I believe these cells are still being produced by Shen Zhen Yong Deli, it's great to see KeepPower marketing them.
Cheers :-)
Cheers :-)
thanks for the links and info
fwiw, protected 18350 are longer than unprotected.
For my PT-16, the unprotected work, the Protected are too long
also:
https://www.aliexpress.com/item/High-Quality-2pcs-P1835C2-IMR18350-1200mAh-3-7V-10A-Rechargeable-18350-Protected-Li-ion-Battery-With/32835752588.html?spm=a2g0s.13010208.99999999.370.fFSKuH
“Can not deliver to United States”
Thank jon_slider Apart from 2 Panasonic 18650, I don’t have protected Li-Ion cells, but I am aware those are normally longer and thicker than the non protected :+1:
Also, didn’t check the shipping from that store :person_facepalming: But there are some other stores that have those and that probably ship to the US
This appears to be the same cell under the wrapper as the Aspire 18350.
I’ll stick with the Aspire for now since I can get them in the US and cheaper.
https://liionwholesale.com/collections/batteries/products/aspire-18350-battery-10a-15a-1100mah-genuine-and-tested?variant=37706165649
Thanks for the review HKJ, very much appreciated. :+1:
I am aware those [protected] are normally longer and thicker than the non protected
surprisingly, to me, the 16340 protected and unprotected are the same length (in inches), or 0.25 mm longer for protected.
The 18350 difference is much greater (IF the linked specs are accurate)
Protected 18350:
https://www.batteryjunction.com/efest-3400-button.html
Height: 1.47” (37.36 mm)
UnProtected 18350
https://www.batteryjunction.com/efest-4084-opt.html
Height: 34.63 mm
Added length of protected 18350, 2.73 mm
Protected 16340
https://www.batteryjunction.com/efest-3540-button.html
Height: 1.33” (33.98mm)
Unprotected 16340
https://www.batteryjunction.com/efest-3277-button-700mah.html
Height: 1.34” (33.98mm)
Added length of protected 16340, 0.25 mm
This store is currently shipping the Keeppower UH1835P to Brazil and I imagine other countries where shipping is often unavailable, I’ve bought keeppwers from them before (currently unwrapped and returned to unprotected panny-B state)
These cells are now in stock from nkon.nl, a highly reputable European vendor (no affiliation).
They do however state that the cells are 39 mm long. Which makes me wonder if they’ll fit properly in my Emisar D4?
The springs should have enough play, but I’ll hold my order until I at least get home and try to cram a measured battery with a spacer in there!
Or can anyone verify that these cells will work in a D4?
HKJ states 35 mm though, and “highly reputable” is the least of his accolades. But different batches, different specs? Fake cells? Or just misspelled on nkon?
I’ll be back with a solution to the conundrum when I have it, unless solved by another.
35mm is unprotected cell and it can be seen on my photo that the cell is unprotected.
39mm is a protected probably button top cell.
Nice cells, allowing small lights with multiple emitters to shine, the closely resemble the Vapcell 18350 purple.
Still, the Aspire cells were even better but extremely hard to gome by………
Tnx for testing!
Cheers,
Nico
I have the aspire 1100, keeppower 1200, and the vapcell 1100, pretty sure the only difference is the wrapper.
The springs should have enough play, but I’ll hold my order until I at least get home and try to cram a measured battery with a spacer in there!Or can anyone verify that these cells will work in a D4?
Hei Imp…
My
Aspire 34.91 long (fit D4)
Keeppower 35.09 long (fit D4)
Ultrafire (protected button top) 38.78 long (do NOT fit D4)
So there you go…
I received an answer from nkon. Despite the time being post 5 pm on a Friday!
Hi Ted,
I’ve changed the height and the width. It was not correct.
Height: 34.76
Width: 17.91I’m sorry for the inconvenience!
Kind regards / Met vriendelijke groeten,
Mithat Kamer
NKON
So it seems like they’re fine. Although Hunter’s post makes me curious as to the measurements and batches, if nothing else…
I’ll order a bunch anyhow!
Hi Imp…
Yes it must be batch variations. Mine Keeppowers are 35.09 to 35.19 in length and 18.27 to 18.29 in width.
Otherwise, exactly the same battery as described.
Still, the Aspire cells were even better but extremely hard to gome by………Tnx for testing!
Cheers,
Nico
The Aspire, Vapcell, and this Keeppower are same cell, all made by the same factory. Yongdeli New Energy Battery. Tony, the owner of Aspire E-Cig is part owner in the battery factory. At least he was a year ago.
I have now received my five batteries. They are indeed about 35 mm long.
The measurement of 39 mm corresponds to Keeppowers protected 18350 cells, so the error was probably made by looking at the wrong specs, but has since been corrected.
The cells arrived in retail boxes of two, including a case for two 18350 or 18500. With a bit of cutting they can be made to fit three 18350s though! (And the fifth cell came in another of the same case, even though I ordered several other cases, one of which was used to package the two HG2s I also bought).
Furthermore, the Keeppower case for one 18650, which is apparently made with protected cells in mind, can just about fit two of these cells, with a very thin insulator! With a little bit of cutting it should be possible to fit a somewhat thicker piece of plastic in between, making it a very compact case for the job!
Thanks for the info. With regards to the insulator thing, no need for it strictly speaking unless you aim to prevent any scuff marks, ?
Cheers ^:)
Cheers :partying_face:
No, I’m more after a “spacer”, or something to hold the cells in place, as the case is on the large side and they will rattle and move if there’s only one in there. Yes, “insulator” may have been a bad choice of word, but it was natural in the circumstance.
What's up, fellows?
Just dropped by to ask how these cells are doing lately, or how are these cells being made right now. I at least hope their performance is up to par.
I am namely asking because after looking at their sale advertisement in the Convoy store, this is what I see in the pictures:
I see a six lobe cell top with round disc atop of it, a clearly different shape than before. Did anyone purchased this cell recently to confirm this?
Also, any comments with regards to this cell's lifespan and self-discharge are appreciated. I may use it to build a custom power tool battery pack.
Thank you and cheers.
I ordered two of Keepower (UH1835P) cells on May 2021 from a different Aliexpress seller. The cells looks different from HKJ’s review and appears to be the same as the one sold on Convoy store.
Both of my cells show very high self-discharge rate. One lost 0.20v from full in 26 days and the other in 20 days. I am not sure if these cells generally show very high self-discharge rate, but I have not yet come by other information that shows otherwise.
However, the cells seem to pump the high current it claims.
Here are my previous discussion on these cells:
I have two 18350 cells from Keepower (UH1835P) that self discharge very fast. One lost 0.20v from full in 26 days and the other in 20 days. I think my cells are defective. I would monitor if the voltages are dropping for a week. If there is significantly high self-discharge, then it would not settle. At least my Keepower cells do not.
The keepowers I have is purchased on May 2021. And they did not see much use. When I first used it, I had a feeling that battery levels go down way faster than what I am used to. I thought it may be because of lower capacity (1200mAh) than 18650 cells that I normally use. I recently decided to investigate it and decided to measure voltage every day after fully charging them and I got the numbers. Interestingly battery capacity seems to be within spec, despite the high self discharge rate. Had I…
Barkuti, good to see you on here again. I have a couple of those that I got a year or so ago from either Illumn or Liion Wholesale here in the US…looks like the same cell (same model, same button). I have not see the self discharge in my pair that Limsup did. I don’t use them a lot but have been impressed with what they can deliver. I only have maybe 8 or 9 cycles on them so I can’t offer anything there.
