already mounted the resistors needed (thanx) but i did not get the convoy lighted switch working.
After reassembling the old switch it does not function anymore.
I reassembled it several times without luck.
Measured the omten switch itself, it does function, but measuring on the spring and pcb, i don’t measure contact.
Am i doing something wrong?
Regards
P
Remember that Bistro is in basic config like you got it without turbo in regular modes modegroup 11
If you want Turbo included you can use modegroup 4
From moon long press goes to hidden modes starting at turbo
If you fear the AMCs short its possible to cut middle leg with a sharp knife and cover then the rest with epoxy glue
Is that one of Hoop’s pills? Beautiful work!
I like to use a copper mcpcb and solder it to the top of the copper pill in the re-flow process. The S2+ I have with Hoop’s pill is making 3029 lumens and I just love it!
Nice mod, enjoy!
Thanks for the tip Lexel, will try that.
Dale, thanks for your compliment, it’s one from Kiriba with filed down notches since it came smooth and i couldn’t figure out how to assemble it without them.
Didn’t spend much time on it yet, since i finished it yesterday evening late, and i’ve got annoyed by the fact that i did not get the switch working again, so have to figure that out first, so another thing to do tonight
Any tips on the switch?
Still not seeing why it doesn’t work
Regards
P
Lexel, thanx for the info!
The switch timing is crucial, had to find out with trial an error how long i needed to press.
Apparently, the retaining ring from the switch was not tight enough (although i thought it was quite tight already)
I really like it with the lighted switch, nice touch that it switches off when turned on and lights up when you switch mode.
Also on turbo its very bright, and i am very happy with the tint.
The XPL-Hi 4B tint is slightly warmer then my 5000K Nichia triple and the copper pill does it’s job very well!
did you have to shave the driver edge to fit the pill?
I had today the opportunity to compare the NW GT driver modded Niwalker with a CW GT driver modded Thrunite TN42
all pictures 50m from target
a bit overexposed on the first shot
reduced ISO on camera for control shot
zoomed iout both lights
TN42 CW
Added a Nichia 219C D240 4000K 90CRI to my Utorch UT01. It was purchased with an XP-L 1A 6500K which is way too cool white for me.
Mod was fairly easy too:
- Unscrew the bezel and you have loose front glass/oring
- Unscrew the reflector which is threaded to the inside of the body tube
- Take the centering ring and set it aside so you dont lose it (it’s important)
- You can either unsolder the LED wires now or lift the pcb from its base and do it while the pcb is suspended
- The LED pcb is not screwed down or anything it only had some thermal paste under it, you can work it out with tweezers from the flat edges and/or the wire holes if you are careful
- I cleaned off the paste and reflowed on the stove top. The pcb isnt clearly marked but the anode/positive side is the same side as the positive LED wire mark and the solder they used seemed to be some leaded low(er) heat stuff so it wasn’t too hard to work with
- Resolder LED wires and
tryto stuff them back through the holes. I only got one side completely back in. The other side I folded over and ran the extra along the edge of the PCB leaving room for the centering ring since there is a good size gap between the reflector base and the pcb/body tube. - Centering ring back on > screw reflector back and re-center everything with the last half turn since the pcb is floating on thermal goo > oring > glass > bezel
Put couple of Simon’s lighted switches in. One in a clear C8, one in a short S2±sort of. Anybody know roughly what the current draw is on those? I love them so far.
ETA: According to my cheap HF meter, 7.5 ma. I don’t love them so much now.
Bought a Convoy M1 host and put a 70.2 in there. FET zener modded from MTN. With 2 aspire 18350 it’s pulling 13A at the tail. It gets hot quicker than the D4 but it’s by far my brightest 18650 sized light…by a huge margin! Also replaced the lens with an AR coated one.
SOFIRN SP32A Turned into a triple
ORIGINAL > SHORTY > TIR LENS > TRIPLE
“Pill” – I bought a piece of brass, as I didn’t find copper in the adequate diameter; later it was cut in some pieces, tall enough for the height need for a pill to sit over the in-built shelf. I filled it and made a hole in the middle. The rest you see below
The MCPCB used is from Jaxman Store and this is the CW XP-G2, and the TIR optics was also from Jaxman.
I soldered new wires to the driver and re-done the spring bypass as the original was not in place anymore.
I added glow-in-the-dark tape all over the fins and other places, including arount the TIR, on the inside
Nice application of the glow-in-the-dark paint MB! Sweet build!
Thank you Dale
BTW, it is GITD tape, I don’t know how to apply the paint or powder + resin (as CRX makes in some mods), so I opted to use the GITD tape (that I have in almost all my lights ) !
Nice. I was wondering about doing the same thing, since the D4 driver has a spare pin. It could totally have a lighted switch or a super-efficient moon mode. There’s even a pad for it already on the driver, but it’s not connected to anything.
Emisar D1S, XPG2 S4 2B d/domed;
Mascaratum, the purple background really makes the parts show nicely, your pics look great!
And see? Told you the mod bug would infect you! Welcome to club Flashaholic!
