I know what answer you will be getting :sunglasses:
I got an imalent hr20. Can’t say it is the best, bit functions very well for what I need and haven’t felt the need for a different one… Yet
That’s the one with variable linen output right?? Looks interesting!!
Yeah, it’s got a little dial to adjust brightness on the head
Yeah, I’m predictable…
Boruit RJ02. Cheap, works. Zillions of posts here about it.
Finnno: Kodachrome40:Okay then, I will! , let’s see… which one???
knowledgeable as well
Btw eagerly awaiting for a discount to grab one, again…
[quote=Lightbringer]
What about the free shipping option from Gearbest, doesn’t it exist anymore?
Whatever I might want to get, I ain’t doing untracked anymore, but if the cost is ever “too much”, I’m just going to pass on it.
For the UK at least untracked sometimes has more tracking than tracked.
GB priority line is sometimes Yodel. No tracking information untill the package clears UK customs then YoDel tracking for the last two days.
My last two Tracked airmail parcels both have a Royal Mail domestic tracking number. Again I’ve got no tracking until the package is at Heathrow Mail Centre.
Untracked to the UK is often rail mail. That gets working tracking numbers all the way across asia to Poland. Once the package is inside the EU it goes quiet for a few days until Royal Mail takes over.
Most of the time untracked is free. Tracked airmail is also often free but can be slower than untracked. Priority line to the UK is often less than 50 cents.
Lightbringer: Finnno: Kodachrome40:Okay then, I will! , let’s see… which one???
Hopefully by tomorrow I will have another code available!
Your list of countries doesn’t work for me
But, let the others have it, that’s ok
I also have this light and the onboard charging is already spazzing. Ive had the light just months.
The red indicator light never turns off while its charging :person_facepalming:
I dont dare charge the battery within the light
I never use on board charging, so don’t know if mine actually functions properly or not
Active codes
28/1/2018
Available for these countries:
HK,US,CA,MY,TW,GB,IE,AU,NZ,IN,SG,ZA,PH,GR,NL,HU,CZ,HR,BG,SI,RS
bilakos10:Hopefully by tomorrow I will have another code available!
Where are you from?
Maybe I can try to persuade GB to add your country to my list.
Would you try add TH back to the list , please ?
Please request code for this 18650 case:
https://www.gearbest.com/led-accessories/pp_582741.html
Thank you
ZT102 Digital Multimeter
$ 8.99
bilakosJ154
Woohoo!
Decided on a lark to try this, and it worked!
(Pssst! And you can get more than 1!)
Tnx!
Thank you
Roger that
If I can recall correctly, the previous code I was given had problems with its activation.
Thank you everyone for the advice on headlamps and thank you for the codes!!
bilakos10:ZT102 Digital Multimeter
$ 8.99
bilakosJ154Woohoo!
Tnx!
Haha, why did you think that it wouldn’t work?
