Emisar flashlights - the D4 is really cool, puts out a lot of power from s small host, albeit not sustained. The D1 is more practical and has the same cool user interface
Convoy S2+ host + MTN-electronics 17mm FET+1 driver + a couple of emitters with different tints (cool, neutral and warm). This would be a modding starter kit as you would only need to solder 2 wires on the LED board, super easy, results in a great flashlight if you don’t want to mod any further, output still can be raised if you like to keep modding.
Batteries with higher capacity for longer run times: Sanyo NCR18650GA or Samsung 35E. They both can sustain 10A discharge, so you are not trading capacity for all that much discharge rate. If you only buy a handful for now, the 30Q will give performance on lights that make use of higher drain without giving up to much capacity. The Sony VTC5a (lower capacity and higher discharge) and VTC6 (same capacity as 30Q, higher discharge) are also popular choices on the forum
A headlamp
Lii-500 charger
Nitecore TIP (the high CRI version)
What I’d get if I had the budget:
BLF Q8
What I wouldn’t get if I was starting:
Any luxury materials (flashlights made completely out of copper/titanium) or special editions
Anything from more expensive brands
Flashlights that run on a battery type I don’t already have. I’d start with 18650s, and only after a while flashlights that use 18350s, 16340s, 26650s, etc
Now that’s a list! Thanks for taking the time to do this. It’s a big help as I try to figure out whether I like cool or warm, which UIs I like, battery issues, etc. Much appreciated.
A couple of people sent PM’s that suggested lists very similar to this. With 2 or 3 saying the same thing, my confidence goes way up. I appreciate the suggestions.
Thanks for the tips on dipping my toe into modding. Those details will help me order! Also, I like the advice about batteries. This whole thing is about to get really interesting.
And genuine(!) UltraFire, at least as far as lights.
But then there are fakes of even good brands and models (eg, the 30Q, HG2, etc.).
Generally, Fasttech and GearBest will sell the genuine articles over in China, and lots of places here in the states (I’ll let someone else rattle off some names).
Avoid fly-by-night sellers on Fleabay and the like. You’ll likely get a cell filled with sand or flour…
Regarding Tint, CRI, UI, batteries and other considerations, you won’t really know until you’ve tried a few dozen lights, and own a drawer full of batteries. :laughing:
Anyway, whatever your preference are, you often end up liking a light for just one reason (cute, small, bright, cheap, easy to use, material…) regardless of all other qualities. :person_facepalming:
none of the following lights are your typical Low CRI 6000k Cool White
they are all High CRI 4000k
18650 option… read review: JAXMAN E2 Nichia this light also has an 18350 option (this light offers a choice of either 4000k or 5700k, both high CRI) It uses PWM, which gives it a demerit in my snobby view
“Light” Pocket carry,
AAA Lumintop Tool w Nichia, the Titanium version is most pocket friendly read review
Notes and suggestions
Storing Lights with LiIon cells in a hot car may not be wise, but there are plenty of cheap Cool White, Low CRI 18650 options.
Eneloop AAA and AA are Fun, for me. Imo AA Eneloop is a candidate for car storage, thought disposable Ultimate Lithium are better.
Using unprotected lights with unprotected cells may not be wise
For lights that do NOT have built in low voltage protection, use protected cells
Buy lights that have a way to let you know when the battery is getting low, so you don’t have to take the cells out and use a meter on them repeatedly and unnecessarily.
What I carry most
the range of color they offer me (two on left are modified)
For headlamp, have a look at skilhunt H03, coupons always available somewhere to bring the price down to around $30.
Lumintop tool is a nice AAA light with a satisfying tail clicks (well, more satisfying than the practical twisty switch most AAA lights use)
If another batch is ever made, the BLF-348 is really nice for the money.
Fun-wise, Emisar D4 is pretty rediculous for size:output, comes in multiple “flavours” of LED so you’ll have to make a choice! Puts out a floody beam. I don’t routinely carry mine as I find the side switch is a bit too easy to press, it’s more of a “take if you know it’s going to be dark” kind of light.
TN42 is also a fun one, throws a beam of light rediculously far, Astrolux M02 might give it a run for itsoney, cost wise, but I’ve not looked at any of the reviews.
Bought a loudspeaker once that came with a brick inside the cabinet. I appreciate the heads-up about batteries. I’ll stick to names that are known for reliability & service.
I’ve seen the recs for things like the Q8 and such, but for a good light for a “beginner”, I can recommend a few things.
Boruit RJ02 headlamp — Hands-down the most useful light I have for “doing stuff”, whether it’s grubbling around in bags or a cabinet, when you don’t give much thought to holding the light with one hand and grubbling around one-handed with the other. Having both hands free is a breath of freedom you can’t appreciate until you experience it, and then you’ll NEVER want to go back. They’re <10bux each, so get 4-5 of ’em. Seriously. Built-in charger, so all you need is a usb cable and you’ll never even have to open it up.
