Nice Don. Let us know how you like it.
Nice! I see it’s an upgrade from TZ4.
Yep, the TZ4 has been a faithful performer for almost 10 years; worn a little about the corners.
Almost $300 to get these tiny things CNCd:
Sure… But how are you going to obtain 1.21 GigaWatts?
In case you haven’t noticed, New member ERTD has been banned for being a confrontational jerk, not only towards me, but to other members as well. All his posts have been deleted by SB.
He was banned? So he appears the same guy lamplight firefly which our comments become sick and sick
atbglenn:In case you haven’t noticed, New member ERTD has been banned for being a confrontational jerk, not only towards me, but to other members as well. All his posts have been deleted by SB.
lamplightfirefly which our comments become sick and sick
I thought he might have been LedBuy. Who knows? All I do know he was here to cause problems. I’m glad SB took care of it quickly.
By running water through it to cool it down
It was just a matter of time Great thread by the way glenn! :+1:
Thanks pal!
The dial indicator i received a few days ago from aliexpress didn’t work, not surprising after opening it and having a look, i’ll see if i can make a bushing to fix it :person_facepalming:
Looks like the shaft on the gear is broken
I never use dash charger.
Check out the charge rate using the Dash charger.
Jason56:I never use dash charger.
As l posted earlier, l think OnePlus’ Dash charging is better for the battery than the usual lower rates. As l pointed out earlier, my battery gets more hot using the ‘normal’ rates than the Dash charging technology in my OnePlus.
l tried the lower, slower charging rates thinking it should be better but because the Dash charging technique has a special circuitry that routes back the heat to the psu, only the psu gets hot.
ln fact, l notice my battery’s performance is as good as when l first started using my phone, going into its 3rd year.
atbglenn: Jason56:I never use dash charger.
I like what I’m seeing. Notice that the battery was only 27.5 degrees C?. Just ordered the Dash car charger.
tatasal: atbglenn: Jason56:I never use dash charger.
One more personal technique of mine to prolong my battery’s cycle life is to avoid having the battery fully charged the whole night and instead just charge it the next morning instead since it doesn’t take long to charge it 80% using the oem Dash charging anyway.
It’s a well-known fact that a high SOC (state-of-charge) is detrimental to lithium-ions.
…and more detrimental is high heat situations.
Got a Dash car charger for my OnePlus 5T, and a new Watts kitchen sink filtered water faucet to replace my old leaky one.
Also just got a handheld laser distance meter from gearbest.
Didn’t you just recently order the distance gadget? How long did you wait?
Nice. That distance meter looks familiar.
