Thrunite TC20 - XHP70 - 3800lm
448 posts / 0 new
robo819
robo819's picture
Last seen: 1 week 5 days ago
Ok I went out and took a few shots with the TC20 I did my review on. Taken from 22 Feet away at a WHITE garage door , paint is a semi dark beige and the trim is a rust red.
Did this so those asking about the tint on the cool white can judge for themselves , as to whether they like the tint this ONE particular sample I did the review on with the COOL white emitter.
Medium
High
Turbo
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
hIKARInoob
hIKARInoob's picture
Last seen: 3 hours 56 min ago
Nice beam and really bright!
beam0
beam0's picture
Last seen: 13 hours 9 min ago
I’m not seeing the “sickly greenish’ tint reported by Gebe in an earlier post for the CW version, so he may have got a loosing ticket in the tint lottery. I can’t even notice the tint shift in the photos. But for me the real test is when it’s beamed at some leafy greens, trees, shrubs etc.
Not sure the CCT of the CW version but personally I most likely wouldn’t be happy with anything 6000K or higher. It’ll be interesting to see what abglenn has to say, soon he’ll have both tints.
beam0
beam0's picture
RT— wrote:
beam0 wrote:
Still wondering what the CCT is on these.
Measured my NW TC20:
hotspot 4800K
spill 5600K
Have a look at maukka’s review of the Acebeam K30. Temp and tint wise the TC20 is quite similar but not as bad due to the smaller OP reflector.
Thanks, this is a great help!
SKV89
Last seen: 41 min 6 sec ago
I wonder how this compares to the 3,850 lumen Acebeam EC50 Gen III with the XHP 70.2 emitter
beam0
beam0's picture
See previous post by edness (post #80)
http://budgetlightforum.com/comment/1264285#comment-1264285
ZoomieFan
ZoomieFan's picture
Interesting beam. It’s bright, very bright, no doubt about that.
For me the first picture is the most visible one. In the last picture I see one big bright white area. In the first picture I see what the garage door actually looks like. The best part, for me is in the spill.
I even have that problem with my 650lm flashlight. Lot’s of lumen is great when lighting up an large area. But when detail is needed, like reading the label on an paint can in the basement it blinds me.
If the OP deems this question off-topic then I’ll start another thread…
What can be done to make the whole garage door as visible as in the four corners of the first picture? Less lumens? More floody? Different tint? Higher CRI? Maybe a different color like green? Something else?
Chargers: 1xBasen BD01 5/5, 1x Gyrfalcon All-88 4/5, LiitoKala: 3x100 3/5, 2x202 3/5, 1x402 3/5., MiBoxer C4-12 3/5.
Flashlights: DQG Tiny III 26650 5/5, FiTorch MR35 3/5, Haikelite SC26 HD 3/5, Lumintop Tool AA/AAA 4/5, Nitecore LA10, Sofirn C01 BLF 3200k/5600k 2/5, Zebralight H600Fc 3/5.
Powerbanks: EasyAcc 26800 mAh 3/5, Xtar PB2 4/5, Xtar PB2S 5/5
Waiting for: (DQG Tiny) 21700 EDCs.
beam0
beam0's picture
Sounds like what you’re describing is the hotspot “washing out” the subject. You need a triple, quad, or multi-emitter in a TIR optic, (pure flood – no concentrated hotspot) Astrolux MF01 219C maybe?
I recently got one of these with Nichia 219C 5700K (tint is pure white) 720lm so no where near as bright as this TC20, but it’s no slouch either, and great for reading those paint cans Silly JAXMAN-E2L-3LED-TIR-LENS-flashlight-18650
ZoomieFan
ZoomieFan's picture
@beam0
I saved your post for later reference. I’ve learned something. For my use more LEDs is best. Astrolux is to big. I certainly want to stay below 60mm. 40-50mm is what I think is ideal for my type of use. Do certain types of lenses reduce/remove the hotspot?
