Perhaps our definitions of excellent may differ. My example came with the heatsink not affixed to the light in any fashion.
I use the word 'heatsink' loosely, as it is notably thinner than the MPCB to which it is affixed.
How did you even get the thing apart? By heatsinking, I was referring to the numerous thin cooling fins in the head of the light.
There's a set-screw behind the reflector that hits the battery tube.
Remove this, and everything else comes apart in a normal fashion.
Thanks for the write-up, chidwack!
Has anyone tested the parasitic drain? Can you securely lock out the tailcap?
You're welcome Huny74. Yes you can lock out the tailcap. I would recommend doing so if you are going to carry the light in a backpack or something like that as the button does click on quite easily.
Manafont says it has a low mode. What's the runtime on an Eneloop on low?
Looks like good value!
I haven't checked the run time on the low mode. I would think that it would last about 6-7 hours.
"place a 30-45 degree TIR optics instead of the original reflector and lens."
Any suggestions where to get something like that?
Also, does anyone think it can be modded to run longer than 7 hours?
I'm sorry to say that 8 days later, my UF-V4 is dead. Well, maybe not completely dead but it looks like it only has about 20 lumens left. It has been slowly getting dimmer each time I use it. At first I thought it was just my eyes playing tricks on me. After reading about some saying the light will work with 14500 and some saying it won't, I decided to put one in it and check it out last night. I figured that the light was getting dim enough that if I killed it, it wouldn't be a big deal considering what I paid for it in the first place. It was much brighter with the 14500. I only tried it for a few minutes and turned it off. This morning I put a AA NiMh back in and hardly any brightness at all. I changed back to the 14500 and it turned on for a second and then went off. Back to AA NiMh and still very dim.
I'm going to order one from CNQ that says it will use 14500 batteries.
Hmm, so are you saying it was already dying ("It has been slowly getting dimmer each time I use it") on the AA and then you tried the 14500? Or was it fine on AA until you tried the 14500? Clarify please.
-Garry
Yes that is what I am saying. It may be my fault. Everything changed when I decided to take the light apart and have look under the reflector. I have never modded a light and this was my first attempt at taking things apart. I could be wrong but it seems that when I put the light back together the beam changed. It seemed much more of a yellow color. I thought I was just seeing things and didn't really remember what it had looked like before. I played with the light for a few days and it just got gradually dimmer. It was kind of like boiling a frog in a pot. The frog doesn't know that you keep turning the heat up because you do so a little at a time. Soon it's much hotter than when you began. Same way with my light. When I finally noticed that it was getting dimmer was when I shined the UF-V4 against the wall next to my Zebralight H51. When I first got the UF-V4 I noticed the H51 on the High Low mode was about the same brightness. Now there is no comparison.
Sorry to hear about that! (ordered one two days ago after reading this thread)
Has the tint shifted to brownish? Maybe it's an overheat issue because of the apparantly poor stock heatsinking from the LED to the body (referring to Chicago X's post #8)? If the current to the LED still is OK it maybe worth trying to swap the emitter and improve the thermal path.
I checked that and the led isn't brown.
Mine works as good as 1st day. AA only not compatible with 14500's.
I use UF-V4 also as a nightlamp.
It seems yesterday Ileft it on and fall a sleep. It was on low.
14500 protected trustfire was inside (usually low-voltage protection, in my experience, doesnt work on any trustfire flames)
Now the batt is from 0 - 0,1 V when I measure it.
What to do with it??
MAybe the protection circuit kicked in after all, and need resetting?
Should I put it in some charger nevertheless? (wich one, WP2, MP1 or Nitecore maybe would be the best?)
With that reading, it appears that the protection may have ‘tripped.’
Try putting it in the charger for 30 seconds, and re-check the voltage.
If it really was discharged that far do not put that in the nitecore intellicharger. That means it would charge it as if it was a nimh battery.
I will put it in MP1
i am puzzled why mine works with metal object accross battery and tube but with tailcap on it doesnt work. i’ve looked closely at the spring clean it and all doesnt seem like t here is a problem with soldering or anything, anyone have same problem ?
Have you measured the resistance of the switch?
