Sorry, you are correct Pete! I’ve re-done the test from OFF and it shut down after 3m25secs.
Previously I didn’t notice but I had started from ON so it stepped down to Medium after the same time!
Funny, I had never tested this way… You are correct! And now I agree with agent80 comment: why? :person_facepalming:
It could have stepped down instead of shutting OFF…
EDIT: only now I read carefully NikolaS previous posts, where that was said as well, so ignore my comments… :person_facepalming:
I have to agree, the moonlight is so low its not really usable, I just got one of these cause of the promo where you get a free 1000 lumen diving light, good deal for $15ish.
My fenix protected cell is too long and it wont work in this light, I put an older & shorter trustfire 14500 in and it works, but I’m not seeing any brightness jump over a NI-MH, but the battery was a little low at 3.7V, so I’m charging it now and will try again.
Side by side with Klarus MI-7 and its getting blown away by the Klarus atm. Will give it another shot after the cell is fully
charged.
Really thought they had addressed the protected length issue, but seems its still problematic.
Edit/ didn’t realize turbo was hidden like some olights, will update after my battery comes off charger, hopefully it’s closer to the Klarus output
Yep. Doesn’t work with my protected sanyo/evva cell either. I initially thought it did not like the button top, but now I am thinking it is probably because of the length.
SP10A all the same with SP10B, all with the same function 4+1 modes, just the black color called SP10A, the blue and red color called SP10B.
You can see this link on Aliexpress Sofirn SP10A/B
Please see the link of Sofirn SP10A/B on Aliexpress Sofirn SP10A/B
@ Blackbeard: Hedy is not from Sofrin Official Store! On that store that the link leads to, there may be some “old” black SP10B.
On Sofirn stores I guess you will probably find the SP10B being sold (currently) in red and blue. The black version is now the SP10A.
@ Hedy : I guess that if you are a seller and can give discounts, that is nice, members here appreciate discounts for sure! But I think that you should indicate that you are a seller and make you also make own thread of discounts for the products you offer, instead of these “disguised as Sofirn” links.
well it definently does not fit longer protected cells, and it says 10B is the black version, thought it would be the newer model, I only have a few 14500’s and 2 are newer fenix cells which are very long, my older ones are not long for this world so it may be an issue in the coming months where I will have to just run it on NI-MH, kinda dissapointing, even the pic on amazon for the black one just says sp10. amazon had a promo and it came with free SD02 diving light so it was a helluva deal for just the price of the AA model
so what exactly am I holding here? It put a decent chip in the wrapper on the positive end of a fairly new fenix protected cell, I’m not willing to crank the tailcap any harder. it is the exact same length as klarus MI-7 which has no problem with that cell and slightly shorter then Lumintop tool AA with the clickie installed. I would say all 3 of these lights have about the same output on highest settings, with 14500, with the sofirn being the warmest tint and tightest hot spot.