RT--
Last seen: 1 week 2 days ago
The Gen III is not out yet, but judging by the only picture I have seen, it will have a smooth reflector. Most likely the tint shift will be much worse than the TC20 but slightly better than the K30. I doubt they will make many other changes; just a new reflector and a new emitter, probably driven harder, to stay in the lumen race.
beam0
beam0's picture
Gen III?? My apologies, oops! Thanks for pointing it out, I didn’t know GEN III existed, guess I wasn’t paying much attention since SKV89 did write “3,850 lumen” and “XHP 70.2 emitter” both of which I knew the EC50 II was not. Facepalm
Now I’m also very curious about how it will compare! For one thing the Thrunite TC20 is 13mm shorter, and to me that’s a lot.
As far as the tint shift with SMO reflector… We possibly could look at the Acebeam L30 (4000lm XHP 70.2) I’ve also been considering that one lately, there are several reviews on it but I don’t recall if any reviewed the NW version.
For the L30 Acebeam lists in the features: “Smooth reflector for max. light output” however in one of the photos they have “Moderately Texturing finished reflector” so i’m wondering if it’s actually Light Orange Peel and maybe the EC50 III will have the same.
beam0
beam0's picture
ZoomieFan wrote:
@beam0
Yes, have look at these:
JAXMAN-E2L-3LED-TIR-frosted-LENS
http://budgetlightforum.com/node/54834
But I’m afraid much further discussion about it here will derail too much, so maybe start a new thread on the subject?
RT--
The 13mm difference is alot.
I forgot about the L30 http://budgetlightforum.com/node/57631 Looks smooth to me. And a rainbow on both CW and NW. It’s just a feature of the emitter.
You might be right about the EC50-III. The K60 has an OP reflector but they went for LOP on the K65.
beam0
beam0's picture
Thanks, that’s one of the reviews I was reading couldn’t remember if it was NW version. I still have the L30 under serious consideration for a tactical light, but the TC20 will be a good pocket light for utility/camping/mini searchlight etc.
I much prefer the flat SS bezel of the Thrunite, don’t need those crenelations for that type of flashlight.
Gebe
Last seen: 11 hours 42 min ago
Medium
High
Turbo
!{width:75%}https://s20.postimg.org/tc4ndtrbh/DSC03157.jpg!
Thanks for the pics! When I posted about my TC20 in CW, maybe I shouldn’t have stated “sickly” but to me it’s close.
Notice robo’s first shot at the top picture in the medium mode and notice the darker perimeter around the beam at the edges of the door. Now imagine that but much, much brighter. That’s kind of what my TC20’s CW tints looked liked in all modes except turbo. The turbo mode was the exception and mirrored turbo’s shot.
Like stated before, I’m a CW junkie and imagine getting a light with most modes except the turbo that looked like that! I’m picky but not too excessive but this light’s tints I couldn’t stand. Also imagine getting a Emisar D1 a month earlier and it is the most perfect CW tint I’ve ever seen in ALL modes! Yeah, big letdown with this light and I wanted to like it so much.
Anyway, I guess in the tint lottery I lost. I wonder if anyone else who ordered CW will too. I hope not!
Sent it back to Thrulite today and I know I’m being picky again, but I shouldn’t have had to pay return shipping especially with their “satisfaction guaranteed” warrantee.
beam0
beam0's picture
I’m still amazed and intrigued this newer breed of single-cell flashlights at around 4000lm can use a protected battery. That just goes against what I’ve learned on BLF about “hot rod” lights. But a welcome advancement indeed.
Newlumen
Newlumen's picture
I just preordered a tc20 with CW, using tc20 coupon code.. i hope i make a great decision..
atbglenn
atbglenn's picture
Last seen: 2 years 2 months ago
My cool white just shipped.
Update: Got it today. Happy to say I like a lot better than my neutral white version. I still notice a tint shift, but it’s not as bad as the neutral version. One BLF member didn’t like his because he noticed a greenish tint, Thankfully, I’m not noticing that with mine. All in all I’m very happy with my purchase. BTW, I’m not going to sell my neutral white version. I’ll be using that in my boiler room as a service light.