Convoy S2+ tubelight — General purpose almost-do-anything light. Get some 20mm TIR lenses which’ll just drop-in and replace the reflector, no soldering or anything needed, and you’ll be able to go from spot to flood in whatever increments you want. Get a few of those to play with, a 6×7135 and the LED with the 4C tint. You’ll thank me later.
Convoy C8 or variant, eg, the Sofirn C8F — No collection is complete without a mini-thrower like the C8, period. All the C8 variants, that’s a thread in itself. The new Sofirn I mentioned with the side-switch kicks ass.
Jetbeam Jet-I, Sofirn SP10B, for AA/14500 lights — if you want a pockettable EDC light, either of these will do nicely, a twisty like the Jetbeam or side-clicky like the Sofirn. The Jetbeam automatically locks out when you untwist it (duh), and the Sofirn has an electronic lockout, or just untwist the end-cap a half-turn or so.
I happen to EDC a nice simple 1-mode ’502 (Ultrafire WF-502B), a dinosaur in today’s flashlight world, but I like drop-ins and being able to throw a new one together in one sitting if I want to. Forgot where I left off trying to use a 26mm TIR lens instead of a reflector, but that would be awesome…
Then, after all that, yeah, if you want to piss away some bux, get gee-whizzums lights like the Q8 and such. Nothing wrong with Q8s, as I got 2 of ’em, but they’re Special Purpose lights that’ll otherwise end up being shelf-queens like my L2s and such. You’re not gonna carry one around in your bag, let alone on your person, so… why?
One of my faves, ’though of course no longer available, is the Sofirn SF31W, in warrrrrrm-white. Wonnnnnnderful. Beautiful beam, great color, nice UI, quickly became my go-to light at home, especially at night.
Interesting! I like your EDC lights. At this point photos of beams make me uncertain of what I’m going to like, but it is really helpful to see what others use after trying many different lights.
You raise an excellent point. When I start looking at each light, I’m sure I’m going to lean toward lights I can imagine actually using. But, a couple of shelf-queens…maybe just a couple. :cowboy_hat_face:
Lightbringer, can you give me some more info on what the TIR lens is, and where to get it? I'm only familiar with the orange peel reflector (for the S2+) sold at Aliepxress.
A practical post just to counter everyone else on here and be a bummer:
You probably shouldn’t spend $300 on flashlights, especially since you don’t plan to do anything outdoors. Hell, a $6.50 bojuit headlamp would be fine. (Though an upgrade to the skilhunt h03 would probably be better).
HAVE to spend $300? I’d aim for variety but still not blow a ton of money.
Buy:
- Charger (home): Miboxer C4-12 for speed or Folomov A4 if you want cheaper. Even liitokala 500. $20-$30ish
- Charger (portable): Liitokala 100 for ~ $2-$3
- Batteries: (2) NCR18650GA for capacity, (2) Sony VTC6 for more power (~$6/battery)
- Headlamp: Skilhunt H03 still. Not worth the extra for zebralight. $25
Small EDC: A zillion options here. If you are actually carrying it AA or AAA might make sense. I hate heavy things in my pockets. Zebralight is the most loved but $80ish. I’d just get something like a Lumintop Tool AAA Nichia, etc. Here’s a favorite AA thread: Best Single AA flashlight for 2017/18 ?. Manker E11 looks pretty nice. AA gets you a lot more capacity than AAA (2500 vs 900mAh).
Optional:
- Handheld: Emisar D4 ($40) or BLF A6 ($25). For high power.
- Throwy: Sofirn C8T ($18) or splurge on Emisar D1S ($40)
Lantern: no good option right now, wait for the BLF project to be ready ($40ish)
Notice that these are nearly 18650 lights. That’s because I think in most use cases they just make a lot more sense than AA. Headlamp/hiking? The h03 is super light and AA models like the Thrunite Th20 are mere ounces lighter. Handheld for home? No reason to be small. Same for throwy. Only an EDC I’d say justifies AA or AAA if you are pocketing it.
Typical battery capacity/weight ratio:
3500mAH 18650 / 47g = 75mAH/g
2550mAH eneloop pro / 30g = 85mAH/g
950mAH eneloop pro / 13g = 73mAH/g
Surprisingly I thought 18650’s almost always won this battle. Looks like the eneloop pros are actually more dense. (The standard eneloops at 2000mAh are only around 66mAH/g)
Here is my list…
Emisar d4 xpl hi 6500 or 5000k tint… $58
Emisar d1s. $40
Blf q8 … maybe $50 with the discount ?
Acebeam L16… $90 ??
Fenix tk35ue. $110
