Sadly, Milla Jovovich does not has a sister.
Im in :+1: , Have a Wuben that has a beam pattern similar to Saturn
I’m in!
I’ll put some on my D4 to make it even floodier. I’d also like to see it on my Q8 and maybe one of my BLF A6’s. I’ll probably try it out on a lot of lights. Thanks for doing this!
Sign me in. I could use a good diffuser, too.
I’m in. Going to find a nice use for it on one of my camping headlamps
Very interesting looking stuff. Would be good for a Reylight, that has noticeable rings.
I´m in. Not quite sure on which light I would use it on... Probably my Zanflare F1. Also it could be fun to see what it would do to a zoomie
“I’m In”.
On a UT02 to smooth out the intense hotspot (sacrilege I know).
Count me in. Luv to try it on a couple of no-name cheap zoomy loaners.
I’m in…
I’m in! I’ll use it on my Q8. Kidding! I’ll use it on any one of my cheap zoomies to pretty up that beam.
Im in, thanks for the giverway.
Id like to try it on my hc90
I’m in. Will use in several lights, eg. DN70, when a lot of flood is necessary for short range illumination.
I’m in! I’ve heard this stuff would be great on my big ol maglite.
I’m in…cuz my B158B is a little bit homely.Thank you.
Not in but thanks for the giveaway Boaz. :+1:
I’m in. II will use it on an Epsilon ED72
I’m in! I have a modded SRK that I would use it on. Any chance of getting a piece of one of those ‘other’ styles you said you had? I haven’t seen anyone in your sale thread step up to test it for you with a light box yet, but I’d like to try some if I win.
I’m in!
Looking to use some on a headlamp and make a small diffuser for edc light.
Ut-02 has the same size head as the BLF Q8 so I have made multiple snap on / off diffusers as well as a light sabre lantern that works on both .