Boycott Nike
Gebe
Hey, glad you like it! Yeah, the old tint lottery. After dozens of lights purchased through the years, I’ve only had one other light, (which was very green), and this TC20 with it’s muddled beam that I actually couldn’t stand to look at their beams.
Maybe because I WON the lottery bigtime with my CW D1, I’m now spoiled. Smile
mmalive
Last seen: 2 years 5 months ago
Hey guys,
How does Thrunite TC20 compare to Utorch UT02. Both these lights are 26650 powered.
I ordered the Neutal White Version of Utorch UT02 neutral white.
Just wondering if I should order which version of Thrunite TC20?
robo819
robo819's picture
mmalive wrote:
Hey guys,
I personally cant answer that one as I do not have the UT20. Hopefully someone will pop in that has both.
atbglenn
atbglenn's picture
I have both the Emisar D1, and a D1S cool white flashlights. Both have the ultimate cool white tints. That being said, I’m still very satified with the not so perfect cool white Thrunite TC20.
Boycott Nike
Gebe
I’m really glad you are satisfied with yours.
It’s amazing that a light like my D1 at almost half the price of the TC20 and has a perfect switch with no mushiness, and a perfect CW tint, (to me!).
It’s also plenty bright enough for almost any of my needs and if it wasn’t, I’d just buy a D4 with it’s amazing turbo mode and get two lights for almost the price of one TC20!
Besides, for the most part, the TC20’s turbo mode with the 3800lm it produces, doesn’t impress me that much over what the D4 and D1 turbo modes put out. As a plus, the D1 and D4 are so much smaller.
Believe me, I’m not slamming the TC20 and if you like it, that’s all that matters. Go for it!
giorgoskok
giorgoskok's picture
Last seen: 3 days 13 hours ago
mmalive wrote:
Hey guys,
These are 2 different flashights .
UT02 has ~1000 lumens and throws about 95kcd , it is a thrower .
TC20 has 3600 lumens and throws about 32kcd , it is more of a flooder .
mmalive
giorgoskok wrote:
mmalive wrote:
Hey guys,
So 1 is thrower vs flooder. But price difference is double for TC20. UT02 around $40.
Newlumen
Newlumen's picture
I think thrunite tc20 is a great deal. $72 with the coupon.. you cant beat that.. d4, d1, tc20 are different light…
D4 optics lense.. great… all the lumen are in one hot spot.. brighter and generate more heat.
tc20. General use light.. one guy reviewed he run 2 hours @ 1800 lumen..
beam0
beam0's picture
The D1 only puts out 1300lm on turbo, or am I missing something?
You really can’t compare this to Emisar …
The D4 can only run in turbo for what… maybe 20-30 seconds? And how many 20 second turbo blasts are you going to get before the battery needs recharged? And I’ve read it gets burning hot within seconds on turbo:
Quote from the maker of D4 (Hank @ Int’l Outdoor):
“The D4 will produce tremendous heat on turbo mode, and heat up very fast (10~20 seconds for the thermal protection to kick in depends on the cell)”
The TC20 will run in Turbo for several minutes before step down begins, that’s a huge difference, plus with the 5000mAh 26650 you have a much greater battery capacity, not to mention the TC20 boasts a rated 320m beam distance. Yes both the D1 & D1S will out throw it, but neither are “lumen monsters” And the D4 is pretty much a close range flooder.
I’m not slamming the Emisar either – I’ll be ordering a D4 soon, the TC20 and D4 are both great flashlights but they definitely have their different uses.
beam0
beam0's picture
Thrunite just replied to me the NW version wouldn’t be available again for about 2 months, however on their listing instead of showing “not currently available” it now shows a ship date: “Expected ship date is 02/23/2018” so about 1 month actually.
CM2010
Last seen: 7 hours 19 min ago
Anyone know what other 26650’s fit into this light?
atbglenn
atbglenn's picture
I haven’t tried yet, but I’m pretty sure my Efest unprotected 4200 and 5200mAh flat tops will work. I’ll check later
Boycott Nike
